86WORX
BT, dpfarr
Old 10-19-2017, 11:25 AM   #2563
Originally Posted by trippinbillies40 View Post
Don't want to scroll back through several pages... @CSG Mike, I saw on IG that CSG has an Edelbrock going on a '17. Are there still shenanigans involved with the alternator and ECU or has Edelbrock worked something out yet?
It's strictly an alternator issue. Permanent fix is coming soon.
Evil Rocky (10-20-2017)
Old 10-22-2017, 03:33 PM   #2564
taiguy
Drives: 2013 Black BRZ Limited
Exclamation engine stalling in neutral
Well this is the opposite of encouraging. I thought I was out of the woods with my e-force install earlier this year after moving over to the delicious tune. I was headed out this morning and my BRZ stalls out as I'm coming to a stoplight, as soon as it get dropped into neutral.
I restart the engine and it does the same thing at the next light. This happens one more time this morning, for a total of 3 stalls. All while going into neutral coming to a stop.
Nothing has changed on the car since March. This happened once last fall while I was still on the CARB tune.
It doesn't seem to happen once the engine is warm. Air temps were around 45 when I left.
Here's my dash all lit up. There are no codes thrown or stored when I checked.
taiguy is offline   Reply With Quote
Old 10-22-2017, 06:16 PM   #2565
Log it, and send it to DT/CSG.
Old 10-23-2017, 04:53 PM   #2566
B T
You're just not driving as hard as you think you are. Go sit on the highway in 3rd gear for 60 seconds and watch your oil temps.
My daily driving doesn't consist of any interstate, several hard stops and starts and a little cruising at 55 or so to keep it legal. What situation do you consistently run 3rd for 60 seconds?
Looking forward to that Touring86 exhaust btw
B T is offline   Reply With Quote
Old 10-23-2017, 05:15 PM   #2567
Any sort of spirited driving will sustain elevated RPMs, which is the purpose of the stated exercise.
Elevated RPMs will result in elevated oil temps, very quickly, with no real way of mitigating or shedding that heat without a heat exchanger (oil cooler) of some sort.
Likewise, your thermostat is actually closed, if your temps aren't dropping under 190F in this car
911's have thermostats set for 85C; this car runs 90C.
Old 10-23-2017, 05:20 PM   #2568
B T
Maybe my sensor is wrong then, I'm running a P3 gauge reading coolant and oil temps from the ECU. Before I added the oil cooler, I would see it quickly jump to 210 sitting in traffic. It's like my oil thermostatic switch never closes off the route to the cooler. I even replaced the t-stat with the higher 200 degree version recently to try and bring up the oil temps on daily. My coolant temps always read pretty low though except track days as well.
Old 10-23-2017, 05:40 PM   #2569
Most tunes have the fans coming on pretty early for the coolant.
Thermostatic plates never *fully* close. There's always a trickle flow to prevent thermal shock when the flow does get larger.
Also, remember your oil temp is post-cooler, so rest assured that the actual oil temp of the oil in your engine is higher than what you're reading.
Old 10-23-2017, 05:44 PM   #2570
taiguy
I haven't figured out how to replicate it on demand.
So far I've logged 4 trips today without any issues.
Old 10-23-2017, 10:40 PM   #2571
B T
@CSG Mike
I was happy to see my Touring86 sitting on my porch when I arrived home from work. I immediately put it on and it sounds great. Thanks for selling great products.
The Following User Says Thank You to B T For This Useful Post:
CSG Mike (10-27-2017)
Old 10-27-2017, 06:02 PM   #2572
DanGTZ
Drives: 1989 Toyota Corolla GTI 16v
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
I had the pleasure to install the Edelbrock kit on a 2013 GT86 a few months ago. Here are some pics of the installation and a Dyno comparison of the previous setup (intake+full exhaust) with the new one.
Click to see live chart comparison :
https://network.perfexpert-app.com/m...bJn+V6y64KuFU8
DanGTZ is offline   Reply With Quote
The Following 2 Users Say Thank You to DanGTZ For This Useful Post:
CSG Mike (10-27-2017), shiumai (10-27-2017)
Old 10-27-2017, 06:33 PM   #2573
@CSG Mike
How's the volume level and note?
Old 10-28-2017, 04:16 PM   #2574
B T
Volume is great, still a bit loud at cold start, but not nearly as bad as with the stock muffler. No Rasp, quiet at cruise, love it.
Setup is Ceramic ACE A350 > ACE SS front pipe > Touring86
Old 10-28-2017, 10:46 PM   #2575
shr133
shr133's Avatar
Drives: 2013 FRS
Who make a good base map that's not locked??
I have my NA tune working great but would take a lot of work to convert my map over.
I will be doing the final tuning but I need a good base map to start with.
I know Edelbrock's map is locked.
Does any sell a good base map that's not locked???
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
shr133 is offline   Reply With Quote
Old 10-28-2017, 11:16 PM   #2576
You can always get a tune with a quieter cold start! Then it'll be much closer to a normal warm idle on cold start.
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
