Old 04-07-2016, 10:12 PM   #71
Cerevo
Drives: 2003 Evo GSR TB
I know this is a bit old, but I have to say this makes my decision between Gen coupe and FRS a little harder now.. I really like that you've done this all your self!
I remember, Vorschlag? I think it was, having issues getting the factory gauges to work with the GM ecu. $75 and some working around is all it took. Kind of amazing. That says a lot about you, in a good way.
Could you speak more on what you needed to do with that Canbus system to make the gauges work? (or point me to a thread where it is laid out possibly?)
Again, awesome build!
Cerevo is offline   Reply With Quote
The Following User Says Thank You to Cerevo For This Useful Post:
wutsaiu (04-07-2016)
Old 04-07-2016, 11:46 PM   #72
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
First off you need to disconnect the stock ECU because it will send information packets that will 'zero' out your tach, etc.
You'll notice that some of the gauge cluster works without the ecu connected (fuel, speedo, etc)
To get the ones that are no longer working you need to replicate the packets the ECU originally sent. I managed to figure out a few of them and send my own packets using Arduino with canbus module which I leave connected to OBD2 port permanently. Arduino has inputs and I connected a tach output from the GM ecu to one of the inputs and my code reads the pulses and converts it to rpm value. The rpm value is used in the packet that controls the tach. I did discover at one point the coolant temp packet but I'm using a better temp gauge so I didn't bother programming that. I got the CEL to go off and the power steering to turn on. Traction control is a complex system and I never used it anyways although it would be nice to have the indicator lights for those systems off. The only crucial thing I've yet to get working is ABS but I haven't put any effort into that yet.
For those who don't understand programming I've been very open and shared my code, it's really nothing complex or special. The hard part was figuring out all this on my own. I guess my comp sci degree helped me out for once, it sure didn't get me a good job
wutsaiu is offline   Reply With Quote
The Following 5 Users Say Thank You to wutsaiu For This Useful Post:
86kahl (04-08-2016), Allch Chcar (01-16-2017), Draco_PR23 (04-08-2016), pward08 (06-19-2018), Zer0 (07-07-2016)
Old 04-08-2016, 03:46 AM   #73
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Originally Posted by wutsaiu View Post
My loss is someone else's gain and I can live with that.
You're alright. I like you.
So.. it is stock aside from the big engine?! Definitely take it in for as much warranty work as you possibly can. Just, uh, no oil changes.
Originally Posted by HatchirokuV2.0 View Post
These cars just CRAWL when getting past 127MPH.
Well, man. Jesus.
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
wutsaiu (04-08-2016)
Old 04-08-2016, 05:10 AM   #74
FRS Justin
Drives: 2013 Asphalt FRS
I'm actually thinking about doing this swap on my other frs. Excellent job.
I think it's funny how some people say you ruined the car but if you put a 2j in it they would be all over your junk with praises......SMH......
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
Old 04-08-2016, 08:47 AM   #75
wutsaiu
wutsaiu's Avatar
Well, man. Jesus.
I've thought many times of going in for a cabin filter change, maybe have some hidden cameras.
I decided at least for now to keep the car looking stock, stock wheels, stock shifter handle, I even kept the dealer licence plate trim which I would normally junk immediately. The only visible difference is tires and my two gauges.
Old 04-08-2016, 08:53 AM   #76
wutsaiu
wutsaiu's Avatar
It feels nice when people like your car and the work you did. However at the end of the day I just wanted to put my favorite engine in my new favorite car. It's for me, not for them, and not to show off. It's also not a race car, I didn't change engine to get better lap times. I just wanted the power and sound I had with my last car in the lightweight modern body of the FRS.
The Following 6 Users Say Thank You to wutsaiu For This Useful Post:
bakerr6 (07-21-2016), Draco_PR23 (04-08-2016), FRS Justin (04-08-2016), Itsjustjoe (07-08-2016), Kiwi Greg (08-30-2016), Tcoat (04-09-2016)
Old 04-08-2016, 12:03 PM   #77
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Off topic but you had three turbo's on a Chevelle?
The Following 2 Users Say Thank You to NyC Zn6 For This Useful Post:
Tcoat (04-09-2016), wutsaiu (04-08-2016)
Old 04-08-2016, 12:20 PM   #78
wutsaiu
wutsaiu's Avatar
It was an experiment, I used some RX-7 parts to make the 3rd turbo only come on at higher rpm/load. It worked but the transition between 2 and 3 was slow and there was some initial boost drop. Best just to keep it simple and select the right turbo for the right application but it was fun to go to car shows and see people scratch their heads.
The Following 3 Users Say Thank You to wutsaiu For This Useful Post:
NyC Zn6 (04-08-2016), pward08 (06-19-2018), Tcoat (04-09-2016)
Old 04-08-2016, 12:35 PM   #79
NyC Zn6
NyC Zn6's Avatar
i didn't even see the car and i'm scratching my head lol....
FRS Justin (04-08-2016), wutsaiu (04-08-2016)
Old 04-08-2016, 03:29 PM   #80
bumppinKota
Drives: FRS!!!
Pics?
bumppinKota is offline   Reply With Quote
The Following User Says Thank You to bumppinKota For This Useful Post:
Tcoat (04-09-2016)
Old 04-08-2016, 07:54 PM   #81
wutsaiu
wutsaiu's Avatar
Originally Posted by bumppinKota View Post
Pics?
Not the cleanest looking engine bay but everything worked.
adjusts (04-26-2017), Luftwaffel (04-08-2016), Ralle109 (10-12-2016), rookie (04-12-2016), Tcoat (04-09-2016)
Old 04-08-2016, 10:33 PM   #82
bumppinKota
Drives: FRS!!!
That looks awesome and like trouble. My right foot feels heavier just looking at it.
Old 04-12-2016, 09:12 PM   #83
dill916
Great job as a DIY project! I hope to V8 swap my BRZ someday. did i overlook where the canbus solution was posted?
dill916 is offline   Reply With Quote
The Following User Says Thank You to dill916 For This Useful Post:
wutsaiu (04-12-2016)
Old 04-12-2016, 09:42 PM   #84
wutsaiu
wutsaiu's Avatar
Parts I used for canbus solution are in my parts list, all one one line from sparkfun.com
Arduino Uno R3, Canbus shield for arduino, and an OBD2 cable
Code I've shared to those who ask but I have not posted it.
The Following User Says Thank You to wutsaiu For This Useful Post:
maxjedi (09-27-2016)
Search this Thread:
Advanced Search
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
WTB A/T BRZ/FR-S CA Budget 21k Euan Want-To-Buy Requests 4 07-21-2015 12:50 AM
$2K Budget. What Would You Do? Skippman Electronics | Audio | NAV | Infotainment 46 02-22-2013 12:23 PM
New tires on a budget jflogerzi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-23-2013 07:32 PM
There goes my MOD'ing Budget RedRocket Scion FR-S / Toyota 86 GT86 General Forum 35 10-19-2012 09:14 AM
