86WORX
BT, dpfarr
Old 09-23-2016, 03:40 PM   #1639
taiguy
Drives: 2013 Black BRZ Limited
Interesting. Is this a new version of the CARB tune? How do you go about getting it?
They came out with a new version when they got their carb certification. I emailed calibration@edelbrock.com for the latest.
No idea how this might fix my lean condition, given that other people on same or older configurations haven't had my issue - but I'll give it a shot.
taiguy is offline   Reply With Quote
Old 09-24-2016, 11:43 PM   #1640
@taiguy keep me posted. Your case is unique to say the least.
Old 09-25-2016, 03:49 PM   #1641
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Got around to putting the HPFP cover back on. That damn pump is too noisy! Took a little hack 'n mod to clear the new banjo bolt position and to keep the 2 tabs from hitting the intake runners.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
BigFatFlip (09-25-2016)
Old 09-25-2016, 06:27 PM   #1642
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I've thought of doing the same Glad to see its doable.
Old 09-25-2016, 08:33 PM   #1643
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Originally Posted by FuzzyFunk View Post
This should be the finalized one that was approved with the EO number. I texted CSG this week and will schedule a time next week hopefully to have them upload it for me and to test it out. Never uploaded a tune before and don't want to screw anything up :-P Gonna have the pros do it and can't say enough good things about the professionalism of CSG.
I'm interested in knowing if you feel any difference and what the update to the file is. Is it necessary to update to this latest version for CARB compliance or is the original version compliant?
shiumai is offline   Reply With Quote
Old 09-26-2016, 02:37 PM   #1644
JGalp
Drives: 2015 CWP BRZ Limited
^^ agreed. is the tune supposed to be more efficient? better power delivery? anything like that? i was told when i got mine installed at the time that the tune was much more efficient than the original tune it came out with. hopefully this one is better as well!
JGalp is offline   Reply With Quote
The Following User Says Thank You to JGalp For This Useful Post:
shiumai (09-26-2016)
Old 09-27-2016, 11:49 PM   #1645
FuzzyFunk
Drives: FRS Monogram
I'll let you know when I have it done. Swamped with work this week. Don't think I can get it done until early next week.
FuzzyFunk is offline   Reply With Quote
The Following User Says Thank You to FuzzyFunk For This Useful Post:
shiumai (09-29-2016)
Old 09-28-2016, 03:49 AM   #1646
taiguy
This is after the car has been warmed up and is idling in the driveway. I don't want to jinx myself but the new EO tune from Edelbrock looks like it's "fixed" my wacky fuel trims while idling.
http://datazap.me/u/taiguy/log-14750...ata=6-10-11-27
The Following 2 Users Say Thank You to taiguy For This Useful Post:
CSG Mike (09-28-2016), paiceyfan (09-28-2016)
Old 09-28-2016, 09:43 AM   #1647
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
I really hope so...I have had the same issue from install with completely stock setup otherwise and would love to see that idle needle calm down.
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 09-28-2016, 09:48 AM   #1648
shiumai
shiumai's Avatar
I asked Mike at Edelbrock about the new EO tune and he replied:
"From a legal stand point, yes we suggest customers have the new E.O. certified calibration installed for CARB purposes.
As for differences, we made some adjustments in the lower RPM’s (~Under 20% throttle) which affect drivability and fuel delivery. This should result in a smoother driving feel as well as increase gas mileage. Hp/Torque numbers remain the same as before."
The Following 7 Users Say Thank You to shiumai For This Useful Post:
BigFatFlip (09-28-2016), Bonburner (09-28-2016), CounterSpace Garage (09-28-2016), CSG Mike (09-28-2016), funwheeldrive (09-28-2016), paiceyfan (09-28-2016), TofuJoe (09-28-2016)
Old 09-28-2016, 07:21 PM   #1649
taiguy
and I jinxed myself. the check engine light came on after 20 miles.
I tried to read the DTC but got a message stating
OBD Error during reading DTCs: No response to OBD request.
Great.
Old 09-29-2016, 01:26 AM   #1650
Great.
Try reading it with a standard OBD2 scan tool.
Old 09-29-2016, 08:36 PM   #1651
taiguy
The $300 scanner at Advance Auto Parts wouldn't connect. I was worried. The $35 scanner at Auto Zone (OTC 3109n) grabbed the code though.
P0507 - Idle air control system revolutions per minute higher than expected.
The Following User Says Thank You to taiguy For This Useful Post:
Silverstar (10-18-2016)
Old 09-29-2016, 10:31 PM   #1652
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Sweet you got a vacuum leak?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
