#43 | |
Drives: Toyota GT86 Coupe Red (UK)
How sure are we that there is no ferrous metals in the coolant circuit? Even the pump shaft, thermostat housing etc. It's true that water has a higher specific heat capacity, around 12% or so at coolant operating temps. Resulting in 12% less flow rate, less wear on the pump etc. Even with the higher boiling point of glycols water is still better. Water does expand more and it vapourizes more easily but that would only be an issue if you overheated (steam out radiator cap or burst pipping/joints for example). Glycols are actually corrosion inducers as they form acids in water. So coolant needs more rust inhibitors. All that said, we can all do our research on the tinterweb but are you going to trust that or are you going to trust the car manufacturers who spend millions researching these things and proscribe a type of coolant for your car? Sure if you are 100% certain your car will never be idle in temperatures close or below zero, distilled water and a rust inhibitor would be fine. Considering the damage that might be caused should you drive to a friend further north and forget.... Or you live in California and go skiing up the mountains and forget... I don't think it's worth it. I know in my climate (Ireland) -5*C is about the average coldest winter morning, however in the past 10 years isolated lows of -31*C have been recorded near by and -14*C recorded where I live. So, a quick reference chart tells me I would need at least a 40% solution of glycol with 50% being advisable. Toyota proscribe 50% solution (in Europe anyway) to cater for all the climates in that region. Including driving in the high mountains. 50% freezes at -34*C. If you live in Northern russia I have no idea what they use, except for leaving a fire lit under it or a block heater.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
#44 |
Drives: 2014 GT86
Car manufacturer don't want to deal with idiots saving on coolant / filling with water, and then forgetting it and driving/parking far north in winter. But if it's always warm climate only, and one trusts own memory, it should be safe to drive & cool engine on just water, all year round.
Your mentioned Ireland climate of course is not of such, to drive on water all-year. But eg. California? In nothern Russia, "far east"/"far north" as they call, in soviet times, they did it in way (for big trucks) - to never stop engine from autumn till end of spring, lol .
| The Following User Says Thank You to churchx For This Useful Post: | strat61caster (07-04-2017) |
#45 | |
I was never good at material science so I won't go into corrosion hypotheses bullshitting. But Subaru coolant hasn't managed to break common knowledge on cooling fluids and water is incredibly tough to beat without spending a lot of money. |
| Help !! Wrong Anti freeze D': | UchihaFanBoy | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 02-11-2015 12:34 AM |
| Heaviest Shift Knob that won't burn / freeze your hand? | bren5279 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 09-28-2014 10:18 PM |
| Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? | mike the snake | Forced Induction | 8 | 04-01-2014 06:56 PM |
| FS: Eibach Anti Roll Kit (From Pro-Plus Kit) | Batman | Brakes, Suspension, Chassis | 1 | 03-31-2014 04:02 PM |
| BRZ Navigation Freeze/Crash | TM | Electronics | Audio | NAV | Infotainment | 3 | 06-08-2013 01:29 PM |
