Old 10-25-2015, 03:24 PM   #43
churchx
churchx's Avatar
Drives: 2014 GT86
Common failure? What makes you think so? One thing is how reliable is or isn't some overmoded car (or it's engine), another thing how long lasts not abused and almost stock one.
The Following User Says Thank You to churchx For This Useful Post:
Ultramaroon (10-25-2015)
Old 10-25-2015, 05:12 PM   #44
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by ka-t_240 View Post
So, would you think a product like the fluidampr is something that will help with longivity on these cars as it appear the common failure is starting to be the bearings?
I am not positive, but I believe that the "common bearing failure" that you are referring to is failure of the ROD bearings, not the MAIN bearings.
For Rod bearings to fail it typically means abuse (high HP, or knocking) or oil starvation.
So a pulley solution would not change the failure rates of those two failure modes.
If we were experiencing MAIN bearing failures, then a fluid vs lightened vs OEM pulley could play a role in reducing the failures.
Old 10-25-2015, 05:22 PM   #45
ka-t_240
Ya, seems like Rod bearings is the issue. Was thinking anything you can do to help keep the bottom end happy helps, even if not directly linked?
ka-t_240 is offline   Reply With Quote
Old 10-25-2015, 11:43 PM   #46
Tekno Virus
Drives: 2015 Subaru BRZ Limited
My car does vibrate a ton when I revv it up a lot. I would definitely consider this product. The reviewer took the time to look at it in a methodical manner which makes reading it up on things a whole lot easier. I think mayber the car hits a harmonic at 5k rpm, maybe.
Tekno Virus is offline   Reply With Quote
The Following User Says Thank You to Tekno Virus For This Useful Post:
chaoskaze (10-28-2015)
Old 11-09-2015, 09:07 PM   #47
Tekno Virus
Is there an installation procedure for this product?
Old 11-19-2015, 12:50 AM   #48
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I would assume that it is no different than any other crank pulley. It would probably be a good idea to replace the retaining bolt and the o-ring with new parts at the same time. Try this thread:
Aftermarket Crank Pulley Install
The Following User Says Thank You to Black Tire For This Useful Post:
Tekno Virus (11-19-2015)
Old 11-19-2015, 08:57 PM   #49
Naco
Naco's Avatar
Drives: 2015 Steel FR-S MT
Not only a good pairing with aftermarket cranks and built engines, but also a good pairing with lightened flywheels.
On the EJ's, lightened flywheels and lightweight crank pulleys used to eat up bearings like no tomorrow.
Still a little sad that we didn't see the HP gains the F20/F22 motors got from these but then they do rev much higher.
17x9 RPF1 wrapped in 245/40 RE-71R = Mo Low Required
Naco is offline   Reply With Quote
The Following User Says Thank You to Naco For This Useful Post:
CSG Mike (11-19-2015)
Old 11-20-2015, 12:35 AM   #50
Mikeez
Engineering Student
Drives: Scion FR-S 2015
One thing I like to point out in these discussions about "Can a lightened pulley provide more HP":
Can HP be measured at a constant RPM? - YES.
In fact the original term "Brake Horse Power" was used because the oldest method of measuring HP was to hold the engine/motor at constant RPM and apply the "Brake" (yes an actual BRAKE).
When the engine begins to drop RPM (and the throttle cannot be opened any further), the power applied to the brake was determined and that was the 'BHP' for that particular RPM.
Repeat the test at all RPMs and you get the typical curves that we are used to seeing from Dyno runs.
SO IF classical Horsepower is measured at constant RPM, then WHAT does rotational mass have to do with HP?
Answer - NOTHING.
(Since rotational mass only resists CHANGES in RPM.)
This is correct.
I also want to add that in any physics questions, pulley weight is neglected.
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Perrin Lightweight Crank Pulley (RED) JarredH Canada Classifieds 1 08-12-2015 08:05 AM
Lightweight crank pulley Vlady Engine, Exhaust, Transmission 112 01-09-2014 10:28 PM
Lightweight Crank Pulley Vlady Want-To-Buy Requests 3 01-02-2014 12:31 PM
Perrin Lightweight Crank Pulley protpibe Engine, Exhaust, Bolt-Ons 4 12-04-2013 08:46 PM
FS: AgencyPower Lightweight Crank Pulley Firestorm_86 Engine, Exhaust, Bolt-Ons 0 11-22-2013 05:13 PM
