#2871 | |
Alternatively, you can buy the updated nose cone, and just swap them. CARB is up to 17 at the moment, but a 18 tune is available. Email the same address you used before at Edelbrock, and give them your Ecutek ID. You'll need another Ecutek license for the new car. PM me for any of the above, including the nose cone and/or license. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | durtdonthurt (08-29-2018) |
#2872 |
Drives: 2013 Subaru BRZ
Are there any strut tower braces that are confirmed to fit?
#2873 |
Drives: 2015 Subaru BRZ
#2874 |
Drives: 2013 BRZ Limited 6MT
Hi Everyone,
Just purchased a used Edelbrock kit from the forum classifieds, getting ready to install it in the next week or two. I purchased all the special tools called out in the manual as well as the coolant and brake fluid. I know I will also need to purchase a license for the ECUTEK. Are there any other consumables I will need to replace when I install it? Thanks. |
#2875 | |
Drives: 13 FRS - Boosted
Sent from my SM-N960U using Tapatalk |
#2876 | |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
#2877 | |
Drives: 13 FRS Firestorm
K&N filter sealant (1oz) https://www.amazon.com/99-0703-1-Sea.../dp/B000N9ZPAI MAF cleaner (not required, but I'm at 100k miles) Sent from my SM-G9600 using Tapatalk |
#2878 | |
PM me for the Ecutek license. |
#2879 |
Thanks everyone.
Will do Mike! |
#2880 |
Finished installing my charger now I have a p0102 code any ideas?
#2881 |
Drives: 2013 DGM BRZ
What tune are you running? Did you clear codes when flashing it?
Can you datalog your MAF voltage so we can see what values it's getting? Last edited by Akari; 09-29-2018 at 02:19 PM. |
#2882 |
Drives: 2016 BRZ Limited Pure Red
I installed my Edelbrock SC a few weeks ago, and I'm getting a few symptoms that I think are related to the tune, but I want to get some opinion if this could be a vacuum leak as well. Basically, the car is very rough during cruising below 4k RPM and during gentle acceleration. I took some logs and the LTFT is low (-7.8% while in closed loop), which corresponds to the range where it is very rough. Based on what I've read in the software tuning threads, I suspect this is due to unexpected feedback from the O2 sensor, as I'm using the Edelbrock CARB tune with an aftermarket header (FT86SF catted UEL header) and stock O2 sensors. I've uploaded some logs here:
https://datazap.me/u/thriller/log-15...a=7-9-10-11-24 However, I'm not quite sure how to differentiate between tune issues and vacuum leaks in the logs. So far, I've had no stalling and no CEL, and it looks like the actual AFR is normal in both open and closed mode, so I don't have any reason to suspect a vacuum leak. I've ordered a tune + DBOX from Delicious, but I'd like to rule out any hardware issues before I install it. Thanks! |
#2883 | |
#2884 |
Hi Mike,
Thanks for the response! I've uploaded an idle log here: https://datazap.me/u/thriller/idle-2...og=0&data=7-11 |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
