Old 08-07-2018, 03:31 PM   #1149
Rich196
Drives: GT86
Originally Posted by BoostTheBrz View Post
Logs of temperature behavior
I suggest your next step is flow testing the laminovas and front rad to see if there any blockages.
Or it you have an inspection camera stick it into the map hole and check the laminova is looking okay.
Rich196 is offline   Reply With Quote
Old 08-07-2018, 06:14 PM   #1150
BoostTheBrz
Drives: BRZ tS
I was afraid that was my next step. Going to take the AC compressor out to double check wiring, but after that it looks like I should find some clear tubing!
BoostTheBrz is offline   Reply With Quote
Old 08-08-2018, 05:51 AM   #1151
Rich196
Drives: GT86
i doubt its the wiring so dont put to much effort in. I wouldnt take the compressor out youll have to re gas it.
Does you IAT temp read close to your ambient temp sensor when the car hasn't been run?
It would be easier to put a resistor in place of the temp sensor on your car and your friends. It it reads the same then you know its not the wiring.
Somewhere between 2k6 and 1k8 will give you between 20 and 30C.
Old 08-08-2018, 10:16 AM   #1152
BoostTheBrz
Drives: BRZ tS
It does read ambient on cold start, significant heat soak otherwise. Moving the AC compressor shouldn't merit a re-gas correct? I won't disconnect hoses, just move it out of the way to get under the manifold.
Old 08-08-2018, 10:48 AM   #1153
Seba
Drives: BRZ Cosworth SC MY16
Ladies and Gents,
I have just had a call from the garage and ... it's alive !!!
No errors, car drives like a devil!
https://pl-pl.facebook.com/carsportpl
Seba is offline   Reply With Quote
The Following User Says Thank You to Seba For This Useful Post:
weederr33 (08-08-2018)
Old 08-08-2018, 05:38 PM   #1154
eMCee
eMCee's Avatar
Drives: GT86
Originally Posted by Seba View Post
Ladies and Gents,
Well done, mate.
Can't wait to see some pictures and maybe a short video ^_^
I'm ready to go your way too.
Cheers.
eMCee is offline   Reply With Quote
The Following User Says Thank You to eMCee For This Useful Post:
Seba (08-09-2018)
Old 08-09-2018, 12:26 PM   #1155
Rich196
Drives: GT86
Ah okay.
Reading heat soak it okay mine does it if I sit in traffic, it will go plus 12C on ambient if ambient is 25c.
Old 08-09-2018, 01:44 PM   #1156
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Ladies and Gents,
Ugh... Seeing this makes me yearn for another Cossie kit. Alas... by the time I can afford one sometime next year, they will probably be all gone...
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
chaoskaze (08-10-2018)
Old 08-09-2018, 03:59 PM   #1157
Seba
I drove about 80 km today. So far so good. No error lights on. I didnt go fast but i could feel more torque on every gear.
The install was quite simple. Matt was very helpfull with the software. Thanks. The most difficult part was to route the cooling tubes and removing the ait from the cooling system. One think i dont like is a dcratch on the hood made by the air intake tube. I will have to do something about it. Pics and movs soon.
Old 08-09-2018, 06:23 PM   #1158
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Some cars touch the hood and some don't
you may have noticed the hood also moves a lot at speed
when static there's about 1/2" of clearance ( or should be)
but some folks take a bag of lead shot or sand and use that to spread the load of a light hammer blow to put and small dent in the cross beam to give some clearance
Matt@Cosworth is offline   Reply With Quote
Old 08-09-2018, 06:41 PM   #1159
Seba
I will try to cover and protect this place with a sheet of a sound deadening material. If I fail, I will ask a car tinsmith to use a hammer.
Old 08-11-2018, 08:35 PM   #1160
BoostTheBrz
Drives: BRZ tS
It's not hard to do it yourself. Paintless dent repair on aluminum is done between 150-200F, so take some boiling water and some rags to heat it up while hammering! No bowing on the outside of the hood at all.
Old 08-12-2018, 04:07 AM   #1161
Matt@Cosworth
Top tip
thanks
Old 08-12-2018, 04:08 AM   #1162
Matt@Cosworth
And I should say the 2nd batch of kits is now in so PM me if you are interested
we will now deal direct, post anywhere in the world
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
eMCee (08-12-2018)
Search this Thread:
Advanced Search
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
