Old 09-24-2015, 12:38 AM   #15
Astroboy
Astroboy's Avatar
Drives: None
Well, @Astroboy, I'm not going to give you any more suggestions until you have told me you have cleaned up the oil and tightened up that bolt ..... and if the oil leak returned .......
And THEN, ...... I'll guess again ......
(jest ah messen wich ya ...... )
humfrz
I just want to see if any one else has experienced this. I'm going to re torque it when I go back to work. I need the torque specs tho
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 09-24-2015, 02:02 AM   #16
humfrz
Well, OK.
Let's see, tightening that bolt down.
Since it's not a head bolt, how about using a standard length box end wrench of the appropriate size. Just tighten it down till it's "tight". You won't over tighten it or twist it off with a wrench like that (without a pipe on the wrench.....).
Oh, you can't reach it with a box end wrench ...... OK, you may use a ratchet, no bigger than 3/8" drive. Tighten till it's "tight" ..... that's as tight as you can get it using only one hand ..... and NOT using your other hand or foot for leverage.
Well, OK ....... so, ol humfrz is out of touch ......
How about torqueing it down to about 15 ft lbs.
If the bolt twists off ..... I was wrong ..... if the bolt falls out after you have driven a ways ...... I was wrong ......
By this time someone should come along to tell ol humfrz that he doesn’t know what he is talking about …. and help you out........
humfrz
Kaotic Lazagna (10-12-2015)
Search this Thread:
Advanced Search
Gas Leak? Fuco Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 10-07-2022 10:40 AM
oil leak ! frsqc Issues | Warranty | Recalls / TSB 5 07-01-2015 08:08 PM
Help - oil leak tlim Engine, Exhaust, Transmission 4 04-10-2015 09:40 AM
Oil leak. ohnoitsthefuzz Issues | Warranty | Recalls / TSB 2 03-23-2015 02:31 AM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 11:31 PM
