| BRZ First-Gen (2012+) -- General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | |
Drives: 2014 BRZ Limited
| The Following User Says Thank You to extrashaky For This Useful Post: | Ultramaroon (08-20-2015) |
#16 |
@extrashaky most people don't see the coolant temp gauge go up even during a 20 minute track session in the heat.
#17 | |
Not Bаnned Anymore
Drives: Heavily Modified FRS
#18 | |
Drives: 2013 BRZ 6MT
Was out at Buttonwillow Raceway this past weekend and even in the later sessions where ambient air temp was 102 degrees, with the car getting a full flogging, the coolant temp gauge needle never budged from it's usual place. I knew coolant temp had to be warmer; just figured the gauge was broken until I read this thread. |
| The Following User Says Thank You to PWBRZ For This Useful Post: | strat61caster (08-19-2015) |
#19 | |
Drives: 2015 Series.Blue
Many people start freaking out at oil temp over 200F for some reason. It NEEDS to get above the boiling point of water so it can boil off the contamination. |
#20 | |
fabulous
...but 220 is no biggie as long as pressure doesn't drop off. I don't know because I still don't have a pressure gauge
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Tcoat (08-20-2015) |
#21 |
Not Bаnned Anymore
Like the other guy said it boils off as it gets close to 212, it doesnt just happen all at once. I just dont like how the ECU pulls power (I read that somewhere dont quote me, but my butt dyno seems to feel it, although it could just be AIT's getting too high in traffic aswell)
#22 | ||
Any thermostat will open earlier than the desired peak temp to head off temp spikes. Local heating of the oil is going to be higher than what the overall temp is going to be as well, but getting the oil good and hot every so often (in my case, usually daily) is far better than having it cold. Yes of course there is such a thing as too hot, but the average person isn't going to see that outside of track use. Quote:
Most cars will pull timing a bit when things get too hot. You're usually going to have this stuff step in from coolant temp or IAT first though. Never had a car that didn't hate the hot ass summers around here... |
| Noob help please | WhiteShadowFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 07-24-2014 10:22 AM |
| radiator noob question/IAT's | BRZPDX | Forced Induction | 4 | 06-02-2014 11:17 PM |
| FS: Robispec Radiator (Massive radiator and liquid to liquid oil cooler in one) | Sportsguy83 | Engine, Exhaust, Bolt-Ons | 15 | 05-27-2014 01:18 PM |
| Mishimoto Radiator & Mishimoto Radiator Hose Kit | tlinspired830 | Engine, Exhaust, Bolt-Ons | 5 | 01-08-2014 09:44 AM |
| noob help | juanam0909 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 09-28-2013 02:17 PM |
