Old 02-24-2016, 01:08 PM   #43
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Originally Posted by Pat View Post
LOL $225. What a joke.
Yeah!
I use one of these at $50 and it works great: http://www.summitracing.com/parts/lil-29100
Sleepless is offline   Reply With Quote
The Following User Says Thank You to Sleepless For This Useful Post:
DocWalt (02-24-2016)
Old 02-24-2016, 02:01 PM   #44
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by Sleepless View Post
Yeah!
I use one of these at $38 and it works great: http://www.summitracing.com/parts/lil-25750
Yeah, it's expensive but worth it, IMO. I'd have linked the much cheaper Lisle but I have no personal experience with it and I'm not going to suggest someone to buy something that I don't have a clue about
I think I'll pick up one of the Lisle spreaders
Old 02-24-2016, 02:10 PM   #45
strat61caster
strat61caster's Avatar
This works well on the OE, the foot nestles into the piston nicely and spins freely so you're not scratching anything up. Not sure on the AP piston size, may make for an awkward fit but could always use a piece of wood like above.
http://www.harborfreight.com/disc-br...sor-68973.html
ineedyourdiddly
Old 02-24-2016, 04:39 PM   #46
IPGJames
Drives: ...Cars...
I just ordered in the Lisle quad piston one....i love my AP Brakes...i hate installing new or close to new thickness pads...a 15 minutes job takes an hour ...hopefully the Lisle spreader works well...will find out next week
i will spend the $225 in a heartbeat if it saves me 30 minutes of my life each time i do pads (i do them frequently between track and street)...we will see how the lisle one does first
IPGJames is offline   Reply With Quote
Old 02-24-2016, 05:37 PM   #47
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
These are my thoughts as well. It was easy enough to use a clamp and block the first time. But i also was only needing to move back the pistons about 2 mils. I imagine it will be quite different when i am i changing pads that are almost toast. If the pistons had been out anymore, my clamp likely wouldnt have cleared. So at the very least i need a different shaped clamp.
But these tools look good. I guess my caliper kit is obsolete, since it mainly worked with OEM slider bolt calipers.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 02-24-2016, 06:59 PM   #48
gatorac
Chin Track Event Manager
Drives: 15 Series Blue
[ame="http://www.amazon.com/gp/product/B005GLQCKA?psc=1&redirect=true&ref_=oh_aui_detailp age_o02_s00I"]Amazon.com: Lisle 29100 Quick Quad Pad Spreader: Automotive[/ame]
I have also used a modified C clamp. Cut the fixed end off and weld on a flat piece. Works great. A little tricky on the back side because of the banjo bolt.
Jim Pomroy Chin Track Days Event Manager.
15 Series Blue in white
18 Golf R
09 Comp Yellow NC
20 Gladiator tow vehicle.
gatorac is offline   Reply With Quote
Old 02-24-2016, 07:09 PM   #49
gatorac
Here's a pic of the homemade tool.
18 Golf R
09 Comp Yellow NC
The Following 2 Users Say Thank You to gatorac For This Useful Post:
DocWalt (02-24-2016), Tenino (01-23-2017)
Old 02-25-2016, 03:05 AM   #50
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
At 4000+ ft elevation in Utah we have much less cooling capacity for the engine and the brakes. My pads last about 8 time attack competition days with the AP kit which is twice as long as the stock, but nowhere near what you're seeing. The rotors have not cracked to the edge yet though. Despite the abbreviated pad life, pedal feel and consistency are amazing.
Likewise, the brake fluid (even RT700) needs to be bled about every 8 days, sometimes sooner, due to the reduced capacity for cooling up here.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 04-02-2016, 08:10 PM   #51
ansibe
Drives: White BRZ
I'm curious about why pads would last longer with these calipers and discs.
With the same engine and tires, the energy going into the system should be about the same. The discs aren't heavier than OE, so they don't have more heat capacity. I guess it's all about airflow through the disc keeping the pads and discs cooler.
Any other ideas?
ansibe is offline   Reply With Quote
Old 04-02-2016, 08:27 PM   #52
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Pads are thicker too, so there's more mass to absorb the heat.
The BBK is a system, you have larger swept area (bigger pads and bigger rotors) meaning you get more torque from the pads which means they don't have to work as hard, there's a lot more airflow through the rotors, the pads are thicker, the calipers are bigger. Everything leads to a lot higher heat capacity meaning you're not at the ragged edge of durability like you are with the factory calipers/rotors.
Old 04-04-2016, 01:46 AM   #53
Falcon
Drives: WRB BRZ
Any other ideas?
Discs arent heavier, but its a two-piece design.
So the actual rings are thicker and heavier than the OEM part of the disks.
You are right about the Airflow.
Falcon is offline   Reply With Quote
The Following User Says Thank You to Falcon For This Useful Post:
Chris S (08-18-2017)
Old 04-05-2016, 01:48 PM   #54
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Does anyone know if the AP kit will clear Enkei RPF1 17x7.5 wheels?
Apex_BRZ is offline   Reply With Quote
Old 05-02-2018, 09:16 AM   #55
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Here are all of the Enkei RPF1 fitments that our customers have told us will clear our Sprint Kit without a wheel spacer:
  • Enkei RPF1 17x7.5 +48
  • Enkei RPF1 17x8 +35
  • Enkei RPF1 17x8 +42
  • Enkei RPF1 17x8 45
  • Enkei RPF1 (very tight fit, but works) 17x9 +35
  • Enkei RPF1 18x9.5 +38
Thanks!
JRitt is offline   Reply With Quote
Old 05-02-2018, 09:25 AM   #56
ZionsWrath
Thanks
ZionsWrath's Avatar
I have that Lisle caliper tool and it doesn't do jack shit on my AP kit. Works a treat on OEM sliding caliper. Doesn't budge the 4 piston AP.
I use a worn out pad, read old baxking plate. Stick it in the caliper and use a small pry bar to depress 2 pistons. Stick in the pad and thenn deprrws other side. Works flawless
Lisle is a decent product but not at all strong enough for the AP kit. Of it works for you i'd ask for advice and please post a video of you using it.
The Following User Says Thank You to ZionsWrath For This Useful Post:
Tristor (05-05-2018)
What does it cost you to race? (Cost of racing) rice_classic Tracking / Autocross / HPDE / Drifting 63 12-27-2013 10:54 AM
Benefit BBQ 11/16 12-3pm for our FOOD DRIVE. VTR Performance Northwest 0 11-13-2013 06:11 PM
Benefit of dark wax? Barbarian Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 07-18-2013 06:31 PM
2014 WRX benefit the 86? SanDiegoFRS Scion FR-S / Toyota 86 GT86 General Forum 22 02-18-2013 10:50 PM
