Old 09-18-2015, 08:35 PM   #15
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Have you checked to make sure that your hat to ring bolts are all tight?
I totally spaced that, but i will be pulling these all apart tonight, so will check that too.
gdrider77 is offline   Reply With Quote
Old 09-18-2015, 08:37 PM   #16
gdrider77
gdrider77's Avatar
Here is a video with it.
Shot a few runs with the camera outside next to wheel, and also have it with the camera sitting underhood next to the ABS module.
Old 09-18-2015, 08:46 PM   #17
strat61caster
strat61caster's Avatar
Maybe the wheel speed sensor is borked? Damaged wire?
Wouldn't explain binding when the car is off but would explain the ABS kicking in...
ineedyourdiddly
Old 09-18-2015, 09:23 PM   #18
gdrider77
gdrider77's Avatar
I thought about the speed sensors, but they are tied to the ABS correct. I am almost positive its not ABS. I just disconnected the ABS control completely. Sounds still happens. So while it sounds like an abs thing, i think its something more related to the brakes themselves.
I have all just got delivered, brake fluid, new pads, rotors, pistons, gaskets, mounts, etc. basically i ordered everythign but new rotor hats and calipers, but everything to rebuild the calipers. At this point, my next steps are in this order. If at anypoint the step does not resolve, move on to the next step.
  1. Bleed system completely. Full flush. NO LUCK
  2. check rotor runout, if this is in spec, then on to next step, if not, swap rotors. Willwood spec is .005 - .008 Pass.005, Drivers.004
  3. If rotors are in spec, sand rotors lightly to remove any build up NO LUCK
  4. Replace pads, possibly use more aggressive track pads to help with caliper smoothing, i have 2 new sets a bp10 (street) compound, and a polymatrix (track) compound. Wilwood actually recommends something like this. NO LUCK
  5. Swap to stock rotors. calipers, lines. Put factory back on the drivers side, problem gone. Looks like its something with the wilwood setup on drivers side. Now to figure out if its the rotor, rotor hat or a caliper issue. Going to swap rotor first, then rebuild caliper, new pistons, then go from there.
  6. New Rotor
  7. caliper full rebuild
Think that makes sense
Old 09-19-2015, 12:55 AM   #19
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I think it's rattling before you even hit the brakes, but hard to really tell from the video. Check those bolts for sure!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 09-19-2015, 05:30 PM   #20
gdrider77
gdrider77's Avatar
So far not making any progress, but at least eliminating a few things
Im now going to remove the entire BBK and put factory back on,
Old 09-20-2015, 10:02 PM   #21
gdrider77
gdrider77's Avatar
Well. After a lot of time, and unfortunately around $700 in parts from wilwood I'm still no better off.
Still does it. I completely rebuilt the caliper, new orings, new pistons, new seals.
New brake pads, new rotors. Same old problem.
I'm stumped.
Brake Rotors: Rusted Stuck Apex_BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-21-2019 04:40 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
Simple Shut Window Feature Not Working on Driver's Side Gimagination Issues | Warranty | Recalls / TSB 21 05-08-2013 12:59 PM
How to mod Auto headlights shut off time? JSUB BRZ First-Gen (2012+) -- General Topics 12 02-02-2013 01:48 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
