Old 11-16-2016, 09:55 AM   #295
LS1M
Drives: 2015 BRZ
I have the high boost pulley with Delicious Flash & Go tuning, E85, flex fuel. Do I have to do anything to go back to the standard pulley, or can I just swap it out with no other changes? I'm fixing to take a trip where I expect to see zero E85 stations.
Thanks
-Mark
LS1M is offline   Reply With Quote
Old 11-16-2016, 02:31 PM   #296
Thanks
-Mark
You can just swap back to the normal pulley with zero issues.
It's approximately the equivalent of traveling to high elevation with the HBP for you, since you have the DT FNG.
LS1M (11-16-2016)
Old 11-22-2016, 08:44 AM   #297
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
I noticed a 72mm aftermarket throttle body is now available claiming some pretty big gains in airflow capacity. Would the high boost system benefit with this?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 11-22-2016, 01:23 PM   #298
Possibly, but I do not believe it has been extensively tested.
The CSG BRZ has had a large throttle body for years, but hasn't had A/B testing done with it.
Old 12-06-2016, 08:42 AM   #299
Deep Six
Deep Six's Avatar
Any possibility of pairing a slightly smaller pulley and belt to move the boost curve further down the rev band. I would consider trading rev limits for a higher boost/rpm ratio just for reliability purposes in a primarily track driven car. I have James (HRI) near by to customize the tune.
I finally got the car back on the track this weekend and the difference is startling. It was cool weather but a crowded event so I'm going to need to overlay data to see segment differentials. Using a different gear all over the track including 6th for the first time. Oil temps never budged from 230 and there were zero issues whatsoever.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
CSG Mike (12-06-2016)
Old 12-06-2016, 12:39 PM   #300
Which pulley are you on now? 100mm (HBP)?
Old 12-06-2016, 02:17 PM   #301
Deep Six
Deep Six's Avatar
Yes With built motor and fuel upgrades.
[SIGPIC][/SIGPIC]
Old 04-15-2020, 05:48 PM   #302
Saelee5
Safe to run 91 when swapping to standard pulley while still on HBP tune?
Saelee5 is offline   Reply With Quote
Old 04-15-2020, 07:21 PM   #303
You'd have to ask your tuner.
Old 03-06-2021, 09:56 PM   #304
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
so i cant find the answer anywhere, but you cant run this on the c38 right because it is internally geared differently right? the power is right where id want but the idea of running the SC at like 95%+ on a c30 freaks me out
Breadman is offline   Reply With Quote
Old 03-08-2021, 05:02 PM   #305
You can but you'll get more flow than a C30.
Old 03-08-2021, 05:04 PM   #306
Breadman
Breadman's Avatar
so i guess nothing really exists to get the same power level with the c38?
Old 03-08-2021, 05:36 PM   #307
With the standard pulley, they make about the same power.
Old 03-08-2021, 05:41 PM   #308
Breadman
Breadman's Avatar
sorry i explained that poorly. im looking to make 330-350 wheel on e85 which the c30 with highboost is slightly over. But seeing as the highboost pully spins it at 95% the rating it freaks me out. I was looking for a pulley that could make that with the c38 and i wanted to double check it didnt worked. looks like ill be ordering the c30 then i guess
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
