#1317 | |
Drives: 2013 Scion FR-S AT Asphalt
Look, I am not discounting anyone's work. In fact, what makes Nameless' and P&L's header designs so remarkable is that they have made monumental strides in solving this problem. There is nothing wrong with someone sitting back, and saying "prove it". Scott
#1318 |
That Guy
Drives: 2013 asphalt FRS MT
ok guys, intake harmonics, 0.101. This is the VERY simplified version as I'm way too far removed from those days in the classroom to try to drudge up the math.
Any tube with air moving through it will create resonances, just like one of those toys you spin and make different tones at different speeds. The runners of an intake manifold act just like those tubes. When these resonances in an intake manifold align with valve events so that the back side of the valve is pressurized by the sound pressure, you get more fresh air into the combustion chamber. Thus you make more power. When the resonances and valve events align so that the back side of the valve is in a slight vacuum you get less fresh air into the combustion chamber which results in less power. These resonances occur at a frequency set by the intake manifold runner's cross section area & length (just like tuning the port of a subwoofer if you've ever played with winisd, or the lengh and width of a wave guide if you've ever played with a smith chart) as well as the engine rpm and the profile of the intake camshaft. They also occur at double, triple, quadruple, and every whole integer multiple of the original frequency. As the order or resonance goes up though, 2nd, 3rd, 4th and so on, the amplitude of the resonance decreases. Most intake manifolds are designed to use the third or forth order resonance, this means the peaks aren't as high, making the intake manifold less efficient at those RPM that put pressurized air at the back of the intake valve, when compared to an engine using the first order resonance. But it also means the intake manifold is less in-efficient at the rpms that put a low pressure on the back side of the intake valves. The other advantage of higher order resonance is it also make packaging MUCH easier as the runners are much shorter. This engine is different though, the runners are naturally long to accommodate the boxer layout. Without dusting my books off, I'd guess that this intake is using first order harmonics with valve events aligning to give peaks at ~2700 rpm and ~6500 rpm. There's a fair amount that can be accomplished with cam phasing to keep the pulses in the intake and the valve events coherent. But along with those two peaks, we also get a valley in the middle. This is the source of the dip, intake manifold resonance. Headers work in much the same way, but lower pressure at the back side of the exhaust valves result in more exhaust gasses being pulled out of the combustion chamber and thus more power. Headers can also benefit from using the vacuum created behind the exhaust gases as they travel through merging tubes, using stepped designs to prevent resonance at certain rpm, and 4-2-1 designs to give multiple first order resonance. Metric fuck tons of math later you get dynos like you see in this thread. |
| The Following 6 Users Say Thank You to Calum For This Useful Post: | civicdrivr (02-20-2013), fenton (02-20-2013), Khalis (02-25-2013), LeeMaster (02-21-2013), reeves (02-20-2013), Shankenstein (02-21-2013) |
#1319 | |
That Guy
Here's the proof the nameless is working on an intake manifold. http://www.ft86club.com/forums/showp...postcount=1048 I'm not going to prove that the intake manifold is causing the dip, I don't have the time, money, or resources. The only thing I have is some poorly educated speculation. If you make some educated guesses though, I'm pretty hypotheses will hold up which is all any of us have until we see some results. :happy0180: |
| The Following User Says Thank You to Calum For This Useful Post: | OrbitalEllipses (02-20-2013) |
#1320 | |
Drives: 13 CSB BRZ Ltd
![]() -Acree |
| The Following 2 Users Say Thank You to Acree For This Useful Post: | naikaidriver (02-20-2013), OrbitalEllipses (02-20-2013) |
#1321 | |
Drives: Turbocharged
Bonjour
Nameless Performance official tuner..dont ban me I'm not selling anything
| The Following User Says Thank You to johnbradley For This Useful Post: | naikaidriver (02-20-2013) |
#1322 |
As hard as I try to stay informed in these threads I missed that post. I stand corrected Acree. Thanks for digging that up.
Scott
| The Following User Says Thank You to naikaidriver For This Useful Post: | Acree (02-20-2013) |
#1323 |
Drives: Attitude
#1324 | |
I havent had any evidence to the contrary so I havent done it yet. Again its one of the testing phases where the big list of things to try and ADD dont always work out
#1325 |
#1326 | |
Drives: FR-S/92 3kgt VR4
#1327 | |
Kuruma Otaku
In the mini-dip, the AFR goes a bit richer, right? Is that something the ECU is doing, or you are doing (richer there to allow more advance)? Have you done any experimental runs with cam position with fixed overlap(turn off AVCS?) so you can get a better look at the torque curve to see where the acoustic effects are having positive and negative effects? Then Jason could maybe work backwards to sort out which component on which side is responsible for the changes? (just brainstorming, I know you guys know what you're doing...)
Because titanium. |
#1328 |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
I would love to see this header on E85 tune. I think dip could be totaly gone with E85.
If you look at all the Dyno of E85 from: 2form, P&L you see that it helps a lot in the deep compare to 91 or 93 |
#1329 | |
Grip>Slip
After sending in the first datalog the next revision resulted in 9 peak HP gain (and 20+ in some areas) over the first revision. It also broke the 200 HP mark. We've still got some more tweaking to do, otherwise I'd post a copy of the virtualdyno (and head to the real dyno for confirmation), but as of now the torque dip is more or less nonexistent on my car. The thought of this header + E85 just made my pants get tight for some reason. |
#1330 |
Drives: WRB BRZ
ill wait for nameless to come out and post their information..this thread is chaulked full of speculation.
| The Following 3 Users Say Thank You to norsamerican For This Useful Post: |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
