#1723 |
Hmmm
Check your throttlebody to make sure it is clean. |
#1724 | |
Drives: 2013 SS BRZ
I've had my kit on for a bit over a week and occasionally get similar idle behavior but no codes yet, keep. I am going with a Delicious Tune to see if that resolves things
Other than that this kit is badass. Just enough oomph to put you back in the seat. Turning with the rear wheels is much easier, the car is even more fun to drive! Thanks to CSG Mike for being right there when I had questions, definitely glad I purchased the kit through CSG! Quote:
#1725 |
Drives: 2015 BRZ
Shameless plug you guys might find interesting-
http://www.ft86club.com/forums/showp...&postcount=323 We're installing an E-Force blower on a customer's racecar, and he's letting us instrument the living daylights out of it to see how it really performs on track. We'll be adding three air temp sensors (intake air temp, post-supercharger, and post-intercooler) and two coolant sensors (pre- and post-intercooler) to monitor performance. We're lucky enough to be based at a track in N. Texas used by several OEMs for their hot weather testing, so once it gets hot again we'll REALLY be able to put some stress on the system. |
| The Following 11 Users Say Thank You to GSpeed For This Useful Post: |
#1726 |
Drives: is300
Hey guys, just recently added an Edelbrock kit to RS2.0 #43. The install went very smooth, very well thought out kit. I flashed it with the CARB tune from Edelbrock and test drove. I get quite a bit of hesitation/surge/bucking around 3k rpm with light throttle application. It's kinda like it can't decide what to do for a second then it lights up and goes. Also, the idle when you come to a stop (car is auto) will drop for a second to 500, then return to 750ish. When you put it in park, the idle will pretty constistently slowly hunt between 500-1000 rpm. I immediately thought vaccuum leak. I have triple checked all the vaccuum lines, made sure the clamps are tight, checked the intake gaskets, etc. What are you guys doing to resolve these issues? I've got Edelbrock trying to help me also but after reading this and the other thread I see quite a few people seem to have the same issues which leads me to believe it's not installation error. The car runs great other than these issues and does not set the check engine light.
#1727 | |
Drives: 2013 Black BRZ Limited
Otherwise, getting your own smoke machine or taking it into a shop to use theirs, seems to be the only way to find vacuum leaks. I still need to find time to resmoke mine. |
#1728 | |
Drives: is300
#1729 |
Drives: FRS hot lava
| The Following 9 Users Say Thank You to Im_SPEED For This Useful Post: | Alltezza (10-26-2016), ATL BRZ (10-26-2016), CSG Mike (10-26-2016), funwheeldrive (10-26-2016), hmong337 (10-31-2016), paiceyfan (10-26-2016), sato (10-26-2016), taiguy (10-26-2016), tirespin782 (10-26-2016) |
#1731 |
Drives: '23 BRZ Limited
Torque shelf from 5000-7400. Nice!
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Yoda (10-26-2016) |
#1732 |
YEAH GOTTA LOVE THAT TORQUE CURVE!!!
#1734 |
Drives: frs
And no torque dip for fuck sake
#1735 |
my car. 700 dw injectors 65c dw pump. jdl uel headers nameless over/front pipe. stock mid pipe. nameless track pipe. stock motor. upgraded clutch and release fork. is350 3.73 rear diff, OSG LSD and DDS axles.
| The Following 4 Users Say Thank You to Im_SPEED For This Useful Post: |
#1736 |
Drives: Crystal Black BRZ(Sophia)
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
