86WORX
BT, dpfarr
Old 10-03-2017, 04:46 PM   #2521
25F over ambient is totally reasonable, considering how much denser the air is post-supercharger.
The Harrop kit reads similarly, with temps dropping at speed due to the heat exchanger getting more airflow.
If you guys datalog, you'll notice that IATs go *down* when you're part throttle vs idling, again, just because of airflow through the manifold.
A great example of this is your hood. Go for a drive on the highway, and then immediately get out and touch the top of your stock hood. Now, the next time you sit in stop and go traffic, when you park, touch the top of your hood. Note how much hotter it is when the hood has minimal airflow over it versus constant airflow.
Old 10-03-2017, 04:58 PM   #2522
B T
So where is the IAT measured for the ECU? I thought it was read at the MAF, before the supercharger.
B T is offline   Reply With Quote
Old 10-03-2017, 05:10 PM   #2523
StraightOuttaCanadaEh
Wes
So would a larger throttle body lower the temps even more by letting through more air?
Old 10-03-2017, 05:46 PM   #2524
Negative; airflow is primarily determined by your SC, and how much you step on the throttle.
You might gain a marginal amount of power and a marginal drop in temps, but both will be in diminishing returns territory.
StraightOuttaCanadaEh (10-03-2017)
Old 10-03-2017, 05:48 PM   #2525
For stock cars, yes. The Edelbrock uses a TMAP (temperatuer MAP) in the rear driver side runner.
This is why you have a harness that the stock MAP plugs into, which then plug into the factory MAP plug. The Temperature reading is sent from the TMAP included with the kit, to the MAP's temperature wire. The MAP's actual temperature is ignored, because we only care what the temp of the air going into the engine is, not what the temp of the air is before being charged. This allows for zero cutting, zero splicing, and allows for the ECU to accurately read what your actual intake charge temperature is.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
B T (10-03-2017), gtengr (10-03-2017), shiumai (10-04-2017), whataboutbob (10-14-2017)
Old 10-03-2017, 06:02 PM   #2526
B T
Great, thanks for the clarification! Have you guys experimented with air ducting and spacing the liquid to air intercooler off of the radiator? I was thinking about going this route, but if someone has tried it and gotten negligible results, I'd rather not attempt.
Old 10-03-2017, 06:26 PM   #2527
No need for extreme measures, unless you're running a 2.875" pulley or smaller, based on the limited data I have. Even then, it's only really needed for sustained use. Water cooling is really, really efficient, similar to computer cooling.
Old 10-04-2017, 05:26 AM   #2528
Bfranklyn86
Drives: GT86 Harrop S/C
Can confirm that this is roughly what I see on the Harrop. The only way to make IATs go up is to sit around in traffic. Extended track sessions....the IATs don't budge.
Bfranklyn86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bfranklyn86 For This Useful Post:
86 South Africa (10-04-2017), CSG Mike (10-04-2017)
Old 10-14-2017, 09:46 AM   #2529
azynneo
Is it normal for a car to feel more preppy and smooth with the stock header over a uel?
azynneo is offline   Reply With Quote
Old 10-14-2017, 01:15 PM   #2530
Yes, with an aftermarket tune, but you can't eliminate the dip without a header that eliminates it. Ace headers are EL and completely eliminate it.
You can imagine what it would do with an Edelbrock, right?
Old 10-14-2017, 02:37 PM   #2531
Dan37BRZ
Senior Citizen
Drives: 2015 WRB BRZ
Quick question for owners running the D-Box.
Is the green light supposed to be solid or does it rapidly blink? I recently got around to installing the D-Box I ordered a while back and having driveability issues right after.
Car surges, hesitates after each gear change and part throttle acceleration is quite terrible. Not smooth, feels like there are rough spots all over the powerband.
NO CEL, installation was checked and double checked, everything plugged in correctly. Connections are pretty idiot proof.
I'm running the Delicious tune and fine tuned by Zach from Delicious.
As soon as I took off the D-Box the car went back to normal.
Dan37BRZ is offline   Reply With Quote
Old 10-14-2017, 07:11 PM   #2532
azynneo
I was talking about with the edelbrock and e85. Car feels smoother with the stock header than my uel.
Old 10-14-2017, 07:43 PM   #2533
gtengr
Drives: 2017 BRZ
Not running dbox yet but I think the tune has to be matched up.to its function.
gtengr is offline   Reply With Quote
Old 10-14-2017, 07:49 PM   #2534
Colin86
Drives: 86
Dbox and Delicious tuned here -car runs nice and smooth.
Unfortunately I think my bypass went bad... Going to check it tomorrow, huge thanks to @BirdTRD for the guide.
I feel like we should link that guide on the first page of this thread... It's post 2368, CSG Mike?
Colin86 is offline   Reply With Quote
The Following User Says Thank You to Colin86 For This Useful Post:
CSG Mike (10-14-2017)
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
