Old 11-12-2015, 02:17 PM   #29
jarviz
jarviz's Avatar
Drives: Raven FRS MT
Originally Posted by ToySub1946 View Post
I have a 2015 FRS, purchased new, now with 21,330 miles on it.
Noticed coolant somewhat low when it was new...after some miles driven...radiator was full, but overflow bottle showing no coolant.
Finally topped it off to low coolant level when odometer showed about 17,000 miles. {I don't allow the Dealership to add any fluids during oil and filter changes}
I used Best available Prestone brand, as FRS coolant was same color (green)...and I see no point in buying Prestone coolant which is premixed, as full strength coolant price is more product for the dollar.
I'd guess these cars, when new, have some bubbles in the cooling system, so they can't get them totally full at the factory.
I've found no leaks from my car, so no worries...just a normal situation.
Bottom line: I'd drive the car a while before worrying about it's coolant level...see if it gets any lower...then add as necessary. As long as you check coolant level in radiator itself, [certainly with car cold], if radiator itself is totally full, no real worries for a while.
Any update on how the car's handling the new coolant? I want to top off my coolant but don't feel like spending $34 for OEM coolant, which I can't use all of anyways.
jarviz is offline   Reply With Quote
Old 11-12-2015, 06:25 PM   #30
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
jarviz,
My FRS now has almost 23, 000 miles.
I don't think it's lost any more coolant, since I topped it off around 17,000 miles.
Recently under the car, with the front aluminum skid plate off (damaged it, sliced it open on a big rock, dirt road), I noticed a little trace of dried (greenish) coolant near and on the front of left cylinder head...though it does not seem to have come from the water pump (no green on or under pump itself), which is also near, above that area. Not gonna worry about it though, as it might be normal seepage from when engine was new.
Note: Bought the car new. Drove it very hard, high revs, on dirt roads, day after I bought the car. Paid no attention to any sort of babying the engine when it had under 500 miles on the odometer....as was recommended. Yet no problems with oil burning so far...between 7500 mile oil changes.
ToySub1946 is offline   Reply With Quote
Old 06-28-2017, 11:19 AM   #31
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
After reading this post, I went to check my level. And I'm hella below the Low level. I won't be able to buy the coolant till this weekend and I daily my car. Will my car survive? Or any harm than could happen?Name:  20170627_193216.jpg
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 06-28-2017, 11:53 AM   #32
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Check if any level below rad cap. Watch temp gauge and you should be ok...Why can't you buy any before the weekend ??? I would get some and add just to be safe.
22R
22R is offline   Reply With Quote
Old 06-28-2017, 11:54 AM   #33
Exrald
Exrald's Avatar
22R
I work 9-5. And they close at 6. Traffic won't get me there on time...
The temperature seems to be ok. It's the usual, middle notch of the gauge. Praise God I caught it in time.
2013 Scion FRS
2022 Toyota GR86
Old 06-28-2017, 02:31 PM   #34
Feelings
Feelings's Avatar
Drives: '15 Dark Grey BRZ
It's just an expansion/overflow tank. If the engine is COLD and you can still see coolant, you're fine. Bring your engine up to temp and have another look, it'll probably be close to the full mark.
In the winter when everything is cold I can barely see coolant in that overflow and I haven't worried about it. Not worth the $ to buy premix for nothing.
Feelings is offline   Reply With Quote
The Following 3 Users Say Thank You to Feelings For This Useful Post:
strat61caster (06-28-2017), Tcoat (06-28-2017), Ultramaroon (06-28-2017)
Old 06-28-2017, 02:39 PM   #35
This^
If temp gauge shows OK then don't sweat it. Because the expansion tank is low it does not mean that your cooling system is low. For the little it is down you can also just add some distilled water. Coolant is mostly water and that is what evaporates not the solids that have been added to it.
Old 06-28-2017, 02:40 PM   #36
Exrald
Exrald's Avatar
Thank you! I've been stressing about it since yesterday. I'm about to do some runs this Saturday, so I don't want to overheat my car.
2013 Scion FRS
2022 Toyota GR86
Old 06-28-2017, 05:04 PM   #37
strat61caster
strat61caster's Avatar
Buy a gallon of distilled water at any grocery store (gas stations have them too but usually overpriced), throw a cup of water in there when it's cold to bring it up over 'minimum' and check it again after it's nice and hot, should be much nearer the top. Toss it in the back seat and maybe add a little bit of water if it drops below minimum again, repeat until you're happy.
You don't need to spend the extra $30 on antifreeze, your car will likely never be in freezing conditions anyway. You and I could probably run it on straight water year round.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
BirdTRD (06-28-2017), Exrald (06-28-2017), Ultramaroon (06-28-2017)
Old 06-28-2017, 10:23 PM   #38
Ultramaroon
fabulous
Ultramaroon's Avatar
I guess I'm the lone dissenter.
totaled
strat61caster (06-29-2017)
Old 06-28-2017, 11:47 PM   #39
Exrald
Exrald's Avatar
I wish I saw this sooner. I got the coolant for $26. Not bad as I expected lol. But I filled it up to full on cold engine.
2013 Scion FRS
2022 Toyota GR86
Old 06-29-2017, 10:25 AM   #40
strat61caster
Meh, some may come out the top and life will go on.
ineedyourdiddly
Ultramaroon (07-03-2017)
Old 07-03-2017, 04:12 AM   #41
paulca
Drives: Toyota GT86 Coupe Red (UK)
Just remember it's not just antifreeze. It's got lots of other good stuff in it. For a start it's boiling temp is around 118*C, not 100*C. It has rust inhibitors and other additives which modern engines require. Filling it with water will work fine, but it might affect the longevity of the engine.
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
Old 07-03-2017, 05:51 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
rust inhibitors might be needed more if there are electrically dissimilar metals in cooling loop, but are there? Block - alu, rad - alu, not copper, as once, when raw copper was cheaper, and plastic/rubber here & there.
And water is best coolant specific heat capacity wise (some unreallistic ones for eg. operating temp/price/poison properties aside), all those additives just reduce it's efficiency, so if not needed due eg. climate car is driven at, then imho should be perfectly fine running with plain distilled water.
The Following User Says Thank You to churchx For This Useful Post:
strat61caster (07-03-2017)
Search this Thread:
Advanced Search
Help !! Wrong Anti freeze D': UchihaFanBoy Scion FR-S / Toyota 86 GT86 General Forum 27 02-11-2015 12:34 AM
Heaviest Shift Knob that won't burn / freeze your hand? bren5279 Cosmetic Modification (Interior/Exterior/Lighting) 13 09-28-2014 10:18 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
FS: Eibach Anti Roll Kit (From Pro-Plus Kit) Batman Brakes, Suspension, Chassis 1 03-31-2014 04:02 PM
BRZ Navigation Freeze/Crash TM Electronics | Audio | NAV | Infotainment 3 06-08-2013 01:29 PM
