#71 |
#72 |
Drives: 15FRS, 05MustangGT, 85Toyota truck
Clutch pop starting does work on our cars...I've done it more than once...(obviously ignition key must be in on position) yet I'm not sure if that's his only problem (engine starter won't crank engine, yet everything else ok ?).
I've also driven the car downhill on winding dirt roads with the engine off...just for kicks...lol. I was an auto tech at a Honda Stealership years ago. We did install those gadgets on new cars for a while...thus the experience and knowledge given. I'm not sure if what's on his car is as simple as what we installed, but expect so. Easy to install, and fast to install...and the tech gets paid little for the job...therefore lots of chances for error... For me, I'd think nothing of removing the device and put the car's wires back as they were from the factory. Doubtful that a tech would even notice...if wires crimped back together properly. Though wouldn't it be just nice to prove to a Stealership that sometimes crap they install, not recommended by the manufacturer can easily cause problems. If a car works as new, don't mess with it. If the car gets towed, especially under warranty...then the parts dept, sales dept, and service dept can all fight over who pays for the bill. Very stupid overall for dealerships to install these devices unasked for, on all their new cars. Customers should complain to the manufacturer. Just my rant... |
| The Following User Says Thank You to ToySub1946 For This Useful Post: | SkiRideDrive (09-14-2015) |
#73 |
fabulous
Works perfectly. ...as long as everything else is ok, if you know what I mean.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (09-14-2015) |
#74 |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (09-14-2015) |
#75 | |
Ya, right .... so, ....... you were quietly leaving your lady friend’s house, down the back road, after her husband came home unexpectedly ..... ?? ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | ToySub1946 (09-14-2015) |
#76 |
fabulous
#77 | |
I dont think you can rule out your nanny box completly if its connected to the OBD port All the Control units in the car exchange data on the CAN bus, if your device is swamping the buss with crap data or interfering with communications on the CAN buss then car wont start. The ECU DASH and Imobiliser module need to exchange data for the car to start @SkiRideDrive IF that nanny device is still connected to the OBD port then definitely disconnect it completely don't just power it off its may be interfering with CAN buss communications |
#78 |
First do everything you were told by others above, if that does not work...
And if all of this info sets you off on a tangent, totally unrelated to your problem, then I apologize in advance, and sorry I'm not there to see it in person. Disclaimer: "DONT TRY THIS AT HOME" O.K. lets for my sake go back to that dealer installed thing. let's for the moment assume it's the problem, and it's activated, and it simply creates an open circuit to the wire going to the starter relay....that ONLY, and does nothing else. Attached pic of my car's wiring in car...to compare to pic in video...so you see what a stock wiring is like, with nothing aftermarket attached. Then I have two pics at the starter solenoid. First pic is of wires covered...one from the battery, large wire, covered with black rubber, second small wire still attached. Second pic is of same wires at solenoid with rubber pulled back, and small wire to solenoid has black hard plastic end removed from solenoid (push in on top of hard plastic to remove). Starting my car with ignition key in on position, >>>gearshift lever in neutral<<<, e-brake pulled up all the way on, no need to push in clutch pedal. YET COULD BE DANGEROUS IF CAR NOT FOR SURE IN NEUTRAL. Best to have a second person inside car with foot hard on the brake pedal on the floor for safety reason. So I started my car (tonight) by connecting these two terminals with a screwdriver. Screwdriver should not be grounded against anything else, and not hit third large copper terminal (barely shown)...only between both uncovered terminals. Note: This surely causes a spark at the screwdriver tip, and the sound of the starter whilst doing so, may make one jump, as in startling...but it works. Certainly a better way would be wires with a hand switch. aka 'remote starter switch'. This is all very basic knowledge, any auto tech would know, just really simple. If the above does get the car to start and run, then the next step would be to get rid of that dealer installed item...by clipping all it's wires, where it's been tapped into the fuse box...computer...certainly easy to just follow all it's wiring and remove the entire aftermarket stuff it contains. The fun of it all, as always, is learning one's own car gradually, becoming less afraid of it's innards. Certainly a way to fall in love, never wanting to give up the car. Last edited by ToySub1946; 09-14-2015 at 06:07 AM. |
#79 |
Drives: 2017 Fiesta ST
Not sure if suggested already, but did you check if the Steering Wheel may be locked?
My humble Build thread: http://www.ft86club.com/forums/showthread.php?t=36716
#80 |
Drives: Frs
#81 | |
Drives: 2015 FRS
As for jumping the solenoid with a screwdriver, I have done that on motorcycles and it may turn the motor over, but I don't foresee that solving my problem. Also, if I screw it up you can fry a lot of things and I'd rather not go causing any problems. Also wheel is not locked, I can rotate the key to start the car, just nothing happens. If anyone disagrees please let me know. Best I have got at this point.
2015 FRS Ultramarine.
| The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post: | ToySub1946 (09-14-2015), Ultramaroon (09-14-2015) |
#82 | |
Oh yes, DON'T leave the dealership without a detailed explanation of what was wrong and how it was fixed............ ![]() Tell them that ...... The Forum Guys ....... "gots ta know" ...... ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Tcoat (09-15-2015), Ultramaroon (09-14-2015) |
#83 |
Drives: 2015 FRS
Oh yea I will definitely try to figure that out to fill everyone in.
| The Following 2 Users Say Thank You to SkiRideDrive For This Useful Post: | humfrz (09-14-2015), Ultramaroon (09-14-2015) |
#84 | |
@steve99 I'm well aware of the CAN bus and how it works. The nanny isn't even powered on until the button is pressed. When the button is pressed it gets power and sends a single message over the network. When the button is released power is back off. There isn't even a slight chance of it causing error frames on the bus. Even if it's purposely programmed to spam the bus you would simply get a check engine light for the next 10 miles... It can't alter the ECU with how it's flashed. It sends the exact data the manual pedal dance does, no different. The only harm the nanny could possibly do is blow the OBD fuse if a high powered device is plugged in the OBD pass-thru while the 86Nanny is enabled (which is why the ACC harness exists).
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 10:57 AM |
| Where did you start with your FR-S/BRZ | jeepmor | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-10-2014 02:39 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 07:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) -- General Topics | 5 | 03-22-2013 03:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
