86WORX
BT, dpfarr
Old 07-29-2016, 02:10 PM   #1527
Reamer
Drives: 2015 FRS
Originally Posted by Pyrium View Post
I want this kit. Too bad I have a seven year warranty. Oh well, I hope it is available in seven years.
You can go cancel it and they will prorate what you haven't used. Then use that money to buy car parts that would void the warranty. Ask me how I know. Lol.
Sent from my ONE E1005 using Tapatalk
Reamer is offline   Reply With Quote
The Following 4 Users Say Thank You to Reamer For This Useful Post:
CSG Mike (07-29-2016), isolato (08-08-2016), raven1231 (08-01-2016), trd87t (07-29-2016)
Old 07-29-2016, 06:03 PM   #1528
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Also, don't forget the kit includes a drivetrain warranty up to the normal 3y/36k.
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
The Following User Says Thank You to Freude am Fahren For This Useful Post:
Reamer (07-29-2016)
Old 07-29-2016, 06:04 PM   #1529
Reamer
Drives: 2015 FRS
Also don't forget this is only on the CARB tune (can only be used on stock cars) and has to be installed by a certified technician.
The Following User Says Thank You to Reamer For This Useful Post:
Freude am Fahren (07-29-2016)
Old 07-30-2016, 10:47 PM   #1530
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
And here's how you install one by yourself....just be sure to have lots of ibuprofen on hand!
BirdTRD is offline   Reply With Quote
The Following 4 Users Say Thank You to BirdTRD For This Useful Post:
BigFatFlip (08-01-2016), GhostOp86 (08-02-2016), menikmati (07-31-2016), Paulo86 (08-02-2016)
Old 07-30-2016, 10:54 PM   #1531
Freude am Fahren
What's supporting it, the garage door opener?
Old 07-31-2016, 08:19 PM   #1532
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Some news !
I went to germany this week end and it was time for me to fill my tank with ultimate 102 octane gas, i switched to my second map (delicious 100 octane map) and really the car drive better, engine run smooth, good map from delicious one more time thanks to them !
As you may know there are no speed limit on some portion of the autobahn so i drove pretty fast but there were to much cars so i did not go more than 160mph ... yes the car will go more than that i can fell it and i will test it !
I'm running now mxp 4in1 el header with over pipe combo,invidia catless front pipe and a invidia q300 cat back. I didn't dyno it for now but i will do it this week if everything will be okay.
Always pretty happy with my edelbrock and the amazing delicious tune !
I'm planning to go on e85 in some month. D-box, injectors, pump, i will ask delicious for an inquiry and of course a third map ^^ powaaaaaaa !
Paulo86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Paulo86 For This Useful Post:
BigFatFlip (07-31-2016), CSG Mike (08-01-2016), MaximeT (08-01-2016)
Old 08-01-2016, 07:54 AM   #1533
BirdTRD
Simply Forgotus
BirdTRD's Avatar
That certainly would have made things "fun"! I actually used my atv winch and with the compound pulley setup and the remote, I had very precise control. Made that part of the install quite easy!
The Following User Says Thank You to BirdTRD For This Useful Post:
Reamer (08-01-2016)
Old 08-01-2016, 12:36 PM   #1534
wootwoot
Drives: FRS
Can you use a mishimoto upgraded radiator with this kit? I already have the radiator installed with a liquid to liquid oil cooler....
wootwoot is offline   Reply With Quote
The Following User Says Thank You to wootwoot For This Useful Post:
jawnthen (08-29-2016)
Old 08-01-2016, 07:34 PM   #1535
the_one_mike
Drives: 2013 BRZ World Rally Blue
I recall somebody a few pages back using the Jackson Racing radiator with this kit and had intake temperature problems due to increased temp under the hood. The solution ended up being a heat wrap for the airbox and intake tubing, plus the addition of some foam around the edges of the radiator to funnel air into the right places.
Edit: Here you go:
Originally Posted by Tomcat07 View Post
I did this as well. The first thing I noticed was major power loss delivered from the engine. I thought I messed up my MAF position and went to my tuner to have it checked out, but then discovered that the tune was fine and the IATs were through the roof. My IATs went from 115 degrees to 145 degrees. I think it's because the radiator isn't ducted the way the oem one was.
I just put some foam weather stripping around the radiator today and plan on testing it out. To see if that helps.
I think this big bad radiator is heating the air in the engine bay more than the oem one did due to its increased cooling capacity and the intake was sucking air from the engine bay around it following the path of least resistance.
The airbox was also very hot to the touch after a little bit of driving so I may end up heat shielding the whole intake right up to the pulleys.
EDIT:
Also I will be testing it out at Roebling Road Raceway June 4th and 5th so I'd like to compare results with you. I won't be able to log it, just take measurements at the conclusion of each run.
I had the line kink issue as well, we had to massage it to get them to not kink the same way you did.
We also reused the OEM cap because the Jr cap didn't fit properly.
the_one_mike is offline   Reply With Quote
The Following User Says Thank You to the_one_mike For This Useful Post:
Tomcat07 (09-08-2016)
Old 08-01-2016, 09:46 PM   #1536
taiguy
Drives: 2013 Black BRZ Limited
Not sure if it's been mentioned, but CSG includes a free D-box with every Edelbrock order placed since the D-box's release, upon request. It's THAT good.
*edit* The D-box is not CARB exempt, and technically makes your car not compliant with California emissions. If you want to be 100% emissions legal in California, you cannot run the D-box.
When did the D-box come out? If we ordered a kit before the box was released, can we get a discount?
taiguy is offline   Reply With Quote
Old 08-02-2016, 12:36 AM   #1537
Yes. PM to order.
Old 08-02-2016, 12:37 AM   #1538
Originally Posted by Paulo86 View Post
Some news !
LMK when you're ready. We can package everything together w/ a DT FNG and FF kit. You'll also want a clutch if you're a manual trans type of guy.
Old 08-02-2016, 10:53 AM   #1539
Paulo86
Paulo86's Avatar
sorry i will take all the stuff from delicious ! and i'm AT
some dyno results of this morning :
blue : stock tune, k&n air filter, agency power cat back
pink : 98ron tune, edelbrock, agency power cat back
green : 98ron tune, edelbrock , gutted stock header, invidia FP, stock Midpipe varex axleback home made (big shit to much back pressure kill power !)
red : 100 octane tune, edelbrock, MXP 4in1 el, MXP OP, Invidia catless FP, invidia Q300 catback, 102 octane gas in the tank
sky blue: 98 ron tune, edelbrock, MXP 4in1 el, MXP OP, Invidia catless FP, invidia Q300 catback, 102 octane gas in the tank
an other picture with :
green : 100 octane tune, edelbrock, MXP 4in1 el, MXP OP, Invidia catless FP, invidia Q300 catback, 102 octane gas in the tank
botbs (11-23-2020), MaximeT (08-02-2016), stoked_on_spool (08-03-2016)
Old 08-03-2016, 02:27 AM   #1540
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I have the mishimoto rad with this kit with no issues. Also have a oil cooler. No track days to test anything.
clayrush is offline   Reply With Quote
Search this Thread:
Advanced Search
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 11:09 PM
