#71 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
My question is, i wonder if this dual snorkel intake will provide higher or just as same power gains as the greddy itb's. This is including a bigger throttle body. If it provides the same gains at least, looking at cost, the revolution intake is very much worth it.
#72 | |
Drives: 2017 86 860 Special Edition
They're not even in the same league in terms of power adders... |
#73 |
#74 | |
The ITB's will net you much more mid range/overall torque, not to mention throttle response will be drastically sharper with the ITB's. Please don't take offense to this, but if you're cross shopping the two then the ITB's are not for you. |
#75 | |
Read this guy's post, he describes the same results from the guy with the itb. |
#76 |
Keep in mind, @Mockinbird87 dyno is with the stock throttle body and not the suggested bigger throttle body, which tells the revolution intake could pull more numbers.
#77 | |
Throttle response with ITB's will still be significantly better than any intake can provide. The last dyno from an ITB'd twin showed close to 180 wtq. I know its not a fair comparison but it's substantial enough. He also was reporting near 60 whp increase over stock with ITB's and a nameless header. It's hard to say without a back to back dyno comparison but it's safe to say you won't get the same type of dyno curves with just an intake and throttle body. Not to mention it's not $1500 vs $3000 ITB's require a ton of work to get them to sync/run with the engine. Then comes the hours of dyno tuning to get the most out of them. You can easily double the cost of the ITB's. Like I said if you're cross shopping an intake and ITB's, the ITB's are not for you. |
#78 |
Drives: GTS 86
Why not both? I am planning to get the SARD ITB at some point and couple it with my intake
#79 |
#80 |
Drives: 2013 frs red
I don't think we've seen an accurate dyno graph yet for itbs in terms of delta over stock.
#81 |
#82 |
#83 |
I wouldn't even consider itbs til we get results from delicious
#84 |
Drives: GTS 86
On my list I have ITB, displacement kit, Supercharger. That should give me some good reliable power
| Gruppe-S Unequal length header UEL - good power, excellent sound/quality - must SEE! | Gruppe-s | Engine, Exhaust, Bolt-Ons | 680 | 12-26-2022 10:46 PM |
| Centering caps for the TC105N from Gruppe-s | cjd | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 11-09-2021 04:57 AM |
| revolution garage rear subframe solid bushings review | mokinbird87 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-01-2015 11:09 AM |
| Gruppe-S | tahdizzle | User/Vendor/Sponsor Reviews, Feedback, Comments | 13 | 05-06-2015 12:30 PM |
| Revolution x GruppeM Intake | TwinRz | Engine, Exhaust, Transmission | 15 | 07-31-2014 08:34 PM |
