Old 01-24-2016, 11:54 PM   #281
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
E100 is very, very difficult to start a car on. E98 is common as a race fuel though.
I do, however, have access to lab grade E100, and it smells literally like corn.
E85 is difficult enough to cold start right now, I can only imagine what e100 would be like. I wish e98 was available besides by the drum.
0351USMC is offline   Reply With Quote
Old 01-28-2016, 10:18 AM   #282
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
As much as I have enjoyed my tuned, bolt on set up, both on the street and many track days, I was finally ready for some boost. For my application I decided the Jackson Racing high boost setup was the ideal choice.
Special thanks to the following for making this happen:
CSG Mike for a great package deal and bailing me out with an emergency delivery of a Jackson Racing oil cooler when we discovered the Robi Spec Combo needed to be replaced.
Rev Works in Orlando for a flawless install
HRI Tuning (James) for custom dyno tuning the car to my specific requests. Absolutely perfect street manners and great power numbers from a conservative by choice tune.
The powertrain mods at this point are:
Jackson Racing High boost kit + oil cooler
ID 1000 injectors
FB Walbro 485 fuel pump
FB Radiator
HKS catless header and front pipe
Ultimate Racing 3" cat back
In two weeks of post install driving I am really pleased with the fact that the car drives perfectly but with just so much more power. The only thing I am going to change is to raise the rev limiter back up to 7400 because the 7K ceiling is a nuisance.
I will update this post with pictures and more perspective when I have a little more time but for now
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
The Following 3 Users Say Thank You to Deep Six For This Useful Post:
CSG Mike (01-28-2016), juliog (01-29-2016), new2subaru (01-28-2016)
Old 01-29-2016, 12:11 AM   #283
juliog
juliog's Avatar
Drives: 86
The Jackson Racing supercharger looks very nice
What's the red box by the battery?
juliog is offline   Reply With Quote
Old 01-30-2016, 09:05 PM   #284
Deep Six
Deep Six's Avatar
It's a vented catch can.
[SIGPIC][/SIGPIC]
The Following User Says Thank You to Deep Six For This Useful Post:
juliog (01-30-2016)
Old 01-30-2016, 10:11 PM   #285
ADebelius
Taking Corners
Drives: 2014 FR-S Whiteout Monogram
Since I only have access to 91 octane, would be possible to install the HBP to increase my low end boost and then also install a wastegate to vent at 9 PSI so that I don't overboost for my gas on the high end?
I mean I understand I'd have to still get retuned as the boost curve would shift, but would this work?
ADebelius is offline   Reply With Quote
Old 01-30-2016, 11:10 PM   #286
Absolutely.
Old 03-05-2016, 10:25 AM   #287
LS1M
Drives: 2015 BRZ
I finally got my high-boost pulley installed Running the JRSC with HBP, Delicious flex fuel & DW 700cc injectors, and completely stock exhaust. I'd like to thank @CSG Mike and Zach @DeliciousTuning for all their advice & help. Car really MOVES now! Logged about 11psi at 7000RPM and 14.5 at 7700. Really moves the power band down a bit so I almost feel like I have some torque. And it's not loud at all. With the stock header & cats, you really can't tell anything is different. The only clue that I've got anything is my Jackson Racking license plate
Got a DW300c fuel pump on the way but the stocker seems to handle the load fine for now. And I'm only at 50% ethanol with my first fillup, so I'll probably see a bit more umph down the road...
Mike & Zach!
-Mark
LS1M is offline   Reply With Quote
The Following 2 Users Say Thank You to LS1M For This Useful Post:
dj2020 (03-05-2016), menikmati (03-05-2016)
Old 04-02-2016, 05:38 PM   #288
BRZ'13
BRZ'13's Avatar
Drives: subaru
HBP has arrived. Waiting on fuel pump now. Should have it tuned and ready to go by the 15th! Will post dyno graph. Expecting at least 285whp on 94 & 12psi
BRZ'13 is offline   Reply With Quote
The Following User Says Thank You to BRZ'13 For This Useful Post:
CSG Mike (04-03-2016)
Old 04-30-2016, 08:26 PM   #289
BRZ'13
BRZ'13's Avatar
Drives: subaru
Finished tuning the brz today. Made 270whp on the HBP running 94. Dyno graph to come!
For comparisons:
Car made 255whp on 9psi on 94
175whp with EL pt-tuning headers (pt-tuning claims 200whp on 93 lol) and nameless downpipe&overpipe
150whp baseline bone stock on 94
Dyno is super low reading compared to the other results iv seen (hence 150whp baseline on 94)
Gained alot throughout the mid range (15-30whp/tq) but higher end was knock limited due to fuel. Was going to run E90 next to get 320whp but i am going to ditch the FA20 and do an LS swap instead. Far more reliable with more room to grow.
Old 04-30-2016, 10:30 PM   #290
VitViper
Drives: '15 FRS
For comparisons:
Your results are pretty realistic... our car dynos 150 bone stock on our Dynapack here as well... the only cars even close to 200whp with bolt ons to date have been E85 ones (~190-193whp).
VitViper is offline   Reply With Quote
The Following User Says Thank You to VitViper For This Useful Post:
Jmonty (05-01-2016)
Old 04-30-2016, 11:28 PM   #291
BRZ'13
BRZ'13's Avatar
Drives: subaru
Yes its on a dynapack! But i think on any of the dynojets etc i can clear 300whp no problem. Just didnt want people thinking the HBP is not worth it. Gained way more in the mid range then i thought
CSG Mike (05-01-2016)
Old 07-23-2016, 08:41 AM   #292
whatevervu
Drives: '15 FRS
I just recently installed Jackson's HBP, tuned by Bill yesterday at Delicious Tuning:
e60: 293 WHP on mustang Dyno.
I can post the dyno sheet later today when I get a chance if anyone is interested. I'm not sure what he issue was but according to Bill it seemed as if I was maxing out around 10.5 psi.
whatevervu is offline   Reply With Quote
Old 08-13-2016, 07:11 AM   #293
whatevervu
Drives: '15 FRS
To followup, after contacting Jackson Racing. They told me that the lower psi is due to me running c38 supercharger. If I was on the c30, it would be around 12 psi which is what the c30 would need to make the same power as the c38 on 10.5 that I was maxing out at.
The Following User Says Thank You to whatevervu For This Useful Post:
kevin.nguyen (11-17-2016)
Old 10-29-2016, 04:10 AM   #294
Dru670
Drives: 2016 Scion FR-S
Originally Posted by Parikh1234 View Post
Going high boost in a few weeks with Mike @ moto-east. I just drove the car through 130 degree temps on 91 through death valley a few weeks ago. Altitude went from 12,000 ft to sea level on my trip. No issues at all, Mike's tune was awesome. Car is on JRSC with stock exhaust now, just headers.
Mods to be done next week or the week after:
Full Amuse system (mid, over and exhaust)
Upgraded pulley
Flex Fuel
Injectors
Pump
Ill post the dyno as soon as Mike is done with it. We are going to run 93 as much as possible (I cant find e85 every where in NJ / NYC). But he said the kit should be good to switch back and forth. He knows I drive the car like I stole it.
If I do ship the car out west. Where we will have extreme altitude / temps, I will have mike do a retune.
have you done a dyno after you first installed your jrsc kit? if so, what was the results
Dru670 is offline   Reply With Quote
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
