#2983 | |
Drives: 2013 FRS
Im also noticing part throttle 3psi surges like the tuning has holes in it. I just dont feel a smooth acceleration unless im full throttle |
#2984 | |
Drives: 13 FRS Firestorm
I'm on the Edelbrock tune. I have been able to deal with the minor idle/throttle response issues. Although I don't notice bucking like you do, or anything mentioned in the above posts when it's cold (20-30°F). Sent from my SM-G9600 using Tapatalk |
#2985 |
Drives: 2013 FRS
yes im on the Edelbrock tune. and yes the throttle response is very poor.
#2986 |
Drives: 2015 BRZ Limited
To those running with e85 and FF kit, how are you guys doing so far and how many miles so far with e85 on top of the edelbrock?
Also which injectors did you guys to with? I'm looking into getting an ff kit to do e85 but need to see which injectors are reliable. |
#2987 | |
Drives: 2017 Toyota 86
#2988 |
Drives: 14 BSP Edelbrock BRZ
What is everyone using for clutches? South Bend stage 2 seems like a common choice but I've read several reviews that said they develop an annoying shudder.
Also, I'm only at 65k, think my flywheel is fine to reuse? |
#2989 |
Pre-emptively changed mine to the ACT SB7-XTSS at 50k and still had plenty of material left on stock clutch. I had been supercharged for over 35k at that point. The SB7-XTSS kit seems grabby when cold but smoothly engages in first after a bit of driving.
Side question, has anyone looked into a swirl pot for the supercharger coolant lines? my coolant seems to always be sitting below the inlet and outlet at the fill point until I open the system. |
#2990 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
I'm running ID1050x injectors with E85 and the Walbro 485 HPFP. Dialing in the tune with those injectors is key so the best place to start would be a conversation with your tuner.
| The Following User Says Thank You to BirdTRD For This Useful Post: | inonly (03-12-2019) |
#2991 |
Simply Forgotus
| The Following User Says Thank You to BirdTRD For This Useful Post: | B T (03-26-2019) |
#2992 |
I'd imagine I have V1 based on when I ordered the kit, but I'm not entirely sure. its a clear plastic upright cylinder, maybe 5 inches tall.
#2993 |
Simply Forgotus
I have V1 so I came up with this rig to keep the air out. (see this for details http://www.ft86club.com/forums/showp...postcount=1628)
#2994 |
Who was your tuner? Mine recommends DW 700cc injectors and DW 300c fuel pump so i guess i'll go with those.
#2996 | |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
