#799 |
Drives: anything you let me
#800 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Look at it this way: I just saved you guys money since now you don't have to buy multiple sets of long needle nose pliers, multiple trips to the auto parts store and time wasted struggling with the hose clamp like I did.
#801 |
As annoying as I find vlogers (this particular guy I find slightly less annoying, but I admit, I feel a little miffed that he ended up with an E-force, but hey, welcome to the club!) but I can't help but share his giddy excitement and reaction to the impressive Edelbrock facility.
[ame="https://www.youtube.com/watch?v=qwf3QQkA9L8"]Picking up my Supercharger from Edelbrock - YouTube[/ame] If anything, for those potential/current owners who have not/could not go to the factory tour, the first half of the video pretty much sums it up. |
#802 | |
Drives: 2017 BRZ
An electric issue might also relate to the connection issues... A sensitive device might not like odd issues from shorts or a bad connection, and based on the earlier cell-phone being plugged in failure, this seems a sensitive system. I'm probably totally off base but it seems it might be time for anything even remotely plausible... I'm only here because I don't need to spend any more money on my car and I wanted to read how miserable life is with boost. ![]() C Last edited by cjd; 02-18-2016 at 10:24 PM. Reason: Manually correcting autocorrect... |
| The Following User Says Thank You to cjd For This Useful Post: | CSG Mike (02-19-2016) |
#803 |
Drives: 2013 FRS
I'm still testing tunes and logging. Making some progress in smoothing out the power band. I did have a strange thing happen tonight during logging. My exhaust cam stayed at -1 for about 15-20min of driving, never moving during all kinds of load points. Power was way down during that time, but everything else was smooth. Anyone ever see that? Seems like maybe a problem with the cam sensor/actuator/electronics? Just guessing...
#804 | |
Drives: UK GT86
.: Stealth 86 :.
#805 | |
Many, many hours later, repairs were made to some partially damaged wiring, the hot wired electronics removed, a new ECU, and the car is now running. However, we're still working on getting it back up to 100%. Electrical stuff is a nightmare. |
#806 | |
#807 | |
Drives: UK GT86
.: Stealth 86 :.
#808 | |
Drives: '13 BRZ | '04 E55
I have been pretty fortunate with AVCS activation on the BRZ. It is usually active by the time I leave my neighborhood after a flash. My STI was terrible about taking forever to activate AVCS after a flash though. I had times, similar to what you describe, where it would remain inactive for the better part of a 15minute drive trying to get a log. Sent from my iPhone using Tapatalk
#809 |
Drives: Toyota GT86 euro version
| The Following 9 Users Say Thank You to Paulo86 For This Useful Post: | BigFatFlip (02-19-2016), CSG Mike (02-19-2016), itsibarra (02-19-2016), MaximeT (02-19-2016), NotSoJDM (02-19-2016), Silverfox (02-20-2016), Summerwolf (02-26-2016), toast (02-19-2016), Uplink (02-21-2016) |
#810 | |
Drives: 2013 FRS
Thanks for confirming guys. I had just flashed a new tune, and I was driving the car fairly easy until the end, and eventually it did switch on, probably when I came to a brief stop at a stop sign or something. I'll chalk it up as a fluke, it's funny I never noticed it before. By the way, I also got a new ECUTek cable from Edelbrock and it is working a lot better than the old one. It still disconnects but now it's 100% related to moving the connector around during logging, which can be dealt with. The other cable seemed to just disconnect randomly. I think I may be getting close to a final tune, fingers crossed. I do have one more unexplained behavior I've noticed with the new setup. Sometimes if I shift from 1st to 2nd at or near redline the throttle goes dead, even when depressed fully it does nothing and the engine drops to idle. If I fully release the throttle and then press again it picks back up normally. Anyone have that happen before? Is this because the new tune is using the throttle to cut the engine off at the limiter? So far it has only happened about 1/20 times, but super scary when it happens because for a split second I think I killed the engine! |
#811 | |
You had me at the picture of a new tool. ![]() But seriously, thank you for the tip. Probably best to install them both at the same time but at least it can be done later if needed. |
#812 | |
Would that explain why sometimes making a quick lunch run at work the car (stock tune) feels a little underpowered? (Nobody make the 'it's always underpowered joke', serious question.) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
