Old 09-03-2015, 12:27 AM   #1
retrofit
Drives: Toyota 86
A daily drive build
This is my current build:
Harrop supercharger kit
-using standard 95mm pulley
-BMC air filter
Tomei 4-2-1 equal length headers (Jet-Hot ceramic coating)
SME 2.5" overpipe (Jet-Hot ceramic coating)
SME 2.5" frontpipe (with Hi Flow cat)
Invidia Q300 cat back exhaust
Valenti crystal full red tail lights
Edit: dyno sheet attached
retrofit is offline   Reply With Quote
The Following 3 Users Say Thank You to retrofit For This Useful Post:
CxG (05-24-2016), NWFRS (10-14-2015), raven1231 (10-14-2015)
Old 09-03-2015, 01:08 AM   #2
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
PICTURES!!!
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
Old 09-03-2015, 03:20 AM   #3
retrofit
Drives: Toyota 86
Originally Posted by weederr33 View Post
PICTURES!!!
Will do
Originally Posted by retrofit View Post
The Tomei EL headers did catch my eye. As the Invidia catted FP are a bit restrictive I'm now leaning towards the SME catted FP.
Thanks to everyone for providing their input. Feel free to continue the discussion in my build thread: http://www.ft86club.com/forums/showthread.php?t=94283
Continuing on from http://www.ft86club.com/forums/showt...93#post2378493
These are the exhaust parts I'm currently considering:
Tomei equal length headers ceramic coated
SME 2.5" catted front pipe
Invidia Q300 2.5" cat back
SME 2.5" over pipe
http://www.tomeiusa.com/_2003web-cat...brz_equal.html
Headers:
The Tomei Expreme headers specifications above show 2nd juncture - joint pipe of 60.5mm (2.38"). Would this be the inner diameter or outer diameter of the pipe?
Front pipe:
inner diameter of 63.5mm (2.5")
Cat back:
inner diameter of 59.9mm (2.36")
Over pipe:
SME 2.5" over pipe
Can anyone see any issues with my 2.5" exhaust setup above if I need to add more boost in the future (i.e. smaller pulley on the Harrop kit)?
What differences in power and torque are there between a 2.5" and 3" header back exhaust setup?
Old 09-03-2015, 03:37 AM   #4
weederr33
weederr33's Avatar
You really only need to change out the headers. The rest only yields minimal gains for the money. I'd say, get some headers (depending on whether you want torque, mid range, or power up top), and a catback of your choice based on sound. I.e. Q300.
Old 09-03-2015, 03:42 AM   #5
350matt
Drives: toyota mr2/ Toyota GT86
2.5" will limit the ultimate amount of power and reduce power over a 3" system by about 3-7% ( depending on what your final power target is)
however 3" is a LOT louder
what BHP target are you shooting for?
350matt is offline   Reply With Quote
Old 09-03-2015, 03:51 AM   #6
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
If you're going catback, I can't say enough good things about the Invidia N1. People think it's loud and droney, until you hear it in person. Given, I don't have headers (yet), but this thing sounds mean af and it's not loud at all, and more aggressive than the Q300
Rifle is offline   Reply With Quote
Old 09-03-2015, 03:56 AM   #7
retrofit
Drives: Toyota 86
Thanks, will keep that in mind
If it's significantly louder then I won't bother going higher than 2.5"
I'm happy with a BHP increase of 50% over stock but looking to get up to 75% in the future. A lot will depend on the cost to get there.
I'm aiming to attract as little attention as a stock car so an N1 might not suit my needs
Old 09-03-2015, 05:29 AM   #8
retrofit
Drives: Toyota 86
How about an aftermarket air filter or even a replacement for the stock airbox?
More searching to do when I get home from work.
Old 09-03-2015, 07:42 AM   #9
weederr33
weederr33's Avatar
You can't go wrong with any of the drop ins. They all vary by 1-3 hp. Depends who you have an affinity to. For example, I like Perrin or Cosworth, so I'd go with them. But Apexi or K&N are no better or worse. Just pick whichever you like the most! Also! Take a look at my build for some inspiration
Old 09-03-2015, 12:17 PM   #10
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
http://www.ft86club.com/forums/showthread.php?t=92961
Try looking at this thread, what I would do for each category...
Performance;
1. Drop in
2. Headers with OFT
3. catback
4. catless maybe resinated or free'r flowing cat.
Looks/suspension;
1-3. tires.
4.you'd be surprised how much a difference with stock wheels what 20mm spacers in front and 25mm in rear can do for looks.
5. lowering springs
6. Camber bolts and/or camber plates
everything is relatively inexpensive. Would definately love to see pictures, and cant wait to see what path you go down.
Instagram: trevor.parque
Old 09-03-2015, 12:34 PM   #11
350matt
the stock airbox is actually pretty good up to 300Bhp, providing the filter is replaced as thats quite restrictive
sounds like you're looking for a positive displacement supercharger to me
and the market has several offerings these days
The Following User Says Thank You to 350matt For This Useful Post:
retrofit (09-07-2015)
Old 09-07-2015, 01:25 AM   #12
retrofit
Drives: Toyota 86
PICTURES!!!
Sorry about the photo quality.
I'm using a phone camera and suck at photography
Old 09-07-2015, 02:27 AM   #13
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I have Tomei UEL header with the Q300 Catback on my car and it's loud on cold start, but once it's up to temp it's actually very civil sounding at low revs and there is zero drone or or obnoxiousness to the note.
Wise is offline   Reply With Quote
The Following User Says Thank You to Wise For This Useful Post:
Old 09-08-2015, 04:52 AM   #14
retrofit
Drives: Toyota 86
I might not bother with an over pipe and only go with a high-flow catted front pipe.
In the example below (for a supercharged setup) there was no gain changing to a 63mm overpipe (assuming it was from a stock over pipe):
Originally Posted by Ryan86 View Post
I recently fitted 63mm overpipe for the Sprintex SC with already having Borla header and full decat exhaust, I can't honestly say the overpipe made any difference, even on dyno I recorded same KW prior to fitting overpipe.
According to the following advice the front pipe should be replaced before the over pipe:
Originally Posted by wparsons View Post
The overpipe isn't as much of a restriction as the front pipe, if you're only going to replace one part replace the front pipe.
Would you all agree there are no gains or very minimal gains to be had with an overpipe?
build thread, forced induction, harrop, supercharger
HKS GT Supercharger v2 |BRZ DD & Track craigpitts7 Member's Car Journals 28 02-28-2017 11:08 PM
Do you have daily drive car? oso_25 Other Vehicles & General Automotive Discussions 51 05-11-2015 04:52 PM
FRS slow daily/ drift build SciOnDrifTtSlIdeR Member's Car Journals 7 04-19-2015 02:50 AM
Longest daily drive? cuddefred Scion FR-S / Toyota 86 GT86 General Forum 6 05-22-2013 01:00 AM
