#3025 | |
Drives: 2017 Toyota 86
http://www.ft86club.com/forums/showp...postcount=2368 I'm not leaking there. I've been doing a lot of searching on this and looks like 2 odd things that seem overlooked a lot could be causing this: low battery or bad PCV. My issues got worse on E85 too. Have you been having issues starting, like it takes 2 crank attempts every time? I have and I think I've just about drained my OEM battery: my voltage is like 11.90v. I'm going to try a different one to see if anything changes. For the PCV there are a couple posts around here where people have replaced the stock valve with one from a WRX/STI. Apparently, our stock one wasn't designed to see boost. These guys reported replacing the valve and their problems went away. The Jackson Racing kit bolsters the stock PCV with another series check valve. The other observation is the DT tune v25.20 I'm on appears to be well behaved on the DW 700cc/min PIs, but appears to be having issues only when on DI only. I'm going to try to ask Bill to check it out. |
| The Following User Says Thank You to Mr_Eyo For This Useful Post: | Bunsin (04-02-2019) |
#3026 | |
Drives: 2013 FRS
Gotcha, so you're noticing it at idle. The reason I asked is I have one of the original kits and recently my idle has started randomly going to shit. I was nearly stranded the other day because it would not idle at all, and when it did it was all over the place 700rpm to 3k rpm and all over in between. Small throttle inputs were also dramatic, felt like tip in was giving 80% throttle or something. I'll run this check to see if that's it, but since it goes away I'm thinking it something else. Thanks for the info. |
#3027 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
#3028 | |
Drives: 14 BSP Edelbrock BRZ
#3029 | |
| The Following User Says Thank You to toast For This Useful Post: | gtengr (04-02-2019) |
#3030 | |
Car Goes Bang
Drives: 2013 FRS, 2014 BRZ
No issues starting (in fact idle is pretty good but a little high). When I did the pinch test last night there was a change in the idle RPM so I'm dead certain it is the actuator. It got entirely worse this morning during the aborted drive to work as it finally lit up the dash. The car was not behaving well at all so I suspect that the tear in the diaphragm got worse. Part is being warrantied by Edelbrock so I'm just in it for rush shipping... Hopefully that is the only leak and I'm not chasing down other things. I should get some of this sorted and then see if Zach can move me up to the latest tune. Shout out to the guys in the tech center at Edelbrock for the rapid response. EDIT: Just checked and it threw a P0171 so just as expected Last edited by Bunsin; 04-02-2019 at 07:15 PM. Reason: Add engine code |
#3031 | |
Here's another question: if there is blow by pressurizing the crankcase, and it blows out through the PCV into the blower, isn't that unmetered air getting back into the intake after the MAF? If so, a vent to air path for the PCV would solve the problem (like others have reported), right? Would routing the PCV to the same CCV port on the air box also work? Last edited by Mr_Eyo; 04-02-2019 at 08:58 PM. |
#3032 |
If that was how the bypass valve worked it would never be bypassing anything. If the rotors moved so much air that they could pressurized not only the plenum but also the air volume upstream of the rotors you would always read boost pressure when logging and never see vacuum.
Blow by is caused by combustion - the air for combustion has already been metered, you aren't introducing any new air into the system. The PCV outlet enters the supercharger snout downstream of the MAF. You seem to want to fix a problem by introducing new measures that could add new problems. The edelbrock kit as spec'd works fine (when the bypass actuator isn't leaking). If yours doesn't you should look at install errors, bad hose connections or things that aren't part of the kit. |
| The Following User Says Thank You to toast For This Useful Post: | Mr_Eyo (04-03-2019) |
#3033 |
My Eyo, I just looked back at your last post. If you have 25% STFT you have a large vacuum leak or a sensor is giving your ECU ridiculous readings. Your tuner should look at your logs and be able to tell you very quickly if it is a sensor reading strangely.
#3034 | |
I'm just concerned that there's something unique about my hardware (not the Edelbrock kit) that I might have to work around. I don't don't want to be like some of the others that had continual issues with the kit and ended up getting rid of it -- I'd be willing to add workarounds if needed. I'm still waiting for an appointment to bring the car into the garage to check it for leaks; hopefully that leads to actually fixing the root of the issue. |
#3035 |
Simply Forgotus
Drove it today and got a few codes, P0171, P015a and P015b. Guess the hole in the diaphragm's gotten bigger. Hopefully the new bypass valve will be here tomorrow.
#3036 |
Car Goes Bang
Just installed my actuator today, but I'm still having issues at WOT from a start (massive hesitation at WOT from a dead stop). The actuator now holds a vacuum but I'm not sure is behaving the same as the old one that I did the initial tune on. Logs are going to Bill to see if he can tell me if I have an issue or just enough stuff has changed I need a refresh on the tune (I had the recall work done so who knows if they jacked something up).
#3037 |
Have you tried pulling power from the ecu or reflashing? If not, it's still holding the learned short and long term fuel trims.
| The Following User Says Thank You to B T For This Useful Post: | BirdTRD (04-04-2019) |
#3038 |
Simply Forgotus
Got a dinky V1 surge tank? Not quite ready to spend money on the V2 tank from Jegs? Want the bits to upgrade your V1 surge tank to Bird's V1.5?
All yours for the cost of shipping! First come, first served.
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
