#729 |
Drives: 2013 FRS
Hey guys, not sure if someone who is an experienced and a seasoned expert at reading ECUTek logs would even look at these logs. Can I beg? I'm just at my bitter end with my troubles. No head way in almost a month. Tonight the problem got so bad the car almost stopped running, it wouldn't put out any power and the ignition timing was -20 in the logs (end of last log). At that point I had to shut it down and just try to get home. Who is the very best person I could pay to examine the logs and give me the best possible cause? I've got about 75 logs at this point through all the various testing and tweaks we've tried, lots of data! I'm feeling very close to just pulling the kit off and selling or trying to get some money back out of the whole experience.
#730 | |
You have an installation error. The lowest LTFT I see at idle is at least +20. Vacuum leak is my guess. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | 86fun (02-05-2016) |
#731 | |
Drives: FRS, Supra, Colorado D, GLC63
#732 |
Drives: 2013 FRS
Thanks for taking a look guys! I have smoke tested and looked over the install several times, checking everything, I cannot find a leak anywhere. The problem only happens part of the time too, I'd think a leak would always be present?
I also get disconnected from my ECU constantly, and I've tried different laptops, messing with the cable/connector, but it seems to be something in the ECU causing it. ECUTek has no suggestions except to update the ROM....waiting on Edelbrock for that one. |
#733 | |
PhoneFlash by EcuTeK
![]() Sincerely, Zach Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | Edelbrock LLC (02-08-2016) |
#734 |
Drives: 2013 FRS
Can someone with the kit do a bit of logging or post some logs of various driving so I can see how our values compare?
I guess I'm going to have to pull the whole kit off and test every single hose and component for leaks, because none can be found right now with it installed. Is it possible somehow the SC unit can leak inside the manifold chamber? |
#735 |
Drives: Evo 9
^ sorry I might have missed it. But I have a ton of experience searching for vacuum leaks on superchargers. Can you explain in detail what procedure you are using when using a smoke tester? Also what model smoke tester are you using? Is the system pressurized when you are performing this test?
#736 | ||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
http://datazap.me/u/bigfatflip/15120...l?log=0&data=7 http://datazap.me/u/bigfatflip/15120...g?log=0&data=7 Quote:
#737 | |
Drives: 2013 FRS
. I'm not a shop, I just use home made tools. Making smoke is not rocket science. I'm not using a lot of pressure, didn't want to pop anything, but I could hook up some compressed air to it, that's a thought.. . The thing is, if it's only leaking sometimes, then I'd have to test it under those conditions, which would be a bit difficult to accomplish. . I guess I'm just going to pull the kit, and if I don't find anything it must be defective. Seems logical. |
#738 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Freeman (02-05-2016) |
#739 | |
Drives: 2013 FRS
Yep, already been done, but I'll do an additional smoke test(s) tonight first. |
#740 |
Drives: 2013 FRS
I just did some logging and testing and found out that when the disconnect problem is happening (disconnect after a certain load point is reached on the engine for a certain amount of time) in ECUTek, I can plug in my OBDLink LX and it stays connected and real time indefinitely. I did this several times plugging them in back and forth and the ECUTek would always disconnect after applying a certain amount of engine load for a while, like seconds, not minutes. At least this tells me it's not the whole computer screwing up. This is 100% reproducible, I just press the throttle a bit, sometimes it takes more than other times, and I'm disconnected, even in neutral sometimes. Not sure what that says, but another data point.
#741 |
Drives: 14 BSP Edelbrock BRZ
I would suspect a split or cracked hose with your symptoms since it always seems to be an issue at slightly positive pressure - under vacuum it seals itself shut.
Sent from my Nexus 6 using Tapatalk |
#742 |
Drives: 2013 FRS
I just spent a couple hours smoke testing, at about 3-5psi, and there was nothing. I also disconnected and checked every electrical connector/pin in the system, all looked good. The only air hose without a clamp is the SC bypass valve hose, but it is pretty tight... hasn't blown off anyway, and the kit doesn't specify a clamp on that one for some reason. The problem I have is mainly happening around 1-2psi, so not a lot of boost.
I just went out and tested and it's still bucking and disconnecting ECUTek with any significant throttle. ECUTek said they could not help with the disconnects, great product support. At this point, if it's mechanical I'll have to remove the kit to look into it further. I'm going to try a new electrical harness for the MAF/MAP/throttle/etc from Edelbrock, then it's off with the kit and getting sent back if I cannot find any install issues and the car works normally OEM again as it did prior to install. This has not been a good experience unfortunately. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
