#15 |
Drives: GT86 Cosworth
ppppssssssttttttt Racecomp
Here in Europe Ohlins are selling the dampers without top mounts for a reduced fee.... any chance of a set of rears to match the fronts? |
#16 |
Drives: 14 BSP Edelbrock BRZ
Since there isn't a rubber cap where the spring contacts the plate I'm guessing these will increase NVH?
#17 | |||
Should be fine with brands that use that same thread pitch/diameter. We will likely do special orders for others but have not worked out price or timing. Quote:
![]() Yes stock is best for NVH but these will be quiet and smooth for a long time. Quote:
) is limited so we're focusing on fronts. For now. We are very much thinking about it though and may even incorporate a few neat features. Contact us if you're interested.- Andrew Last edited by Racecomp Engineering; 08-05-2015 at 03:52 PM. |
#18 |
Drives: 2023 BRZ
I don't know much about camber plates. It seems to me other plates are specifically for OEM or certain brands of coilovers. Can you explain to me:
1. How does this plate accept both OEM and KW coilovers when others cannot? 2. Are there sacrifices made or compromises of design to ensure this flexibility? Thanks! |
#19 |
^^ This. Great design @Racecomp Engineering
| The Following User Says Thank You to fika84 For This Useful Post: | Racecomp Engineering (08-05-2015) |
#20 | |
2. Nope. Some camber plates come with a fancy upper spring perch with roller bearing type option at a much higher cost, but with proper installation and a good quality main bearing this isn't usually needed. We've been making camber plates for Subarus since 2005. ![]() - Andrew |
#21 |
Drives: FR-S Whiteout
@Racecomp Engineering Andy No specs on the maximum camber adjustment range, yet?
Intent > Content
cowardice is the mother of cruelty. |
#22 | |
On RCE T2s (and KW/ST) you can get more...honestly a TON with the plates and the slotted lower mount. More than anyone should need. - Andrew |
#23 | |
For instance, a stock strut with -.5 built in coupled with a adjustable top offering -1.5 of adjustment will end up with -2.0* maxed out. The geared adjuster is a pretty awesome idea. I had an alignment tech ding up my top plates trying to get to the camber specs I asked for. So you can say I'm looking at replacement options.
Intent > Content
| The Following User Says Thank You to solidONE For This Useful Post: | Racecomp Engineering (08-05-2015) |
#25 | |
Drives: 2023 BRZ
That said, I likely have higher expectations than many people. I typically put 20,000+ miles on my car every year, including ten to 15 track days. Also, I live in Colorado and drive the car year-round. When I modify my car, I want to do it once and do it well. I don't want to have to worry about servicing aftermarket parts on a regular basis. I have heard of people rebuilding (?) camber plates every couple years due to NVH that creeps in. Given how and where I drive my car, what should I expect for service intervals on camber plates? If you have any wisdom to share with me I'm all ears. |
#26 |
Drives: Scion FR-S
Is the caster fixed or adjustable?
#27 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
Another beautiful camber plate design from RCE. These and the original GD Subaru plates look amazing, and work just as well. They look like pieces you'd see as one-offs on someone's big $$$ custom build. I had a set of their lowering plates on my '07 STI. The camber adjustment was silky smooth and never bound up.
Looks adjustable via those gold "keys". |
| The Following User Says Thank You to Draco-REX For This Useful Post: | Racecomp Engineering (08-06-2015) |
#28 |
That's the camber adjustment, caster would require sliding the whole upper mount forward or backwards.
| The Following User Says Thank You to wparsons For This Useful Post: | Racecomp Engineering (08-06-2015) |
| Dominant Engineering Custom Bc Coil Camber plates and rear Uca/Upper Control Arms | thatcosta | Canada Classifieds | 2 | 04-23-2015 12:49 PM |
| GC Camber Plates and Robispec Street Rear Tophats | ReThink | Brakes, Suspension, Chassis | 0 | 10-01-2014 11:06 PM |
| -0.5 for RaceComp Engineering | wrxneffect | User/Vendor/Sponsor Reviews, Feedback, Comments | 3 | 03-04-2014 05:21 PM |
| megan racing street series coilovers w/front camber plates | 256brz2013 | Brakes, Suspension, Chassis | 33 | 07-01-2013 10:39 AM |
| Racecomp Engineering | industrial | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 05-02-2013 05:17 PM |
