86WORX
BT, dpfarr
Old 10-05-2015, 05:53 PM   #169
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by chaoskaze View Post
I'm pretty sure we can take out the windshield washer fluid reservoir to help with some weight. That thing is a heavy giant all the way up front. 😛
I'm no owner but likely to be one one day..
Yes, but it's way at the bottom so it helps with lowering the center of gravity.
Uplink is offline   Reply With Quote
Old 10-05-2015, 06:08 PM   #170
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
I've thought about this as well, but never mentioned it since I look at both as different "systems" with different goals/requirements: one with CARB and the other with max performance in mind. I agree, if you take a look at its individual components, the E-force seems like a steal!
You are paying for the cosworth name more than anything with their kit. I actually installed their kit on another local BRZ 2 weeks ago and it was a nightmare. The blower assy was nice but that's about all I can say about it.
As for horsepower, the biggest differences between the two kits are plenum/cooler design, runners, and intake/tb placement. I can't be certain these are the reasons for hp differences but that would be my guess.
Attachment 121932
Here's a pic for reference of the blower. Notice throttle body positioning out the back.
NotSoJDM is offline   Reply With Quote
Old 10-05-2015, 08:19 PM   #171
Edelbrock LLC
Edelbrock LLC's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Uplink View Post
Looking over the E-force kit documentation, there is no thermostat and the published dyno results were on stock exhaust components.
Our Test mule was 100% stock. Only thing we added was a bung for our wideband. Once all the testing was done we added a Borla cat-back and all cosmetic modifications. Stock thermostat is also used. No need to replace it.
Edelbrock LLC is offline   Reply With Quote
The Following 6 Users Say Thank You to Edelbrock LLC For This Useful Post:
CSG Mike (10-05-2015), CxG (11-06-2015), Nitro22 (10-05-2015), NotSoJDM (10-05-2015), Porcupint (10-05-2015), SirBrass (10-07-2015)
Old 10-06-2015, 12:30 AM   #172
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
@ notsojdm u the blue one? I'm the one bobs working on. Nice to meet u
umpadupa is offline   Reply With Quote
The Following User Says Thank You to umpadupa For This Useful Post:
NotSoJDM (10-06-2015)
Old 10-06-2015, 12:31 AM   #173
NotSoJDM
NotSoJDM's Avatar
That's me! I've been talking a lot with him, wish I lived on the right coast to meet up! Glad to see you on here too. If you're on FB, feel free to send me an add. Bob can point you my way. I'm really looking forward to see how your kit does.
Old 10-07-2015, 11:10 AM   #174
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
A couple of questions: I've noticed a couple of threads about broken supercharger belts (on other brands). are you stranded if that happens or can you drive/'limp' home?
is replacing the belt on the e-force a relatively simple matter that can be done at the roadside should a belt break? i'm assuming it's the same as replacing the stock serpentine belt - just need a wrench to pull on the belt tensioner (and any other associated tools). i was just wondering whether it'd be prudent to carry a spare belt in the trunk and tools 'just in case'.
shiumai is offline   Reply With Quote
Old 10-07-2015, 01:58 PM   #175
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Other might be more familiar, but I'll take a stab at answering your question based on info I have available:
Unfortunately, the E-force is directly driven by the belt, as opposed to an independent drive system like the one on a Kraftwerks system, so you wouldn't be able to drive away if you break a belt. The good thing is, it looks like its pretty straight forward to replace the belt. Looking at the install instructions, it looks like you would just need to take off the intake and maybe the throttle body, both easily accessible. So if you're worried about it, I would just keep a spare belt in my trunk.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
NotSoJDM (10-07-2015), shiumai (10-07-2015)
Old 10-07-2015, 02:22 PM   #176
350matt
Drives: toyota mr2/ Toyota GT86
Attachment 121932
how did it drive though?
also your link doesn't seem to work?
350matt is offline   Reply With Quote
Old 10-07-2015, 02:52 PM   #177
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
You shouldn't need to remove anything. Just use a breaker bar to move the tensioner pulley, pull the belt off, let go of the tensioner pulley, route the belt, move the tensioner pulley again, and put the new one on the pulley.
stockysnail is offline   Reply With Quote
The Following User Says Thank You to stockysnail For This Useful Post:
Old 10-07-2015, 02:59 PM   #178
Edelbrock LLC
As with many other kits utilizing a v-belt driven supercharger for this vehicle, our E-Force supercharger belt routes around vital components such as the alternator and waterpump. If a belt were to fail, you will not be able to safely drive home.
