#29 | |
Drives: 2015 FR-S
Anything I could think of about this car is either in here already or just in the case of that wiring issue I had, just a post away from being solved. I think a great deal of why it's so great a source for info is the amount of traffic that is in here. I love seeing all the new posts, even if they are problems like this one, as I soak all that stuff up in case I might need to use it later. |
| The Following User Says Thank You to Impureclient For This Useful Post: | SkiRideDrive (09-13-2015) |
#30 |
Have you checked the battery voltage when the car is NOT running ... ??
It should be about 12.6 V. With the engine running, you should be getting around your 13.5 V. http://www.aa1car.com/library/battery_runs_down.htm humfrz |
#31 |
Ya that is wrong! Have given that out 20 times I think. Pull your manual it is in there at page 276 (went old school). Or page 35 in the BRZ manual attached since the FRS one does not seem to be available in PDF. Fuse 21
#32 | |
Drives: 2015 FRS
Big fusible links?
2015 FRS Ultramarine.
#33 | |
Drives: 2015 FRS
The measurement was takenough with the car not running. I can't get the car to run...wish I could.
#34 | |
Edit: AHHHH he beat me to it.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | humfrz (09-13-2015), SkiRideDrive (09-13-2015) |
#35 | |
Drives: 2015 FRS
Thanks.
#36 |
And ironically enough one of the main reasons there is so much traffic is that this is also a highly social forum where people joke around and actually enjoy themselves. Pure tech forums can be empty wastelands or only have a handful of people. So those "totaled" or "cuddle it" jokes may not help the OP directly but they do keep people coming back and then eventually somebody can help.
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | Braces (09-13-2015), cdo221 (09-14-2015), humfrz (09-13-2015), Impureclient (09-13-2015), SisterBlue22 (09-13-2015), Ultramaroon (09-13-2015) |
#37 | |
under bonnet their are more fuse box's in those their are some about 10mm square plastic blocks , they are fusible links (big fuses, just different to the tiny blade fuse.) they are generally the high capacity ones like 30 to 80 amps for starter headlights ect. |
| The Following User Says Thank You to steve99 For This Useful Post: | SkiRideDrive (09-13-2015) |
#38 |
Fuses 21, 30 and 45 seem to be the main ones for starting. I would start with them.
| The Following User Says Thank You to Tcoat For This Useful Post: | SkiRideDrive (09-13-2015) |
#39 |
#40 | ||
#41 |
@Tcoat mine is the full service manual wiring diagrams :-)
| The Following User Says Thank You to steve99 For This Useful Post: | Tcoat (09-13-2015) |
#42 |
Drives: 2015 FR-S
I agree, it may seem like it's not joking time but keeping the new topics fresh like that keep them up top and make them more "clickable".
| The Following User Says Thank You to Impureclient For This Useful Post: | Tcoat (09-13-2015) |
| Pushed start.. didnt start | im_topher | Engine, Exhaust, Transmission | 86 | 11-29-2015 10:57 AM |
| Where did you start with your FR-S/BRZ | jeepmor | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 04-10-2014 02:39 AM |
| Battery dies, push start car in gear.... push start button | rhythmM | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-27-2014 07:06 PM |
| Pop-Start with Push-Button Start | cmspooner | BRZ First-Gen (2012+) -- General Topics | 5 | 03-22-2013 03:45 PM |
| Push Start Rough Engine Start Up | joergasm | Engine, Exhaust, Transmission | 3 | 12-12-2012 04:44 AM |
