jpit
Old 02-20-2013, 08:41 AM   #1289
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by XPR Small Block View Post
i just know with v8s a "Shorty" header creates more lowend torque vs. a long tube header which makes more topend i would assume the same thing would apply here
Pretty well all of the rules of thumb have been thrown out the window with this engine. We've had Visconti reporting almost no difference between 91 and 93 octane, Nameless made more power with a 3 inch exhaust vs. a 2.5, Full Blown has made over 520 whp on a stock longblock, two tuners that I know of have reported making the most power at over 12:1 air/fuel ratio and running a safe AFR of high 11's on pump gas with turbo'd engines... Just throw all of your preconceived notions straight out the window.
The Following User Says Thank You to Calum For This Useful Post:
Jive Turkey (02-20-2013)
Old 02-20-2013, 08:59 AM   #1290
FR-S Matt
So basically what you're saying is this engine is an enigmatic beast?
Old 02-20-2013, 09:01 AM   #1291
Calum
That Guy
Everything we've seen so far has pointed to just that.
Old 02-20-2013, 09:42 AM   #1292
FR-S Matt
Hmm, looks like I'll be taking the plunge on the 3" DP/OP and hopefully a 3" midpipe with a beefy resonator. I'm so indecisive, lol.
Old 02-20-2013, 12:12 PM   #1293
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
With almost 250 crank Hp we start to be close to the point where a 2'5 exhaust start to induce some restriction. So A couple of sharp bend could make it hapen sooner.
This graph is with Crank Hp not WHP
Mars2 is offline   Reply With Quote
Old 02-20-2013, 12:13 PM   #1294
Mars2
Sorry that was to explane that I'm not surprise 3" exhaust make more power than 2.5"
Old 02-20-2013, 12:22 PM   #1295
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Where did you find that chart?
-Acree
Acree is offline   Reply With Quote
Old 02-20-2013, 12:41 PM   #1296
d1ck
Drives: Black 2013 FRS
This doesn't take the thermal efficiency of the engine into account. An engine with a higher thermal efficiency will produce more HP for a given exhaust flow rate.
d1ck is offline   Reply With Quote
Old 02-20-2013, 03:13 PM   #1297
mad_sb
Drives: 2013 Asphalt FR-S
Ha.. Jason almost had me talked into the 3" yesterday.. I went ahead and ordered the 2.5 but am waiting on them to test the 2.5 midpipe and revised axleback.
Old 02-20-2013, 03:20 PM   #1298
FR-S Matt
Yeah, I'm going to talk to him again. I'm not afraid of the 3" system. I just need a good resonator and a 3" midpipe to go with it. It will be easy swapping to turbo later.
Old 02-20-2013, 03:30 PM   #1299
johnbradley
Drives: Turbocharged
I disagree. The 'regression' around the dip between runs is ECU. The dip itself is an acoustics artifact.
Yeah, the dip is a combination of compromises NOT just the tune. There are only so many variable you can adjust in the tune and by this point the combination of tuners have touched them all on various cars and no one has eliminated the dip.
This header design and tune combination has already turned a big chunk of what was the dip into a mound of torques... I stoked to see the finished product and how it performs.
I agree with these guys. After having done some extensive naturally aspirated tuning with Hondas in the last 2 weeks, dips like those are present in LOTS of applications. Oddly enough playing with the actual intake pipe length and diameter made the most differences on those.
Originally Posted by Skywgn1 View Post
I would like to know how the ECU handled the header without the tune. Are there graphs and actual figures?
I meant to have gotten that done but didnt remember in time...next time though.
I can tell you there is no power loss running NA between a 12.0:1 and a 13.5:1. On a turbo motor you will always make more power lean but with Subaru head design thats a bad idea for #3 and #4. I have made best power on most Subaru drag race tunes at a 12.5:1 but I would never leave it there on the street.
Nameless Performance official tuner..dont ban me I'm not selling anything
johnbradley is offline   Reply With Quote
The Following User Says Thank You to johnbradley For This Useful Post:
Skywgn1 (02-21-2013)
Old 02-20-2013, 03:31 PM   #1300
johnbradley
When I'm looking at the AFR, what exactly am I seeing? Is the straight dotted line the 'target' and the wavy solids the actual?
Dynojet lets you set a "safe" limit line if you want. That particular one is a 12.5: and is more for a quick visual reference if I am lazy and dont want to get out of the car to stare at the screen.
Old 02-20-2013, 03:59 PM   #1301
reeves
Hope this isn't too far off subject, but would a CAI intake with longer piping work better than a short-ram intake? As far as making the most difference to minimize the dip? Or is it negligible?
reeves is offline   Reply With Quote
Old 02-20-2013, 04:15 PM   #1302
naikaidriver
Drives: 2013 Scion FR-S AT Asphalt
This is WAAAYYYY off subject but honestly, new intakes (whether CAI or short ram) don't do anything for the torque dip. In fact, there are some intakes that make it worse without a tune.
If you want to eliminate the dip, it looks like your choices are, forced induction, header and tune, e85 tune.
Scott
naikaidriver is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 11:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 05:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-19-2012 12:32 AM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 05:32 AM
