Old 10-06-2016, 08:04 PM   #617
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Originally Posted by Matt@Cosworth View Post
Ok just trying the shorter belt may well be enough on its own as the increased tension will pull the idler pulley away from the crank pulley
As soon as I get a chance to put the other belt on, I'll let you know how it goes!
Also... about building the engine. So if I were to keep the stock compression, and stock pistons, would it be wise to buy new pistons and piston rings? Or keep the ones I already have?
MS, CSCS, TSAC-F, CPT
Old 10-07-2016, 05:24 AM   #618
ajc209
Drives: GT86 Cosworth
If you are building the engine, why not put in new pistons and lower the comp a tad so you can run beast mode 380hp?
I have a feeling stage 3 might be release at SEMA if we are lucky.
ajc209 is offline   Reply With Quote
Old 10-07-2016, 09:28 AM   #619
weederr33
weederr33's Avatar
I only really want to sit around a reliable 300-340 hp at the crank. haha
Old 10-07-2016, 03:45 PM   #620
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
our stress analysis showed that the stock piston starts to suffer at cylinder pressures over 120Bar and this will very roughly equate to 340Bhp
if you want to rebuild it, then it'll depend on how many miles you have your current setup and as a stock piston is only about $60 each including rings and pin then it may just be best to bung a new set in there
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
weederr33 (10-07-2016)
Old 10-07-2016, 04:05 PM   #621
Icecreamtruk
Drives: Track preped NA FRS
Quick question, is this analysis proper to the Cosworth SC or would you say the pistons would suffer at that pressure regardless of chosen setup (of course, the bhp number would vary depending on turbo vs SC and even among types of SC).
Old 10-07-2016, 05:12 PM   #622
weederr33
weederr33's Avatar
My car has about 53k miles, so if I were to still want to build it near the end of next year, I'd say about 65k miles. However, for 340 bhp would it be ideal to look for a forged piston at the 12.5:1 ratio or lower it?
Old 10-08-2016, 12:09 AM   #623
weederr33
weederr33's Avatar
I just read on the UK forum something about an 11:1 ratio piston. Does anyone even make that? Or does it have to be custom made?
Old 10-08-2016, 03:55 PM   #624
Matt@Cosworth
the analysis was just based on cylinder pressure which is directly related to power but there's a number of ways to achieve that power
so yes turbo or SC 330-340bhp is the absolute limit of the stock piston
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
JDM4E (10-08-2016), weederr33 (10-08-2016)
Old 10-09-2016, 12:22 AM   #625
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
More like stock rods, they love to bend and snap. If not for the rods we could run e85 on stock comp and still hit the limits of our transmissions. 450bhp is not a problem with e85, 12.5:1 pistons and a big enough turbo.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-09-2016, 03:55 AM   #626
ajc209
Matt has already discussed their findings that much more the 250whp and you are on borrowed time with the stock rods.
Old 10-23-2016, 11:08 AM   #627
pjp
Drives: frs
Cosworth USA sales
I have been trying to buy the 1.0 - 1.3 kit
All have been put on hold from Cosworth is the story I am getting.
Does any body know the story?
Nameless said they nolonger make parts for cosworth?
Thanks
pjp is offline   Reply With Quote
The Following User Says Thank You to pjp For This Useful Post:
ajc209 (10-23-2016)
Old 10-23-2016, 12:12 PM   #628
weederr33
weederr33's Avatar
Thanks
So you're saying Nameless has admitted to no longer making parts for Cosworth? The exhaust pieces are still on their site. As are the headers on the SpeedFactory site. Although, unless there is something different about the headers or downpipe, I don't see why they would be any different than the normal Nameless parts. So long as they are 2.5" ID it should work.
Also you an find the Stage 1.0 on the Fensport and Vivid Racing sites
Old 10-24-2016, 01:42 AM   #629
pjp
Drives: frs
I have tryed all co. Listed in USA for cosworth parts
With no luck!
Have not tryed yet out of country yet !
Old 10-24-2016, 01:57 AM   #630
pjp
Drives: frs
Yes rep for nameless said they are done with
Cosworth but are selling there own pipes
But not as cool
Or is Cosworth done with nameless because of
Cracking pipes??
Search this Thread:
Advanced Search
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
