Old 08-03-2015, 06:23 PM   #15
DAEMANO
Time Traveller
The amount of stupidy in this thread...
But OP great questiong and my answer is idunno. But would love to know if theres actually an answer.
Actually @Gunman answered the question correctly just a few posts above.
Originally Posted by Gunman
The high pressure in the wheel house, will be higher than the flow along the body, and the air will move from high pressure to low, seeking equalization
Old 08-03-2015, 06:51 PM   #16
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I would certainly think so
Old 08-03-2015, 07:16 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Gunman View Post
The high pressure in the wheel house, will be higher than the flow along the body, and the air will move from high pressure to low, seeking equalization.
Assuming the car has no fender liners.
For any fender vent to work, there has to be an inlet for air to pass in from. If there isn't (or if the stock fender liner is left intact), there is no use for this other than cosmetic.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
DAEMANO (08-03-2015)
Old 08-03-2015, 07:34 PM   #18
mav1178
mav1178's Avatar
Originally Posted by Top-Secret View Post
And I started to focus on high pressure build up in the wheel wells and how it *could potentially* cause lift.
I think to understand one you must look at the overall picture.
"Lift" in the wheel well, sure, but what is the overall aero balance? If having a bit higher lift in the wheel wells via enclosed fenders w/ liner yields better overall aero balance in the front end overall, I'll take the small tradeoff and find downforce elsewhere (canards, splitters, both, etc).
I enjoy watching sports car racing because top teams always try to find ways to improve aerodynamically. To have a functional vent you must always have a way to feed the vent...
Some samples:
http://www.mulsannescorner.com/newsmarch15.html
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
8R6 (08-03-2015), Top-Secret (08-04-2015)
Old 08-03-2015, 09:16 PM   #19
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The air coming into the wheel well and inder the car tends to be of a higher velocity and lower pressure. When it meets the spinning wheel volume of air it is diffused. That airflow loses velocity and increases in pressure.
I'f In not mistaken, it isn't the high pressure causing lift but, the LOW pressure on the backside and top of the wheel. This is why the tops of fenders are louvered and the rears aren't as wide as the front on widebody fenders or the rear section is vented... to get air out of the fenders as efficiently as possible.
One of the reasons for lips and front diffusers to have the little wing's infront of the wheel well it to help direct air not moving along the body away from the high pressure zones.
Again, no expert.
Feel free to become one. You gonna need some time to get through it all.
http://ltces.dem.ist.utl.pt/lxlaser/...apers/15_1.pdf
http://www.ara.bme.hu/~regert/public..._corrected.pdf
http://www.ara.bme.hu/~regert/public...s_cmff2003.pdf
http://www.atzonline.com/index.php;d...lloc=3/id=8005
The Following User Says Thank You to Kiske For This Useful Post:
Old 08-03-2015, 11:08 PM   #20
CrispyCheddar
CrispyCheddar's Avatar
Drives: the white one
bro, you got a voicemail
If you can't win a race, beat the person in front of you
CrispyCheddar is offline   Reply With Quote
Old 08-04-2015, 03:49 PM   #21
Top-Secret
Drives: FRS monogram
good thing i have nothing but time at work. thanks for the links. ill keep reading into it more
Top-Secret is offline   Reply With Quote
Old 08-04-2015, 09:18 PM   #22
Gunman
Drives: 2019 Mazda Miata RF
6 of one, half dozen of the other. The pressure delta is the key, and as long as the pressure in the wheel house is higher than that going over the top of the fender, venting it will create downforce, aka reduce lift.
You're venting air, and turbulence created by the rotating tire, "tire squirt" behind the tire, air from bead blowers, and other fans, and air being extracted from front diffusers. The more you get out of the wheel house, the better all those things work.
If you look at this GT-D/GT3 Viper, the side cove has a passage from the wheel house, to allow air to exit from behind the tire. This is the same on the GTLM version. But, the GT-D/GT3 also has vents above the tire, for even more downforce.
Note no vents on top of fender, this is the GTLM (Lemans) spec car:
But GT-D (and GT3) has the top of fender louvers:
Note, I use the Viper as example, since I am most familiar with that GT car.
Gunman is offline   Reply With Quote
aero, aerodynamics, fenders, trd, vents
Vented BRZ Fender Trim! zkv476 DIY (Do-It-Yourself) Guides 121 11-05-2018 12:10 PM
Titan Supra Competes at Texas Invitational - Supra is still competitive Video Titanmotorsports Off-Topic Lounge [WARNING: NO POLITICS] 0 05-20-2014 12:53 PM
RB style fender kit... Shit Luck Exterior Parts (Aero, Lighting, Etc.) 4 10-28-2013 08:34 PM
Supra TRD style hood for FR-S Larkin Cosmetic Modification (Interior/Exterior/Lighting) 19 08-19-2013 12:10 AM
What I just don't understand... Liquidcell Scion FR-S / Toyota 86 GT86 General Forum 35 08-30-2012 09:38 AM
