86WORX
BT, dpfarr
Old 01-21-2016, 07:27 AM   #603
Originally Posted by tracerit View Post
That might happen in the future. Who knows haha. But right now I'm dealing with a squeaking clutch again... Had my throw out bearing replaced last summer, thus new noise is when I left the clutch out.
Would an upgraded clutch such as the act street HD be a good part to go with to accommodate edelbrock +e85?
I figured if greasing the fork doesn't fix it I'll bring it in if they service the car and open up the transmission I'll just get an upgraded clutch.
Yes, you'll need an upgraded clutch, and the ACT is pretty popular (and frequently goes in and out of stock).
Old 01-21-2016, 11:39 AM   #604
Uplink
Uplink's Avatar
Drives: anything you let me
Take a look at the Spec 2+ kit. I'm running that on my Vette (3200lbs w/ 520+ft/lbs TQ) with the Spec lightweight flywheel. It holds perfectly and acts like stock for daily driving. No chatter even when slipping it for stop and go driving. In the FR-s they claim it's good to 264ft/lbs. Wouldn't go any more agressive than that though for a daily.
Uplink is offline   Reply With Quote
Old 01-21-2016, 11:54 AM   #605
tracerit
Drives: '13 SSM BRZ Limited 6MT
Gonna have to cancel my edelbrock plans now. Just discovered an engine leak in the same area as before (timing chain cover). Appears to be a slow leak that I most likely have had since the very beginning but neve noticed until 20k miles when I removed the cover to install the OFH (never did it btw). Luckily the dealership fixed it under warranty. I'm at 31k miles now.
I now have no confidence in my engine being built tough enough to accommodate the edelbrock. What a sad realization
tracerit is offline   Reply With Quote
Old 01-21-2016, 12:00 PM   #606
j123ic
Drives: Evo 9
Originally Posted by NotSoJDM View Post
Is there really only 9 owners! I think the first page needs an update with new owners
Honestly there's a whole lot more than 9 owners now.
And if anyone ever has an issue with missing parts, just call Edelbrock tech support directly. They will more than likely send you what's missing first class. You don't need to go through your retailer for a missing bolt.
j123ic is offline   Reply With Quote
The Following 2 Users Say Thank You to j123ic For This Useful Post:
Nitro22 (01-22-2016), NotSoJDM (01-21-2016)
Old 01-21-2016, 12:05 PM   #607
menikmati
Drives: 2015 BRZ, 2005 STI
menikmati is offline   Reply With Quote
The Following 2 Users Say Thank You to menikmati For This Useful Post:
Freeman (01-21-2016), tracerit (01-21-2016)
Old 01-21-2016, 12:07 PM   #608
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
lol that was my point. I'm sure Edelbrock has shipped a lot more than 9 kits out. Which means the owners list on the first page needs some love.
I.E if you own the setup, let our buddy Mike know so he can update the first page with your name.
NotSoJDM is offline   Reply With Quote
Old 01-21-2016, 12:11 PM   #609
86fun
Drives: 2013 FRS
Maybe these are just CSG Edelbrock owners? I can start a new thread that is more open if needed...
Yes, call the tech line directly and bypass their operator, because she rudely told me I had to go back through my retailer.
Edelbrock shipped out my part after a day and it was sent ground. YMMV. I had more than a missing bolt though, it was a couple larger parts.
86fun is offline   Reply With Quote
Old 01-21-2016, 12:14 PM   #610
NotSoJDM
NotSoJDM's Avatar
I bought my kit directly through Edelbrock, and am on the list.
Old 01-21-2016, 12:36 PM   #611
86fun
Drives: 2013 FRS
Cool, then I'm an owner and can be added to the list.
The Following User Says Thank You to 86fun For This Useful Post:
Old 01-21-2016, 12:39 PM   #612
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I had a different experience. Called tech support directly and they gave me the same answer of having to go through my "dealer" to get parts. I haven't followed up with my dealer in a while, so I'm sure nothing happened. Good thing its a minor part I was able to mcguyver.
Old 01-21-2016, 12:53 PM   #613
Edelbrock LLC
Edelbrock LLC's Avatar
Drives: 2013 Subaru BRZ
If there is something missing you are more than welcome to PM me here or call our tech line directly.
We would like to know what some people have been missing so we can address the issue immediately.
-Eddie L
Edelbrock LLC
Edelbrock LLC is offline   Reply With Quote
The Following 6 Users Say Thank You to Edelbrock LLC For This Useful Post:
BBDGriptonia (02-03-2016), BigFatFlip (01-21-2016), Fever (01-22-2016), Irace86 (01-21-2016), paiceyfan (03-11-2016), Paulo86 (01-21-2016)
Old 01-22-2016, 12:32 AM   #614
86fun
Drives: 2013 FRS
Hey guys, I'm buttoning everything back up here and found a fault in the instructions. It does not specifically say to reinstall the radiator shroud. To me it seems obvious to do so, but what did you all do? Once I have this advice should be able to finish up and take a quick ride
Old 01-22-2016, 01:11 AM   #615
BigFatFlip
BigFatFlip's Avatar
Not entirely sure what you mean by "radiator shroud", do you have a pic of the part?
Old 01-22-2016, 01:12 AM   #616
86fun
Drives: 2013 FRS
That's what it's called in the instructions when you remove it. It goes from the crash beam to the upper radiator support.
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
