#99 |
Drives: 2015 Raven V8
Have some more random videos.
[ame="https://www.youtube.com/watch?v=av0x0bsb9RM"]2015 FRS 6.2L V8 1/4 Mile - YouTube[/ame] [ame="https://www.youtube.com/watch?v=pdQAHXf1GvY"]Shannonville FRS 6.2L V8 May 2016 - YouTube[/ame] |
| The Following 5 Users Say Thank You to wutsaiu For This Useful Post: | DustinS (10-19-2016), ILLSMOQ (10-31-2016), Lynxis (10-31-2016), Sportsguy83 (01-27-2017), tofurun (11-02-2016) |
#100 |
Drives: 2013 WRB BRZ 6MT
Very interesting to see an LS swapped twin at my local track because now I have a direct basis for comparison. It looks like it's quite a handful now. It looks like it really pushes on entry and then the rear wants to come around on power. Guessing you're still getting used to it in a high performance setting?
#101 | |
Without ABS and brake stability, combined with the the increase in speed on straights I've lost my braking confidence and I brake very early. I'm very fearful of locking the brakes. With front sway bar missing (clearance issue) the car wants to over-steer very easily even without throttle. And of course there is the added power which makes throttle control on corners much much more difficult. I was a massive 2 seconds faster than my own best in a stock FRS. Disappointing? of course a bit but I drove my stock FRS at 100% and was passing other 86 that had minor performance mods. With my V8 I struggled. There are a lot of things I could do to improve this car but they all cost $$$. I already need a new transmission and radiator for next year. I will probably try to get better tires as well but that's about all I can afford to do. Stock suspension stays, couldn't figure out how to get ABS to turn on, and no solution for sway bar yet. Despite all the little annoyances when I drive a stock 86 I just want back in my V8. |
| The Following 3 Users Say Thank You to wutsaiu For This Useful Post: |
#102 |
Drives: Black 17 BRZ LT MT PP
Why not put back the ABS unit?
#103 |
Drives: 2017 WR BLUE BRZ
#104 |
Drives: FRS Silver LS1 swapped.
Adding that much power and torque without adding balancing grip seems kind of nutty.....yah expect slower lap times over OEM....it must be a complete bear to drive it that way on a road course.....over powered for traction and unbalanced with sway bar in rear and sway bar removed in front....remove the rear sway if the fronts removed ....are you on those prias stock rubber?.....good lord man......seems like your having fun though ....I'm assuming no alignment adjustments or anything....
#105 |
#106 | |
| The Following User Says Thank You to wutsaiu For This Useful Post: | cf6mech (11-01-2016) |
#107 | |
#108 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#109 |
Drives: 2013 Ultramarine FR-S
FWIW Those compromises should be short lived. CAN system has been finished for some of the LS ECUs and the others are almost finished. Vorshlag is also working on the sway bar issue. Hopefully they will release that soon as well.
#111 |
#112 | |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-21-2015 12:50 AM |
| $2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 12:23 PM |
| New tires on a budget | jflogerzi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 5 | 01-23-2013 07:32 PM |
| There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 09:14 AM |
