Old 08-13-2015, 12:50 PM   #1
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Gas Pedal Relocation Kit- Proof of Concept
We made a gas pedal relocation kit to try out. The stock gas pedal location leaves a little to be desired, so we machined this bad boy to try out an idea.
By moving the gas pedal less than an inch closer to the driver, the gas pedal is now slightly above the brake under heavy brake pressure. This forces you to raise your heel to reach the gas, which gives a much more stable toe position on the gas pedal. As I'm sure you guys are aware, it's easy to let your foot slip off the side of the brakes, and this gives a little more confidence in your stance on the brake pedal.
Here's pictures of it installed. It's 100% bolt-on, and can be installed in about 10 minutes.
Here's a picture of it off the car, along with an extended pedal stop made from acetal.
This is a render of the production version with rounded corners and pockets:
GSpeed is offline   Reply With Quote
The Following 13 Users Say Thank You to GSpeed For This Useful Post:
Anthonytpt (03-14-2016), BatStig (08-13-2015), civicdrivr (08-13-2015), CSG Mike (08-13-2015), DAEMANO (08-13-2015), DustinS (08-13-2015), ichitaka05 (08-13-2015), kch (08-14-2015), P@ul (03-01-2016), Ramster (08-13-2015), Teseo (08-13-2015), The Racers Line (08-17-2015), WillRacer1jz (08-15-2015)
Old 08-13-2015, 12:59 PM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I'd be really into this! The first thing i noticed about the pedals in the BRZ is that i could never heel-toe like i could in my MINI. Does the pedal in this position affect the feel when cruising with one's heel on the floor in an appreciable way?
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 08-13-2015, 01:14 PM   #3
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
We haven't driven it on track yet, but we don't expect it to change the feel much. It's definitely different, but it seems like something you'd get used to quickly, just like different pedal positions in different cars.
Old 08-13-2015, 01:29 PM   #4
wparsons
wparsons's Avatar
I find that with the stock pedal placement the gas is already in a good place, that's with stainless lines, MC brace and non stock (less compressible) pads. It would be interesting to try with it further out just for comparison though.
flickr
Old 08-13-2015, 02:15 PM   #5
raven1231
OMG the mod everyone has been waiting for!
Old 08-13-2015, 02:18 PM   #6
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
subscribed to see if this ever becomes a thing
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-13-2015, 02:51 PM   #7
sirbobbinhood
sirbobbinhood's Avatar
Drives: 2014 WRB BRZ
Subscribed for when these go on sale.
sirbobbinhood is offline   Reply With Quote
Old 08-13-2015, 04:17 PM   #8
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I'm pretty sure both the brake and clutch pedal are height adjustable...
Autocross nut
AustinTX is offline   Reply With Quote
The Following User Says Thank You to AustinTX For This Useful Post:
GSpeed (08-13-2015)
Old 08-13-2015, 04:39 PM   #9
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Put me on the list. There have been a few times where my foot slipped off the brake pedal or when I went to blip the throttle only to hit air.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-13-2015, 05:46 PM   #10
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Correct, but by my measurement the brake light switch is activated at a little over 1/2" of brake pedal travel. (Measured with a dial indicator on the pedal pad.) I don't think you'd be able to adjust the brake pedal to the point where you get the same geometry we settled on, especially considering we moved the pedal laterally as well.
Waiting on one last quote to come back, then I'll post a group buy thread with pricing.
Jake
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
Old 08-13-2015, 08:21 PM   #11
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Cusco throttle pedal plate cures that issue
Sleepless is offline   Reply With Quote
Old 08-14-2015, 10:01 PM   #12
philooo
Drives: 13' Scion FRS Track car
I have to say that the Cusco pedal plate did also work quite well for me. Same end result, but cheap way to go.
I am not sure if raising the pedal would also be a good addition. But considering PST strong research background I am open to the idea
Phil
philooo is offline   Reply With Quote
Old 08-15-2015, 01:23 AM   #13
Premium 615
Premium 615's Avatar
Drives: '15 BRZ Limited
Subbed... looks interesting!
2015 Subaru BRZ Limited AT6
Premium 615 is offline   Reply With Quote
Old 08-16-2015, 10:56 AM   #14
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
http://www.ft86club.com/forums/showt...94#post2358894
Alright, group buy is open through the end of the month. Any kits ordered by the end of the month will include a $25 off coupon for SCCA TNiA!
The Following User Says Thank You to GSpeed For This Useful Post:
civicdrivr (08-16-2015)
Accelerator Pedal relocation Caspeed Scion FR-S / Toyota 86 GT86 General Forum 2 12-03-2014 09:37 PM
[GTA]Where did you get your rust proof done JERM^ CANADA 4 09-17-2014 04:11 PM
dealer asking for proof of oil changes. EZWood Issues | Warranty | Recalls / TSB 25 09-11-2014 12:06 AM
Anybody tried rust-proof BRZ? qqzj Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 04-18-2014 05:18 AM
