#239 | |
No rice, no life
Drives: 2013 Asphalt FR-S
As for getting 280 with a catless header, the Type A header you mentioned is equal length, which gives better high rpm gains while uel gives better low end. Having a full performance exhaust will also make a big difference. I don't think 280 is unreasonable. Hey I'm the guy who originally asked the question lol. My setup would be a catted header with an otherwise stock exhaust. I also have a Tomei 60S catback that I may throw on, but it's not like catbacks make a difference on this car other than noise. It's my daily and I do a lot of highway miles, so I would go crazy if it was basically straightpiped.
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
#240 |
Drives: 2014 Monogram FR-S Whiteout
So I was going to PM CSG directly but thought since this has not been asked on either of the JR threads I would go ahead and do it here in case someone else was thinking of doing this or hasn't but might like the idea. The stock pulley at sea level and with ideal boost weather makes 9.5 psi from what I have seen. The factory tune is calibrated around this and on 91 gas. I live WELL above the grapevine at 5000 feet and my place of duty is at 5200 feet. I anticipate I will make about 7 psi with the stock pulley at this elevation but I could be wrong as I do not have the kit YET.
What I am contemplating is installing the HBP and running it on the CARB tune at the high elevation I live. I understand it is a risk to my blower if I over-rev (but a risk N/A either way) and a risk to my engine on the CARB tune if I over boost which could be possible. What I would like to see is on the best day what kind of boost will I get and if I will break 9 psi at 7400 rpm or if I won't even hit it. I would approach this the safest way I could imagine with a boost gauge and slowly revving up to redline under load. I would stop accelerating at 8.5 psi and see where I am vs rpm then the answer would be clear. My question is would you (CSG and/or JR) condone this or is it simply too risky; or have I completely missed some detail and I am completely wrong in my reasoning here? The goal is to have the SC perform the way it does for people that get to enjoy it at lower altitude where I will be living for the next few years. I am fully willing to swap pulleys for any travel I will be doing. I am not willing to lower my redline so if I hit 9 psi by 7200 rpm I will not go through with this idea. |
#241 | |
Drives: frs
#242 | |
Drives: WRB JR BRZED
#243 | |
Drives: WRB Limited BRZ
And I'm sure a catback does help maybe not much but hey 2.5" helps with the back pressure although turbos seem to benefit a lot more from that. Now I'm assuming you're keeping your exhaust stock because of emissions right? I would honestly strongly recommend a catless header I don't know how strict they are in NJ but they can't be nowhere near as bad as CA, I thought Middle TN was up tight about emissions but actually they're pretty chill. And honestly if you have the stock catted FP and OP wouldn't that be all they check for, who's going to actually take that metal cover under our header and actually check? Alright I'm getting off topic now but I'm sure a catless header would get us in the 300whp range if anything and since we have an abundance of 93 Oct here in the south I think we'll be good! Since you're near by you should come to TN and hit up Tail of the Dragon(; |
#244 | |
#245 |
Drives: frs
#246 | |
I am very aware of the capability of Delicious Tuning's FNG tuning for this platform and I will run it for when I upgrade to Flex Fuel. However that is not what I am trying to accomplish here. Where I am stationed currently the Smog laws are quite strict. In some aspects worse than California and in some aspects better. What I am trying to do is exactly what I stated and I am wondering if it is worth carrying out the experiment as this could benefit the whole community if successful. If you don't mind me asking, if you have the JRSC kit, what peak boost are you hitting at what altitude? |
#247 | |
I answered my own question by going through the owners thread again. Looks like the losses aren't as significant as I had expected at altitude and I was completely wrong. It is not worth pursuing this theory. The altitude in the quote is about 6000 feet. Looks like I will be completely stock on the CARB tune until I move somewhere without extreme smog laws.
#248 | |
#249 | |
Yes I am in Utah and I am very confident the JRSC will pass emissions on the CARB tune which is why I am getting it. Though I doubt my car would pass emissions in my county with the mods I will be doing when I go to E85 because I will be deleting the cat in the header with a full 2.5 inch exhaust. So I guess I will just live with it and enjoy higher boost whenever I make the drive down to Cali to see my family. If you have some insight on smog laws for Davis county and I missed something you should PM me since this is getting a little off topic. I would love to be able to run E85 with DT's BTFF kit, HBP, and the full exhaust. |
#250 |
Drives: 2013 FRS / 2013 427 Vert
Which gear is typically used for dyno pulls?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
#251 |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
For a true 1:1 on a dynojet, 5th is the most correct gear on standard USDM gearsets with an MT. But for tuning purposes we'll frequently use 4th to fine tune things, since it is a shorter duration and easier on the car. Then do a 5th gear run to finish things off and make sure no additional knock takes place under the longer duration load. That'll also give the most accurate number when comparing to other dynos/locations.
| The Following User Says Thank You to Xero-Limit For This Useful Post: | Bykov (01-17-2016) |
#252 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Just been poking around doing research on different FI systems and this caught my eye. I'm wondering, is it possible to add a boost controller to this system? So I can just go straight for the HBP with all supporting mods, but turn it down until I feel I'm ready. Basically giving myself some growing room without having to go back to the tuner or swapping the pulleys myself.
Again, its a pretty newb question. I searched around but didnt find anything about adding a controller to SC systems. (Probably cause they dont usually put out enough boost to warrant a controller I assume). |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 01:59 PM |
| Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 10:26 AM |
| Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 08:51 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
