#2073 | |
The car wasn't even lowered? |
#2074 |
Drives: GT86 Harrop S/C
Decent power. Was that the stock pulley and stock exhaust? I'd love to put that kind of power down with my TVS1320 and would be very happy to pay for replacement axles should they be required!
| The Following User Says Thank You to Bfranklyn86 For This Useful Post: | Silverfox (03-01-2017) |
#2075 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Stock pulley, e-85, ace header, hks front pipe, ace catback. 8psi tune. Approx 330whp 245 ftlbs Sent from my iPhone using Tapatalk |
#2076 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
No, not lowered. The shop foreman kept trying to deny me because I was on coilovers, which were set to stock height. I had to drive home, grab a tape measure, grab the shop foreman and measure the ride height on a car they had on the floor to get it sorted. |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | Silverfox (03-01-2017) |
#2077 |
Well it wasn't the axle. Somehow my hardware and bushing on the rear driver side control arm came undone 🤔
#2078 |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | Silverfox (03-02-2017) |
#2079 |
Hopefully. I should get the full story tomorrow. Still going to purchase a DSS axle for the future. When the control arm broke I was only at half e-85/91. I haven't even felt what she can do yet 💥🤤 Sent from my iPhone using Tapatalk |
#2080 |
Glorious BRZ Master Race
Drives: Subaru Libird
There are at least 2 versions of Edelbrock factory tunes that I know of: original release tune and the later released CARB tune. Would a smog test station be able to tell whether or not it is flashed to the CARB tune?
#2081 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
I could be wrong though... I'm probably wrong...
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
| The Following User Says Thank You to Xxyion For This Useful Post: | switchlanez (03-02-2017) |
#2082 |
My understanding is that the test station only checks for fault codes when doing the OBD2 check, so its not able to see the difference on tune. The CARB sticker is there so that the tech can correspond the EO number to the SC when doing a visual inspection.
| The Following User Says Thank You to BigFatFlip For This Useful Post: | switchlanez (03-02-2017) |
#2083 |
Just ordered this for my 2013 BRZ. I'm happy with the OFT stage 1 tune I have, but I was planning on adding bigger port injectors and a catless header to the bottom of the car when I install it. I also notice it comes with its own TMAP and MAF sensors [I think I goofed when I ordered a 3 bar MAP sensor right away...]. I'm less sure about how this would affect the tune I have. Should I just message Shiv immediately before installing or (provided I flash the ECU with the right injector settings) or should my stage 1 tune work for a while?
I guess a more general form of the above is, what exactly gets affected in the CARB ECU tunes for this supercharger? Sensor settings? Ignition timings? Etc.? |
#2084 |
#2085 |
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
| The Following User Says Thank You to Silverfox For This Useful Post: | Bfranklyn86 (03-03-2017) |
#2086 | |
-Are you working with Shiv on getting an OFT tune for the supercharger? I personally don't have an OFT but from what I know about it, your "stage 1" won't work. You will have to get a Edelbrock specific tune from Shiv. -I don't know what tunes Shiv has given you, but I would hazard a guess he will have to adjust it if you are planning on using injectors and header. I would also guess that he can also tune it using either the TMAP that comes with the kit or any aftermarket MAP sensors. Again, you will have to get a custom tune from Shiv. -The CARB tune is based on ECUtek and not OFT, so if you are trying to be CARB legal, you'll have to switch. As far as specific parameters? I have no idea. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
