Old 12-17-2015, 02:57 PM   #211
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
Jackson Racing also offers a MAP sensor now; PM @CounterSpace Garage to get one.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
CSG Mike (12-17-2015)
Old 12-17-2015, 03:23 PM   #212
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
3 bar?
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 12-17-2015, 03:52 PM   #213
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Originally Posted by ScionOfHorus View Post
3 bar?
4 Bar
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
Old 12-17-2015, 04:39 PM   #214
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
What would be the purpose for using this?
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 12-17-2015, 05:05 PM   #215
dj2020
Originally Posted by JDMChris View Post
I figure we would only need a 2.5 bar MAP sensor since we're boosting to 12psi on this smaller pulley. My basic understanding is that should give us more resolution.
dj2020 is offline   Reply With Quote
Old 12-17-2015, 07:04 PM   #216
OkieSnuffBox
Drives: '23 BRZ Limited
Originally Posted by Jackson Racing View Post
Yeah, we have done this on different applications. There are additional components, cost, and complication associated with it. But yes, it works.
If you are planning to run E85 most of the time, it really would never be used. Also, guys are running around with 91/E85 flexfuel without the wastage system. We don't recommend using 91 octane with the high boost pulley because the benefit of the additional boost is taken away by the amount of timing you need to pull out.
And pulling a ton of timing also dramatically raises EGTs.
A double whammy.
Old 12-17-2015, 07:19 PM   #217
dj2020
A double whammy.
Is this an issue strictly for sustained high rpm, WOT conditions? Or are higher EGTs a problem when street driven?
Old 12-19-2015, 12:06 AM   #218
Primarily for sustained WOT, but you want to avoid it, period.
The High Boost pulley should only be used if you have 93 octane, race fuel, or ethanol readily available to you. We do not recommend it for 91.
dj2020 (12-19-2015), KR-S (12-19-2015)
Old 12-19-2015, 01:31 AM   #219
dj2020
@CSG Mike: PMed you. Should I order HBP/MAP sensor directly from CSG site?
Old 12-19-2015, 02:04 AM   #220
Site or message @CounterSpace Garage if you prefer a paypal invoice.
Thanks for supporting CSG!
dj2020 (12-19-2015)
Old 12-21-2015, 03:31 PM   #221
twag4
Drives: frs
Hey I have the delicious 11psi MAP sensor. Would this need upgraded if one got the new high boost pulley?
twag4 is offline   Reply With Quote
Old 12-21-2015, 03:35 PM   #222
dj2020
I believe so. The HBP raises the boost to ~12 psi.
The Following User Says Thank You to dj2020 For This Useful Post:
twag4 (12-23-2015)
Old 12-23-2015, 06:41 PM   #223
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Yes. You will also need injectors, fuel pump, some other supporting modifications, and a very patient time with tuning to refine the parameters in the map.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
twag4 (12-23-2015)
Old 12-24-2015, 01:34 PM   #224
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
When will the CSG site have the upgrade kits you mentioned earlier?
Sleepless is offline   Reply With Quote
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 01:59 PM
Jackson Racing BRZ Parikh1234 Member's Car Journals 31 12-29-2015 10:26 AM
Why no high rpm boost for Phantom ESC? stevo585 Forced Induction 11 02-11-2014 08:51 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 03:29 PM
