#4201 |
More like find an actual dyno that shows AFR of both stock intake vs injen and see if there are any that show similar AFR, or better yet find tuned oem vs tuned injen that shows injen better. I am not saying it isn't better but I have yet to see a dyno showing any gains. I have however tuned a car with an injen intake and i have to say what a living hell. So much turbulence! The Maf voltage log looks like an accordion!
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
#4202 | |
Bottom left - TRD Top right - Injen Your MAF curve shouldn't go up and down during a wide open throttle pull like this. It should also be smooth. The TRD has no air straightener, but the OEM does from the factory. This "bump" is what causes the CEL, idle issues, fuel trim issues, etc. The dynos that I have seen all show stock rom with ecu reset and the pulls on injen running leaner than stock which is where the extra power comes from. I have yet to put one on the dyno to see if it did worse than stock though.
| The Following User Says Thank You to nelsmar For This Useful Post: | Brahsbrah (04-14-2014) |
#4203 |
Drives: 2013 BRZ Sport Tech White Pearl
Ugh.... Basically cost me $400 to get it to Canada.
#4204 |
Fanboy
Drives: 2013 ultramarine frs
Sorry dude. It's just a bad item. Lots of work to get it to just work as well as stock. I wasn't bagging on it to be a **** I was trying to save you money and time.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#4205 | |
I got it from rallysportdirect... Just checked out there return policy and it looks pretty good. Sorry for the thread jack... |
| The Following User Says Thank You to Brahsbrah For This Useful Post: | FrsDuke (04-14-2014) |
#4206 | |
Drives: 2013 Asphalt FR-S
As for the tune, not much to change. I would like to fine tune it on the dyno to get avcs just right but it doesn't seem to need anything special. I'm burnt out on spending several hundred dollars for dyno time everytime i change something. I'm probably just going to dial in the afr and then go do a pull and leave it alone unless something is off. Power wise, it feels alittle stronger everywhere than the Fa20, except maybee the last 500 rpm up to the limiter, hard to say since i don't get on it much due to the stupid rattle / ringing.
~Namaste~ |
#4207 | |
Fanboy
#4208 |
Drives: 2018 BMW M240i
I have not seen anything from Jason or Ryan for a while.
Have they posted any updates on the header and dyno's or fitment issues anywhere else? |
#4209 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
How many of us are having leaky header issues? I've been a bit quiet about it but it's getting frustrating at this point. I paid for express shipping to get the headers in time for an autoX event and turned out to have a leak. The leak could be felt coming from the connection to the overpipe while idling (I have the Nameless 2.5" OP/FP), so it's not a small leak where it can only be felt under load.
First I took it to my local shop, where they tried double gaskets and sealant. Still leaked. I overnighted a Grimmspeed gasket and put it with Nameless supplied gasket, including exhaust sealant. Still leaked. Nameless sent me a special graphite gasket. Still leaked. In the off chance that I'm wrong about the location of the leak, I ordered yet another set of Grimmspeed gaskets for the connection to the heads. If it still leaks, I'm really considering requesting a return rather than an exchange. |
#4210 | |
Drives: '13 6MT Raven FRS
I dont 'think' I have a noticable leak at idle but under load on throttle there is a very apparent hiss from the front of it leaking somewhere. Idle is a bit off too (which i kind of expect without a tune) and no CEL yet (after about a 1000km of driving). Hoping the new gasket and grimmspeeds will solve it because otherwise my butt dyno is loving the extra torque. If it doesn't work this time I'm not sure what I'll do. I'll send a message to nameless one more time I guess and see if there are any alternatives as I really want this to work. |
#4211 | |
Drives: First SWP BRZ-L
After talking to Ryan yesterday, it sounds like most everyone's leak issues were fixed with better gaskets. The 3" to 2.5" just means there's not much overlap between the two flanges, makes it a little tough. Sorry to hear yours still is leaking I hope they get it fixed for you.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#4212 |
I spoke to @Ryan@Nameless on the phone last week, he said they have never had fitment issues etc and told me to contact some other dude whose name i forgot. I specifically told ryan before this header shipped that i was having issues with the front pipe but thought it was due to the fa20 header he said to contact them if i continued to have issues, which i did then was told to contact someone else. I think it was John.
~Namaste~ |
#4213 | |
~Namaste~ |
#4214 | |
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | verts (04-15-2014) |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