Because of the risk involved, we go to great lengths to ensure this does not happen. We work with OEM suppliers to do belt performance analysis. Loads, duty cycle, and life expectancy are carefully tested in real world conditions. There are many factors that affect belt life. Tension, idler size and type, belt wrap, and heat just to name a few. In a clean environment with good alignment and normal operating conditions and temps we can expect a minimum of 37k miles of belt life on a standard EPDM belt.
However, we do not use standard EPDM belts. We are using Continental ELITE Poly-V belts with Helicog profiles. We have been using this belt on ALL of our supercharger kits since day 1. The superior material and design allow this belt to run quieter and withstand higher temperatures than standard belts. For more information click the link below:
http://www.veyance.com/ProductsDetail.aspx?id=3128
We've really put this belt through some serious abuse with our 2300 series superchargers and it has proven itself many times in preventing belt slip and lasting longer than many other belts used for superchargers.
Lastly, replacing the belt is a one minute job at most. It is the same procedure as replacing the OEM belt. You do NOT need to remove any other components. Throttle or intake.
The belt is also easiest to obtain through Amazon Prime with one day shipping in case of emergencies.
[ame="http://www.amazon.com/Continental-Elite-4060995-Poly-V-Belt/dp/B000C30J1K/ref=sr_1_1?rps=1&ie=UTF8&qid=1444239876&sr=8-1&keywords=elite+poly+v+belt+4060995&refinements=p _85%3A2470955011"]http://www.amazon.com/Continental-Elite-4060995-Poly-V-Belt/dp/B000C30J1K/ref=sr_1_1?rps=1&ie=UTF8&qid=1444239876&sr=8-1&keywords=elite+poly+v+belt+4060995&refinements=p _85%3A2470955011[/ame]
The Following 32 Users Say Thank You to Edelbrock LLC For This Useful Post:
86 South Africa (10-26-2015), aegisdrgn (10-07-2015), ajc209 (10-09-2015), Alltezza (10-07-2015), avishenoy1 (10-08-2015), bfrank1972 (10-07-2015), BigFatFlip (10-07-2015), Calum (10-07-2015), Chimera (08-10-2016), CSG Mike (10-07-2015), CxG (11-06-2015), djdnz (10-07-2015), Firesnake (10-07-2015), funwheeldrive (10-07-2015), Griever423 (10-29-2015), itsibarra (10-07-2015), LucidMomentum (10-07-2015), Mad1723 (05-27-2018), menikmati (09-14-2016), new2subaru (10-07-2015), Nitro22 (10-07-2015), NotSoJDM (10-07-2015), Phantobe (10-08-2015), Porcupint (10-07-2015), shiumai (10-07-2015), Silverfox (02-17-2016), stockysnail (10-07-2015), SuperDave (10-08-2015), TofuJoe (10-08-2015), ultra (10-07-2015), why? (10-07-2015), zigzagz94 (10-07-2015)
Old 10-07-2015, 03:52 PM   #179
shiumai
shiumai's Avatar
Thanks to all who replied to my question - much appreciated. Thanks for the insight, Edelbrock.
Old 10-07-2015, 04:13 PM   #180
Assuming the engine isn't blazing hot, the belt replacement should be super quick. I can show you how to do it; the only tool you need is a ratchet and 14mm socket, or a 14mm wrench.
Firesnake (10-07-2015), shiumai (10-07-2015)
Old 10-07-2015, 04:24 PM   #181
shiumai
shiumai's Avatar
it actually looks like access to the tensioner is better than OEM, as the sound tube and resonator aren't there to get in the way of the ratchet. LOL - i'd bring a long a pair of gloves in the trunk just in case as well.
The Following User Says Thank You to shiumai For This Useful Post:
Old 10-07-2015, 06:51 PM   #182
VitViper
Drives: '15 FRS
Like the look of this kit... if only it would get shipped already so we could test it on our shop FR-s.
VitViper is offline   Reply With Quote
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
