86WORX
Old 09-08-2022, 02:39 PM   #15
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by Maafeu View Post
Hey quick question,
I'm having an issue with one of my cylinders, number 2 to be exact. swapped the Coil and replaced the plugs, still an issue. Might be a fuel rail issue, but I was doing some work and I think I might have borked the Fuel Injector Module. I was thinking of grabbing another used Fuel injector module and testing to see if that fixes the two error codes I was getting in relation to that.
Question for you is when you were successful with getting your car to start, was it running with the Fuel injector you grabbed from the other car? or did you roll back to the ecu you had in the car originally before putting back the MAP Sensor?
Thanks in advance.
That person hasn't logged in since 2016.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
Search this Thread:
Advanced Search
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Dented fuel injector? pgranberg11 Engine, Exhaust, Transmission 7 07-14-2015 01:58 AM
Fuel injector cover Notorious RBG Engine, Exhaust, Transmission 1 01-29-2015 09:14 PM
fuel return system? lbroskee Engine, Exhaust, Transmission 4 03-04-2014 07:56 AM
Fuel Injector Cleaner Purdue FR-S Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-18-2013 07:54 AM
