#351 | |
Drives: Q5 + BRZ + M796
I took off the passenger rear panel to check the ground, and it was rock solid. I undid the sub quick release bolt and reached behind and wiggled some wires to see if that made a difference, and it didn't affect the output of the music playing. I didn't have much time to do much else. I didn't have much time to really assess everything, but the sub seems fine. I don't know about the rear speakers or tweeters, but the door speakers are both affected, and it just seems like the whole cabin is affected. Tomorrow I will try to isolate the sound by moving the sound around on my head unit. I wish I had my old head unit to eliminate the head unit as the problem.
#352 | |
Master Collaborator
I would check the speaker wires for any possible shorts to ground. Unplug the ten-pin connector from the factory amplifier to avoid erroneous readings that the amp may present, then pull the head unit, unplug the ten-pin and six-pin plugs and check for any continuity from each of the speaker output wires on the ten-pin and the six-pin plugs to ground. There should be infinite resistance to ground from each pin. From there, if that test gives you normal results, ohm out each speaker and look for differences between left and right matching speaker pairs. You might have a blown speaker or filter capacitor. It wouldn't hurt to check your door speakers at the factory amplifier as well in the same manner as above if no anomalies are present in the first tests. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Irace86.2.0 (03-05-2022) |
#353 | |
#354 | |
Master Collaborator
That could be a speaker wire intermittently touching ground with expansion and contraction of the wire harness from ambient temperature fluctuations, or possibly a bump in the road jarring the wire where it's close to chassis contact. Or it could be something inside the head unit itself. Sometimes intermittent issues like this can be difficult to track down. |
| The Following User Says Thank You to FR-S2GT86 For This Useful Post: | Irace86.2.0 (03-10-2022) |
#355 |
Update: I’ve done nothing, and everything seems to have fixed itself. Hopefully it stays like that.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | soundman98 (03-19-2022) |
#356 | |
Master Collaborator
Awesome. I love it when problems just go away by themselves. Like whenever I start hearing a noise, I just crank up the stereo volume so that I can't hear it anymore. Gone just like that! As for your issue, let's hope it stays that way. |
| The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post: | Irace86.2.0 (03-19-2022), soundman98 (03-19-2022) |
| Tags |
| amp, audio, music, radio, subwoofer |
| Audio Equipment Part out! AVH-x4500bt, illusion audio, OEM amp, arc audio and more!!! | CamryDS | Audio/Visual, Electronics, Infotainment, NAV | 25 | 10-23-2015 10:10 AM |
| Incriminator Audio 6.4, Sundown Audio SAX-100.4, US Amps Xterminator XT800.2 | slicktop | Miscellaneous | 1 | 07-11-2014 09:58 AM |
| WTB: berk dual delete/perrin exhaust. JDL El headers. BBK kit. OEM Audio+/JL Audio | YEAHdams | Want-To-Buy Requests | 0 | 07-01-2014 12:37 PM |
| FR-S Audio Build - SQ (Illusion Audio/Mosconi) | DekaMori | Electronics | Audio | NAV | Infotainment | 28 | 04-17-2013 05:34 AM |
| 'Noobish' questions as I look to upgrade my car audio audio. | DkY in Vcr | Electronics | Audio | NAV | Infotainment | 0 | 09-22-2012 10:45 PM |
