86WORX
Old 05-04-2018, 12:06 PM   #1009
ajc209
Drives: GT86 Cosworth
Matt - whats the recommended torque for the bolts that hold the pulley on the nose of the supercharger?
Sent from my SM-G935F using Tapatalk
ajc209 is offline   Reply With Quote
Old 05-04-2018, 12:34 PM   #1010
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
12Nm chap
Matt@Cosworth is offline   Reply With Quote
Old 05-04-2018, 03:56 PM   #1011
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Matt@Cosworth View Post
Well I'll still be checking occasionally and will always try to help if I can
to answer the kit weight its 33.5 kg so 74 lb
Always good to hear!
Good thing my Stage 1.3 tune is running great with no issues at all
MS, CSCS, TSAC-F, CPT
Old 05-05-2018, 05:42 AM   #1012
Matt@Cosworth
going to the small pulley?
Old 05-05-2018, 05:59 AM   #1013
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Did you make any logs? Anything to share?
Old 05-05-2018, 06:02 AM   #1014
ajc209
Well I bought one to make sure I get one.
I'm still on the fence. If it blows a rod it would be highly inconvenient at the moment.
Matt could you perhaps explain in simplle terms how cylinder pressures vs intake runner length vs boost work. Im interested because the harrop runs 0.7bar to make same power as this kit on 0.5 bar. Obvious differences are shorter runners, bigger roots and smaller ic bricks.
Is it as simple as more pressure = more power or is there more to it regarding intake tuning, cams ect
It's would be really good if we knew the mean and standard deviation of rod strength so we could then figure out what the chances are of blowing a rod at 110bar.
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (05-05-2018)
Old 05-05-2018, 10:30 AM   #1015
Matt@Cosworth
Well something that cropped up during the initial development of our kit was the realisation that the intake runner length we wanted to have from the Tuning simulation calcs, could only just be packaged with the brick size we'd chosen
hence you may notice the manifold is a little 'bow' legged to increasie the runner length
if we'd ignored the runner length like some may have done then the engine pressure wave tune will work against the boost pressure
so you need more boost pressure to overcome the intake pressure pulse
ours does not
plus we had the advantage of cylinder pressure kit and a engine dyno and cylinder lambda measurement so I could adjust the ignition timing and fuelling to get it all spot on for each cylinder throughout the rev range
and yes we looked at using the bigger blower and found its on a bit of a knife edge whether to use the smaller R900 or R1320 as yes the bigger blower makes boost quicker so you can run it slower but it will consume more power to develop this boost
the R900 will make very similar boost pressure but has to spun faster to get there but will also consume less power to do so
plus when we designed the kit the R1320 wasn't available.....
as to rod material strength scatter we used data we already had from OEM's to define a safe limit so there's margin on that and we originally then came back a bit further on that figure to give some more margin which is where the 280bhp figure came from
the smaller pulley uses up the extra margin we specified but we still have the safety margin in the material spec
The Following 6 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (05-05-2018), botbs (05-07-2018), gtengr (05-05-2018), Rolla (05-08-2018), Teseo (05-06-2018), weederr33 (05-05-2018)
Old 05-05-2018, 10:33 AM   #1016
ajc209
ours does not
Right then pulley goes on tonight or tomorrow!
Old 05-06-2018, 02:46 PM   #1017
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
How are the transmissions holding up with this kit?
sly is offline   Reply With Quote
Old 05-06-2018, 07:00 PM   #1018
Matt@Cosworth
No issues to my knowledge
some folks have polished the stock clutch using it but that's not the norm
the auto is also OK on this kit
Old 05-08-2018, 03:24 AM   #1019
Rolla
Drives: Rolla
ours does not
Love this sort of information!
Rolla is offline   Reply With Quote
Old 05-12-2018, 03:36 PM   #1020
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
Matt@Cosworth and All,
Which oil cooler do you recommend and fits for the Cosworth 2.0 kit? I am planning to track down the road and I would like to install everything all at once.
Thanks
botbs is offline   Reply With Quote
Old 05-12-2018, 05:29 PM   #1021
weederr33
weederr33's Avatar
Thanks
The charge coolers are pretty damn effective. There's a guy here in Austin (and on here) who tracks his car without an oil cooler and hasn't had any issues. I used the OEM forester style on my FRS. The Jackson Racing dual radiator/ oil cooler would be great if you need extra capacity but don't track crazy. If that's the case, any A2O cooler will do.
The Following User Says Thank You to weederr33 For This Useful Post:
botbs (05-12-2018)
Old 05-12-2018, 11:06 PM   #1022
enigma
Drives: Asphalt 86
Thanks
I have the Perrin Oil Cooler with mine.
enigma is offline   Reply With Quote
The Following User Says Thank You to enigma For This Useful Post:
botbs (05-13-2018)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
