Old 09-10-2015, 02:53 PM   #15
wparsons
wparsons's Avatar
Originally Posted by chaoskaze View Post
Come on guys so much negativity. It's not gonna understeer in that setup. 😂 it will just be more track oriented.
You're joking, right? It understeers with the stock tires at all 4 corners at the limit, going wider in the rear certainly isn't going to fix that.
flickr
The Following 6 Users Say Thank You to wparsons For This Useful Post:
CSG Mike (09-10-2015), drewbot (09-11-2015), D_Thissen (09-11-2015), glamcem (09-15-2015), strat61caster (09-10-2015), zdr93523 (09-16-2015)
Old 09-10-2015, 03:01 PM   #16
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
This. Just because you can get a car to rotate doing something ham-fisted, doesn't mean it's set up for oversteer. I've done powerslides in LS400s before. Doesn't mean they need to understeer more.
jawn is offline   Reply With Quote
The Following 5 Users Say Thank You to jawn For This Useful Post:
CSG Mike (09-10-2015), Guff (09-11-2015), strat61caster (09-10-2015), TrqlessWonder (09-14-2015), wparsons (09-10-2015)
Old 09-10-2015, 03:26 PM   #17
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Locust View Post
Well if you made it a drag car...
Come on guys so much negativity. It's not gonna understeer in that setup. �� it will just be more track oriented.
Can't tell if serious, or troll.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Icanfaptothis86 (09-10-2015)
Old 09-10-2015, 03:40 PM   #18
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
How to PROPERLY select and size TIRES for PERFORMANCE
I'm. But I'm pretty sure this is related to thread topic. Stock wise 86 don't have too much power so it's good as is. 😛 But if you add some more power to it lets say 50-100 extra hp, Won't a slight staggered setup be better?
*Thread topic is how to select proper tire size for "performance"?*
Old 09-10-2015, 03:46 PM   #19
strat61caster
strat61caster's Avatar
No, most of what we experience is under steady state cornering, adding power does not magically change the handling balance of a car, the front end will still wash out at 'X' mph in 'Z' turn whether you've got 50 horsepower or 500 horsepower. While adding grip to the rear will allow for more power sooner it will only exacerbate the already existing understeer balance, again assuming the rest of the car is left as-is.
A staggered setup would be a bandaid that does not address the underlying problem, as alluded to above by @jawn oversteer on a stock 86 is caused by ham-fistedness, deliberate driver inputs, or road conditions, usually a combination of all three.
ineedyourdiddly
The Following 7 Users Say Thank You to strat61caster For This Useful Post:
chaoskaze (09-10-2015), CSG Mike (09-10-2015), D_Thissen (09-11-2015), Guff (09-11-2015), OkieSnuffBox (09-10-2015), rallysrt (09-13-2015), wparsons (09-11-2015)
Old 09-10-2015, 05:30 PM   #20
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
SOme one check my logic here. Formula 1 cars are the fastest race cars in the world. Formula 1 cars have staggered wheel set up. Therefore staggered wheels set up bc racecar.
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
The Following User Says Thank You to Icanfaptothis86 For This Useful Post:
wparsons (09-17-2015)
Old 09-10-2015, 05:38 PM   #21
juliog
juliog's Avatar
Drives: 86
I really think our car should have some with a staggered setup like 215 front 235 rear. Instead of drift all you want 215 square.
But.. but...
[ame="https://www.youtube.com/watch?v=GqUkt83gpnI"]Max Verstappen drifts F1 car at Interlagos Free practice - YouTube[/ame]
juliog is offline   Reply With Quote
The Following 5 Users Say Thank You to juliog For This Useful Post:
CSG Mike (09-10-2015), Dream20b (09-27-2015), D_Thissen (09-11-2015), jph11 (09-11-2015), wparsons (09-11-2015)
Old 09-10-2015, 05:42 PM   #22
When you have their power/weight ratio, you can too
Old 09-10-2015, 05:46 PM   #23
Icanfaptothis86
I've read taht the tire/wheel size is all set by the regulations.
If the F1 designers had their way they would prefer larger fronts to optimize balance and run larger front brakes.
Celery man
Old 09-10-2015, 05:48 PM   #24
Icanfaptothis86
Originally Posted by juliog View Post
But.. but...
There goes the tire budget
Celery man
Old 09-10-2015, 05:50 PM   #25
Icanfaptothis86
http://www.wired.com/2014/07/f1-cars...fit-consumers/
save the rubber taste the rubber
Celery man
Old 09-10-2015, 05:58 PM   #26
OkieSnuffBox
Don't be too simplistic, it's also weight distribution as well.
Old 09-10-2015, 06:16 PM   #27
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Last time I checked there is a motor sitting back there with those wider tires. Rear and mid engine setup is a whole different ball game.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 09-10-2015, 06:25 PM   #28
Icanfaptothis86
I know i was being cheeky
Celery man
Search this Thread:
Advanced Search
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 10:23 PM
Best wheel size for performance? themarvz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 12-13-2013 08:53 PM
Performance and wheel size Howardwei Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-05-2013 12:11 PM
TIRES, TIRES, TIRES! @ Pure Automotive Performance Pure Automotive Wheels and Tires 1 02-04-2013 03:32 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 09:41 PM
