#225 |
Drives: 2013 FR-S Argento
#226 | |
Drives: Scion FR-S (Hot Lava)
Step 63 shows the OE PCV hose and step 64 shows the Edelbrock hose you need to interrupt if you want to use a catch can. -Aaron |
#227 |
This just in...
![]() CSG has a bunch of kits in stock. For everyone that preordered the kits, they're on their way! |
| The Following 11 Users Say Thank You to CSG Mike For This Useful Post: | 86 South Africa (10-26-2015), Alltezza (10-20-2015), Firesnake (10-20-2015), Griever423 (10-29-2015), illmatic (10-21-2015), itsibarra (10-20-2015), JohnnyP (10-22-2015), Nitro22 (10-20-2015), Phantobe (10-22-2015), Porcupint (10-21-2015), stoked_on_spool (10-21-2015) |
#228 |
For those familiar with this dyno, from the Facebook discussion group:
https://www.facebook.com/groups/1072440386107226/
#229 |
Drives: 2013 FRS
CARB tune = 265 fwHP? Isn't that about 225rwHP? Doesn't seem right?
Can't tell much without knowing what a stock/baseline dyno looks like on that dyno.... |
#230 | |
From another thread.
![]() The flatter curve is the Edelbrock, and the steeper curve is the Rotrex kits. Ultimately, both kits, are limited by the 92 octane fuel. The Edelbrock's strength is manifested down at the lower RPMs, where it can build boost earlier, but the Rotrex's efficiency is manifested up top, where it makes more torque (and power) at the same level of boost. The peak differences are that the Rotrex kits have about 20 lb/ft (~15hp) less at 3500 RPM, but have about 25 lb/ft (~30hp) more up top at 6500RPM. I would confidently say that Drift-Office can probably tune the Rotrex kits to not drop off up top at this point, given their experience. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Freeman (10-23-2015) |
#231 | |
Green = CARB Pink = DT FNG 91 (with a few bolt ons) Purple = DT FNG E85 CSG is a Delicious Tuning dealer, and already has this tune for sale. |
#232 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
One thing I'm curious about and maybe the current owners and perhaps @Edelbrock LLC can shed chime in is what type of maintenance is needed with the kit ie more frequent engine oil changes, intercooler coolant replacement, air filter cleaning/recharging etc. along with their maintenance intervals.
#233 | |
PhoneFlash by EcuTeK
These numbers are displayed in Dynojet on that display. A baseline of an FRS on this dyno as described below "Comparison Mode" or DynoHet numbers are 175 Raw Rear Wheel Horsepower numbers are 150 CARB Edelbrock Tune Wheel Horsepower numbers are 225 Sorry for the confusion, but you can blame the dyno companies for all their variances that just confuse everything. Cheers, William Knose Delicious Tuning |
#234 |
Drives: '13 BRZ | '04 E55
Here are some videos from this weekend at Tail of the Dragon. The first one has some supercharger whine in it, which you can't hear in cabin.
[ame="https://www.youtube.com/watch?v=lfvidoUx940"]Dragon Run 3 Oct 2015 - YouTube[/ame] [ame="https://www.youtube.com/watch?v=GL9ObGLXtOE"]Dragon Run 2 Oct 2015 - YouTube[/ame] |
#235 | |
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Looking forwards to some updates... Is the tune done now? |
#236 | ||
1337
Drives: 2013 BRZ WRB S/C
| The Following 6 Users Say Thank You to djdnz For This Useful Post: | 86 South Africa (10-27-2015), alvinli217 (10-27-2015), CounterSpace Garage (10-26-2015), FRS Justin (12-15-2015), JohnnyP (10-26-2015), sw20kosh (10-26-2015) |
#237 |
Thanks!
1) Love the results from both Edelbrock and Delicious. 2) I just want this SC kit even more now. 3) Is the Delicious tune worth paying the extra $ for on normal gas (I won't be able to use ethanol/flex fuel)... I couldn't care less about the CARB stuff - just worried about reliability, efficiency and safe power. |
#238 | |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
