Old 02-28-2018, 07:18 AM   #925
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I would never run a 0w20 oil on a forced induction car. This grade is just for better consumption and lowering car emissions.
Old 02-28-2018, 07:34 AM   #926
ajc209
Drives: GT86 Cosworth
The manual states 0W20 or 5W30 for hot condition or trackdays.
Since my oil cooler doesnt let oil above 110C on track I actuality switched back to 0W20 as my oil pressure was too high with 5W30.
ajc209 is offline   Reply With Quote
The Following 2 Users Say Thank You to ajc209 For This Useful Post:
botbs (02-28-2018), weederr33 (02-28-2018)
Old 02-28-2018, 11:17 AM   #927
gahooligan
Drives: 2017 BRZ Premium
Can oil pressure be too high? I run 5w30 synthetic since installing the kit and JR combo radiator/cooler and hood vents.
Sent from my SM-N950U using Tapatalk
gahooligan is offline   Reply With Quote
Old 02-28-2018, 11:42 AM   #928
ajc209
High oil pressure mean the oil is thick and possibly not flowing as much oil because the pressure relief is working and the pump is less efficient. Thick oil doesn't lubricate as well but has a stronger film strength which is what protects the big end bearings.
Its a balance: you need thick enough oil (and thus pressure at the pump outlet) to protect the big end shells and other places where the film is under heavy load, but you need to make sure the oil is thin enough to flow and lubricate moving parts.
Dont ask me what the right amount of thick and thin is but my thoughts were that if you dont have a cooler and oil gets very hot ~140C+ then you need a thicker oil than even a W30 to maintain viscosity but as I have an oil cooler that limits oil temp to 110C the film strength of 0W20 is still good.
botbs (02-28-2018), Teseo (03-01-2018)
Old 02-28-2018, 04:11 PM   #929
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
Adrian has it right
basically you run as thin a grade as you can whilst maintaining decent film strength on the crank an cam bearings
the push these days is for 0W20 to help with fuel consumption but I wouldn't go any thinner than 5W30 most of the time
we used to run a 0W15 in the F1 engines but these didn't have to last that long (3000km)
Matt@Cosworth is offline   Reply With Quote
The Following 3 Users Say Thank You to Matt@Cosworth For This Useful Post:
botbs (03-01-2018), nikitopo (02-28-2018), Teseo (03-01-2018)
Old 02-28-2018, 04:16 PM   #930
gahooligan
Tha ks Matt. Sounds like my 5w-30 was a good choice. I like more than 3000km out of my engines... lol.
Old 02-28-2018, 04:45 PM   #931
ajc209
Well if you don't have an oil cooler like the cosworth Dev car then oil sits around 100C and can get up to 140C on track fairly quickly.
If you have a cooler even with a Tstat the trickle flow will likely pull oil temps dpwn the 80s which pushed oil pressure up a bar or so. And if the oil cooler limits max temp to 110C instead of 140C then that's about 3Bar!
So with no cooler I can see why a w30 or a w40 (what i used to run stock) would be required as pressure 0w20 is down to 3bar @ 7k when up at 140C.
In my case I found I was getting 7bar hot and higher when I was on the motorway and 85C oil temp. So I switched to a 0w20.
I did do some film strength sums a while back but w20 at 110C is better or similar to a w40 at 140C iirc.
Sent from my SM-G935F using Tapatalk
The Following User Says Thank You to ajc209 For This Useful Post:
gahooligan (02-28-2018)
Old 02-28-2018, 05:27 PM   #932
gahooligan
I need an oil pressure guage i guess. I run 203-208°f in traffic and have not seen anything over 210°f yet. BUT, its not summer yet and it hasnt seen the track. I think summer in Atlanta, GA and trackdays will require the 5w30.
Old 03-01-2018, 07:26 PM   #933
botbs
botbs's Avatar
Drives: 18 BRZ tS, 27 GRMN 86
For those of you who got the SC installed by a shop, how much did they charge you for the installation and how many hours?
Thanks!
botbs is offline   Reply With Quote
Old 03-01-2018, 07:57 PM   #934
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Thanks!
It varies by shop but, it took them about 9 hours and cost me about $1100. Then again they had never worked on a car like mine but the British guy that worked their was familiar with supercharged cars.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
botbs (03-01-2018)
Old 03-02-2018, 12:02 AM   #935
Teseo
Drives: frs
You know they rip off you, right?
Old 03-02-2018, 05:24 AM   #936
weederr33
weederr33's Avatar
Meh
Old 03-02-2018, 06:23 AM   #937
ajc209
Fensport in the UK charge £50/hour (+tax) and charge 13hours to install the kit and fine tune the Cosworth maps with the help of Matt. So £650... shame tax is 20% here....
botbs (03-02-2018), weederr33 (03-02-2018)
Old 03-02-2018, 09:36 AM   #938
Grady
Grady's Avatar
$1100 and done right, $600 and blown engine! What one is the rip off?
The Following 3 Users Say Thank You to Grady For This Useful Post:
botbs (03-02-2018), Tcoat (03-02-2018), weederr33 (03-02-2018)
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
