Old 08-14-2019, 12:50 AM   #1457
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Originally Posted by Koba View Post
Hi Matt,
Where can one buy a SC now, do you not sell them through Cosworth anymore?
https://www.vividracing.com/cosworth...150917862.html
sly is offline   Reply With Quote
Old 08-14-2019, 08:57 AM   #1458
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
we still have a few left £3700 + VAT ( inside europe) and delivery
drop me a pm if you're interested
Matt@Cosworth is offline   Reply With Quote
The Following User Says Thank You to Matt@Cosworth For This Useful Post:
chaoskaze (09-24-2019)
Old 09-16-2019, 06:52 AM   #1459
ajc209
Drives: GT86 Cosworth
Originally Posted by pjp View Post
Do you like your AP brakes
I was thinking about a set
Pros and cons!
Thanks Paul
Yes love them. Part or all of the reason they seized was the use a cheap bleeders after they were refurbished. The proper AP ones have a rubber seal to stop salty water setting to the threads. The company that refurbished them had a 4 year warrenty and fixed them from free as well as fitting the proper AP bleeders.
The brakes are amazing. I ahve the 355mm x 32mm discs with 6 pot calipers. Solid pedal on road or track; large enough to get away with soft street friendly pads at the track without melting/fading them.
I currently use PFC Z rated and used Cosworth streetmaster in the past.
The only real con was the initial cost but in the long run discs and pads will last longer and probably cost less to maintain.
Discs are expensive (I paid £375+tax+shipping) for a pair in sales but pads are cheaper than stock in most cases ~£80+tax. However discs will last a very long time.
Pads I did about 6 trackdays and about 5k road and the streetmasters were 50% worn and the disc less than 20%.
Stock brakes a set of Project Mu HC800+ could last two trackdays, Project mu Clubracer would last about 6 trackdays but you would need to replace disc and pads at the same time.
Sorry its late but hope that helps.
On the Cosworth front I have been running the smaller pulley for about 18 months ~6k miles and everything is running nice still. I am about to do a big service including the belt; just ordered a gates 6PK2315.
ajc209 is offline   Reply With Quote
The Following User Says Thank You to ajc209 For This Useful Post:
weederr33 (09-20-2019)
Old 09-24-2019, 12:43 AM   #1460
18BRZLtd
Drives: 2018 Subaru BRZ Limited
Anyone put the Cosworth on a 2018? Some things say it fits, some say not
18BRZLtd is offline   Reply With Quote
Old 09-24-2019, 01:19 PM   #1461
Koba
Drives: 2020 BRZ
Why wouldn't it fit? Engine is the same.
Koba is offline   Reply With Quote
Old 09-24-2019, 02:43 PM   #1462
sly
sly's Avatar
It will fit but the air filter won't fit. You have to order a different one. Also, the intake tube is too short so you need a coupling.
The Following User Says Thank You to sly For This Useful Post:
gtengr (09-26-2019)
Old 09-26-2019, 12:01 PM   #1463
18BRZLtd
The question was more about engine bay layout and if everything will fit physically in the same space
Old 09-26-2019, 12:02 PM   #1464
18BRZLtd
Ok that makes sense, thank you! What year is yours? And does it have the Cosworth in it?
Old 09-26-2019, 01:35 PM   #1465
sly
sly's Avatar
2016 and yes, I have the Cosworth supercharger.
It will fit the 2018 just fine, but you need a different air filter as they changed the air box. This also makes the metal intake tube just a little too short so you need a coupling to join it to the air box. All the information you need is in this thread.
Old 09-26-2019, 07:57 PM   #1466
gtengr
Drives: 2017 BRZ
I have one on a 2017 and it fits without issue. As sly noted the fit of the coupling to the air filter box is on the short side. It works but just needs another inch in length to feel confident it won't come apart due to vibration over time. I went with this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
gtengr is offline   Reply With Quote
Old 09-26-2019, 08:22 PM   #1467
18BRZLtd
You guys rock! I hope all remaining kits aren’t gone by the time I can get my hands on one
Old 10-08-2019, 05:17 AM   #1468
ajc209
I have noticed in the last year on my car when idling, if the AC comes on or whatever and revs dip a tad I get a squeak. It sounds like it could be a bearing or possibly belt slip squeak. Not sure but it doesn't do it when solidly idling and not when driving.
I wondered if anyone here had or has a similar issue?
Old 10-08-2019, 10:53 AM   #1469
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Back when I had my Cossie kit on my FRS, I also noticed that. I thought nothing of it since it only happened when the AC kicked on and it didn't seem to have any negative repercussions. I think it was just the AC compressor, but it could have been something else, I wasn't certain.
MS, CSCS, TSAC-F, CPT
Old 10-08-2019, 11:27 AM   #1470
sly
sly's Avatar
Mine does it when I shift hard at high revs or let the engine bog down pulling out in first. It's belt slippage, for me.
Do you have the undersized pulley? If so, you need the undersized belt. I have the undersized belt and it still slips a little. It's a result of the narrow belt OEM used. The supercharger pulls hard against it.
Search this Thread:
Advanced Search
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6002 02-01-2024 01:12 AM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4305 01-08-2024 07:54 PM
HKS Supercharger owners thread wbradley Forced Induction 1048 10-12-2023 09:03 PM
Phantom FTS Electric Supercharger Owners Thread TM Forced Induction 1206 12-15-2019 03:33 PM
Supercharger Kits! Vortech/Cosworth RallySport Direct Forced Induction 61 06-29-2015 12:26 PM
