Old 08-03-2016, 04:50 PM   #533
ajc209
Drives: GT86 Cosworth
Originally Posted by weederr33 View Post
Ok, so my first real issue with the supercharger kit. The idler/ tensioner pulley that came with the kit has malfunctioned for some reason and is grinding against the engine block. Not sure why it happened, but I already emailed Cosworth about getting a replacement asap. I think this should be an easy fix, but probably shouldn't drive the car till I get a pulley.
On another note, I wonder if the Raceseng pulley's would work?
I would assume the bearing failed. Best not to drive it until fixed but it's very easy to replace.
Sent from my SM-G935F using Tapatalk
ajc209 is offline   Reply With Quote
Old 08-03-2016, 05:06 PM   #534
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Yeah, I just hope someone from Cosworth get a hold of me soon. I sent one email, but the guy is out of the office till the 8th. So I send Matt a message on here as well.
MS, CSCS, TSAC-F, CPT
Old 08-03-2016, 05:10 PM   #535
ajc209
Try going direct to cosworth USA. Call them I would.
Old 08-03-2016, 05:37 PM   #536
weederr33
weederr33's Avatar
Matt already got a hold of me! He's quick. Should have another pulley bearing sent out soon.
Old 08-03-2016, 05:44 PM   #537
ajc209
Legend
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (08-03-2016)
Old 08-03-2016, 06:05 PM   #538
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
looking at the raceseng pulley I'd agree that their tensioner should work with our kit
as it has a front fence and we found we had to add a pulley with a fence to work with our belt run otherwise the belt jumps forward and off
We'll sort mr Weederr out with a replacement parts as soon as we can
Matt@Cosworth is offline   Reply With Quote
The Following 2 Users Say Thank You to Matt@Cosworth For This Useful Post:
ajc209 (08-03-2016), weederr33 (08-03-2016)
Old 08-12-2016, 05:55 PM   #539
weederr33
weederr33's Avatar
I have to praise Cosworth for their help. So not only did I need a new tensioner pulley, as it was grinded to hell due to the bearing failing, I now need a new tensioner. So, I have that ordered. Man it is hell having to deal with something so small rendering my car useless, but at least they helped me out by practically over-nighting the parts.
So now I can officially say I had parts over-nighted from somewhere
The Following User Says Thank You to weederr33 For This Useful Post:
chaoskaze (08-29-2016)
Old 08-13-2016, 04:15 PM   #540
Matt@Cosworth
glad it got there OK chap
here's one for the collective
I'm interested in changing the stock intake over to something with a larger MAF tube so I can rescale the MAF without it topping out and to remove the inlet restriction that comes into play over 300Bhp
if there anything on the market that has a larger MAF tube to take our MAF sensor , and maintains the stock ( more or less ) exit position?
Perrin perhaps? but that's still 3" so no larger than stock?
Old 08-13-2016, 05:40 PM   #541
weederr33
weederr33's Avatar
What about the Grimmspeed? And the Perrin BigMAF isn't big enough?!
Old 08-13-2016, 05:45 PM   #542
ajc209
Grimmspeed requires no tuning so must be same ~70mm diameter.
Perrin big maf is 76mm which gives a little headroom but might not be enough for 350+hp worth of airflow.
Old 08-13-2016, 05:58 PM   #543
weederr33
weederr33's Avatar
Welp, better do what the turbo guys do, and just stick a big intake cone on the end of the supercharger pipe! hahaha
Also... is Cosworth hinting they are working on more power for our cars?!
Old 08-13-2016, 10:38 PM   #544
muckypuppy
Drives: MY13 SWP BRZ Cosworth 2.3
Skunk2 powerbox without the tapered velocity tube perhaps?? Their blurb says it tapers from 96mm ID down to 70mm ID.
http://cms.skunk2.com/id/1024/BRZFRS...Intake-System/
muckypuppy is offline   Reply With Quote
Old 08-14-2016, 05:12 AM   #545
Matt@Cosworth
that skunk box looks quite decent
shame that the exit is angled away but I might be able to make something work with that
Old 08-14-2016, 05:22 AM   #546
ajc209
Matt as you know I've been looking at intake and I'm not too far from Northampton. Give me a shout if you want to do any testing on my car or need any help. I like the look of the skunk intake too as you don't need to take the bumper off!
Search this Thread:
Advanced Search
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
