86WORX
Old 12-25-2015, 05:49 PM   #225
Originally Posted by Sleepless View Post
When will the CSG site have the upgrade kits you mentioned earlier?
Feel free to PM if you want stuff earlier.
Old 12-29-2015, 12:57 AM   #226
BRZ'13
BRZ'13's Avatar
Drives: subaru
Anyone have any pump gas results yet on the hbp? Im at 255whp and want more. I was thinking of staying on the stock pulley and running 12psi to hopefully reach ~285whp.
If the hbp cannot hit 300whp on 12psi on pump i dont see the need for me personally... Mainly because our canadian dollar is 1.38 vs the US. With our sales tax all parts cost 50% more
BRZ'13 is offline   Reply With Quote
Old 12-30-2015, 01:04 AM   #227
BRZ'13
BRZ'13's Avatar
Drives: subaru
Originally Posted by new2subaru View Post
Have you tried Petro Canada Ultra 94?
If not, it may be worth a shot.
http://www.petro-canada.ca/en/locati...PC=+&R=50&B=UL
Yeah thats exactly what i use now. Highest available at pump
Old 12-30-2015, 02:59 AM   #228
You'd be better off getting supporting mods, rather than the high boost pulley.
How is your 94 octane rated? MON? RON? (MON+RON)/2?
Old 12-30-2015, 01:10 PM   #229
BRZ'13
BRZ'13's Avatar
Drives: subaru
Fueling mods or power? I have headers, full exhaust minus catback (probably 2-5hp there) running stock fuel system.
Im not sure how the fuel is rated but i believe its the same as anywhere else from the pump.
I was just curious what others have been getting on the hbp while running pump gas. I cant justify spending 5 grand for injectors, clutch, fuel pump, retune, guages etc if the gains are minimal on pump.
Old 12-30-2015, 03:04 PM   #230
Your type of setup without the HBP should already be 285+whp, assuming AKI94 fuel. The HBP will take you north of 300whp.
Although recommended, you do not need a clutch, injectors, and fuel pump, if you're not using ethanol with the HBP. The final determination on need for these items should be verified by your tuner, based on your car's behavior on the dyno.
BRZ'13 (12-30-2015)
Old 12-30-2015, 06:57 PM   #231
Gear_One_Performance
Gear_One_Performance's Avatar
Drives: 2014 BRZ SCCA STU endurance car
Now if only we could sneak this in to an STU car.
Gear_One_Performance is offline   Reply With Quote
Old 01-02-2016, 10:53 AM   #232
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Originally Posted by JDMChris View Post
Would that basically be the same as the Omni 4 bar? I'm asking out of curiosity if I was to buy a FnG from Delicious would I just drop down the box and pick the Omni 4 Bar as my "Manifold Pressure Sensors (Scaling)" or would I actually need to take this to my local tuner and get a custom tune.
Alltezza is offline   Reply With Quote
Old 01-02-2016, 08:17 PM   #233
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
I've been dailying and drifting my JRSC for about 13 months with no issues on my otherwise stock FRS and I've decided to spring for more power, but I have a few questions that I'm having trouble finding answers for. For the record my plan is to stick to 93oct fuel and add a FT86Speedfactory catted UEL header along with the pulley, so I assume this will put me in the ~300whp range (though please correct me if I'm wrong).
  1. What size injector should I buy? Would a 700cc injector be appropriate?
  2. What are the fuel pump requirements? I'm looking at the DeatschWorks DW300 (350LPH)
  3. Just to confirm, the JR 4bar map sensor would be appropriate for me, right?
  4. If I install both the header and pulley, will it be safe for me to drive ~30miles to the tuner on the JRSC factory tune? If not, will it be safe if I only install the header or only install the pulley? I have no problem paying the shop to install them but why pay if I can do it myself.
  5. Do I need anything else other than the aforementioned injectors/FP/map sensor?
Thanks everyone!
2013 Asphalt Scion FR-S | Jackson Racing Supercharger | KW V3 | Enkei RS05RR 18x9.5
campy is offline   Reply With Quote
Old 01-02-2016, 10:20 PM   #234
A 4 bar is a 4 bar; it should not affect the tune.
Alltezza (01-03-2016)
Old 01-02-2016, 10:22 PM   #235
Thanks everyone!
You do not need injectors or a fuel pump to run 93 octane or a race gasoline with the HBP.
Yes, the JR 4 BAR map sensor would work for you.
Yes, you can drive to the tuner on the factory tune, but to be safe, DO NOT go into boost at all. Even at lower rpms, the boost profiles are different.
I wouldn't expect to see 300whp from the setup. 285-290 is realistic. (standard calibration dynojet)
campy (01-02-2016)
Old 01-03-2016, 02:15 AM   #236
twag4
Drives: frs
Even with the high boost pulley this is all that could be expected from 93 octane? Isn't that similar to the power output on standard pulley given the same set up?
twag4 is offline   Reply With Quote
Old 01-03-2016, 05:30 AM   #237
Alltezza
Alltezza's Avatar
i was wondering the same thing, but it could be because you're going to be running a catted header. Is the rest of your exhaust setup stock as well?
Old 01-03-2016, 12:12 PM   #238
twag4
Drives: frs
Well the original question wasn't mine. But I was told I could get 280ish with my ace type A and full exhaust with just one high flow cat in the front pipe on the standard pulley burning 93octane. That is what I run. I'm curious about this, as there is literally only one business in my town of 35000 to buy e85. I don't live very close to it. -EDIT- I reread and the original question asked about a catted ft86 speed factory uel header.
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
