#57 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Most heater hose I've seen is rated to 275 F. As Weeder mentioned, I put some thermal sleeving on mine where they run close to the block or exhaust - just as a precaution.
If you use silicone hose the temp rating bumps up to something like 350 F. In addition, I picked up a molded 5/8" silicone 90 degree "L" to make the transition from the exit of the Forester/WRX coolant pipe to the OEM heater hose cleaner.
Slow is smooth, and smooth is fast
#58 | |
Drives: White GTS then Black GTS
#59 |
Why not just use the throttle body method?
2013 Series 10 FRS #553
#60 |
Yes I am going to try the TB method. I wonder if anyone running into heat problem for the hose when connecting the TB? I am sure the hose would touch the metal part. Do I need to use some kind of heatshield like this one to protect the hose? https://www.ebay.com.au/itm/172355932574
#61 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#62 | |
Persona Non Grata
First, I bought the various parts to do the OEM(ish) approach 3 or 4 years ago and never got around to installing them. The current environment offers the time to finally put that together. Second, aesthetically, I like the cleanliness of that installation. Third, functionally. I have a hunch it may offer better coolant flow through the heat exchanger than the TB approach - admittedly, I'm just pulling that out of my ass but, oh well. If I were going to use a different variation, I'd use the feed side of the OEM approach and run the return line over the top of the engine around to the rear of the water pipe that bridges the two cylinder backs and swings around the passenger side to the upper radiator hose. There's a plate on the rear of that pipe that blocks off what on automatic trans cars is the return line from the trans cooler. I considered just buying the housing that bolts to that port and returning the coolant there. But, as I noted earlier, I already had the parts to do it this way and now have the time.
| The Following User Says Thank You to Capt Spaulding For This Useful Post: | jflogerzi (05-21-2020) |
#63 | |
Persona Non Grata
#64 |
Something like this will help: https://www.spectreperformance.com/3...er-hose-sleeve
I was fortunate that the Cusco kit came with some plastic covering, but I still used the braid on a few sections, too.
#65 |
Drives: 2019 BRZ Sport-Tech RS
I used Vibrant hose #20425. Highest temp rating I found (350F). One hose is more than enough - I had a bit left over.
https://vibrantperformance.com/catal...fe4e30d2eeed54 |
#66 |
Thanks guys, I will go with silicone hoses + shield
#67 |
Drives: 2017 toyota 86
Bypass the TB. You don’t need the coolant heat soaking the TB.
#68 |
Drives: European gt86
#69 |
It’s only purpose is to warm up the TB when it’s below freezing and you park outside. Otherwise the 190f+ coolant will heat soak the TB, a lot of people just delete it from the loop. It isn’t going to hurt anything keeping it, but no point for most.
| The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | T0rt0r0 (05-25-2020) |
#70 |
Drives: 2014 BRZ
Agreed. I bypassed the throttle body on my '14 about four years ago and have had no problems in temperatures as low as 0 F.
(Incidentally I did the same mod to my Forester as well with no problems.) |
| The Following User Says Thank You to T-Steve For This Useful Post: | T0rt0r0 (05-25-2020) |
| Perrin Oil Cooler Kit Installation and Review!!! | Sony | Engine, Exhaust, Transmission | 29 | 03-27-2017 03:03 PM |
| Texas Heat Sale- Perrin Oil Cooler 10% Off with Installation! | GSpeed | Southwest | 0 | 07-30-2015 03:47 PM |
| Beat the Texas Summer Heat! Perrin Oil Cooler 10% Off with Installation! | GSpeed | Engine, Exhaust, Bolt-Ons | 0 | 07-30-2015 03:44 PM |
| Robispec Radiator/oil cooler NEW $800 or trade for NEW FB oil cooler kit. | mike the snake | Engine, Exhaust, Bolt-Ons | 1 | 01-31-2014 06:46 PM |
| Oil Cooler usability: Changing oil, installation, etc | post_break | Engine, Exhaust, Transmission | 20 | 06-12-2013 03:36 AM |
