86WORX
jpit
Old 04-04-2014, 07:00 AM   #4145
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
The sound is from the vvt timing, the stock tune has some noise there while any tune for EL headers will have more. It resonates in the exhaust so some piping makes it worse.
I had it with the nameless opfp combo and it is more pronounced now and goes all the way to redline. If you cruise in that rpm it goes away, only under load or decel.
My plan is to coat the dp with the thin cheap local coating and wrap both header and dp (op/fp) once I can be sure I won't over tighten the wrap. (coating for corrosion resistance)
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
mad_sb (04-04-2014)
Old 04-04-2014, 09:53 AM   #4146
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Pistol View Post
i thought the metallic sound was the VVT angle change from the OFT/flash as it was obvious before the header installation.
Now the header just amplifies that sound.
There are a few threads on this metallic sound already, all started before the nameless header came out
Is everyone who can hear the metallic sound running a tune?
I have had the 3600 rpm metalic noice for a long while, can reduce it by pulling back on the intake cam advance but hat hurts power so i just live with it. I has been there since i started tuning way back when i was stock and everyone but me (seemingly anyway) was using off the shelf ecutec tunes.
All the changes along the way have added to the volume of the sound, intake mods, exhaust mods, and yes header as well, not even the nameless header as i have yet to install mine.
You will get a different sound if the pipes are just barely touching the the sway or sub-frame under load.
As for the exhaust leak everyone is having trouble with at the header to front pipe connection.. that is always a problematic connection, short of using a 3 bolt flange, i think the best bet is to make sure the over pipe is bolted to the header before anything else and use a thick / double gasket or a single gasket with a little ultra copper.
The Following User Says Thank You to mad_sb For This Useful Post:
Pistol (04-04-2014)
Old 04-05-2014, 01:16 AM   #4147
Slip Angle
Drives: Devolving WR Blue 6 Spd BRZ Limited
I am getting the metallic sound from 3500 rpm up as described since adding the header. It sounds like it's resonating from the rear of the car from the mufflers? I DON'T have an ecu tune but do have nameless high flow cat and 5" mufflers. Header certainly added torque and will be great on track but what was a nice sounding exhaust is now really unpleasant and exceedingly loud.
Anyone know if putting the stock mufflers back on but keeping the header and high flow cat might make the sound more tolerable without losing the nice power gained by the header??Thnx
Slip Angle is offline   Reply With Quote
Old 04-05-2014, 01:42 AM   #4148
Slip Angle
We fabricated an aluminum heat shield to protect the stock intake and to keep intake air temps down for track day use. Put gold heat reflective tape underneath it and welded a simple bracket that screwed easily into a conveniently located factory screw hole. It seems to be working well so far but can't really tell on the street. I have already had oil temperature issues on track and probably need to add an oil cooler as well.
The Following User Says Thank You to Slip Angle For This Useful Post:
BatStig (04-05-2014)
Old 04-05-2014, 01:44 AM   #4149
Slip Angle
More pics
Old 04-05-2014, 01:48 AM   #4150
Slip Angle
Another pic with intake back in place
Old 04-05-2014, 02:00 AM   #4151
verts
verts's Avatar
Drives: '13 6MT Raven FRS
That heat shield looks awesome! Going to have to try something like that!
Did my install tonight, header flanges to head seemed fine with grimmspeed gaskets. Header to op (2.5" nameless op/dp) used a 3" and 2.5" gasket and snugged it up.
Op is reaaallly close to the head. Still gotta bolt up the midpipe brace so hoping i can pull it away a bit.
Wouldnt suggest doing it on jackstands. Defs doable, just a huge pain in the ass.
Edit: just started it up and damn its awesome. Not for those looking for quiet setups though haha!
verts is offline   Reply With Quote
Old 04-05-2014, 09:21 AM   #4152
StormTrooper
I can tell you that with the stock exhaust it sounds fine from outside but I think it makes the vvt resonance worse.
Cruising it's dead quiet, when you get on it the noise while not loud is well tinny.
I'm going to try heat wrap and see it it helps any.
I was hoping the nameless exhaust would just be loud but not have that cheap civic noise.
GR86 MT premium
Old 04-05-2014, 12:29 PM   #4153
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
This is my experience as well on the stock exhaust. Best sound I've had from the headers so far is with a straight pipe, but that puts me straight into "WHAT THE FUCK DID YOU JUST SAY?!?" levels of loud.
Decay107 is offline   Reply With Quote
Old 04-05-2014, 02:32 PM   #4154
Slip Angle
Thanks, what you said is spot on. Too loud or too quiet is certainly subjective but the stereotypical civic "fart can" sound is hard to live with. That said, the header really is a solid product with nice torque gains by seat of the pants. My neighbors may not appreciate it as much as I do. LOL
Old 04-05-2014, 04:31 PM   #4155
xjohnx
Grip>Slip
xjohnx's Avatar
are you going to be making these available for purchase?
Old 04-06-2014, 10:50 AM   #4156
mad_sb
So I followed my own installation advice and got a leak free seal at the front pipe but a nice leak at the block lol.
On my fa20club header i got it to seal to the block by tighhtening the 2 inside nuts first then criss cross tightening the outer 2 on each side. Tried the same with the nameless and new subaru multi layer metal gaskets.... I think the double gasket trick might be needed on the block side. I'm going to loosen them all up this am and re torque evenly and see if i can get it to seal.
Old 04-06-2014, 01:11 PM   #4157
mad_sb
Found one potential source of the metalic ringing noise
So, I went out this AM to loosen and re torque the header to manifold nuts. I gave everything a good looking over and noticed it was not leaking at the block like I thought it was, turns out the clearance to the driver side subframe and motor mount heat shield is VERY tight.
I snapped a couple pictures of it before attempting to adjust the fitment. The passenger side has about double the clearance. I'm fairly sure this is the source of the metalic ringing under throttle that I am getting.
The Fa20club header apparently had this same fitment issue on the passenger side mount heatshield as you could visibly see the wear marks on that side. I could hear it more when next to a wall on the right side of the car with the fa20club unit and more when next to an object on the left with the nameless.
I adjusted fitment as much as possible (not much at all)and stuffed some header wrap between in the gap on the driver side. If that does not fix the problem i am going to double gasket the block using the oem style gaskets and modify the heat shield (not the good multi-layer ones) to buy a tiny bit of clearance.
You may notice i have megan mounts, but this was an issue prior to the megans as well with the old header.
Pistol (04-07-2014)
Old 04-07-2014, 07:05 PM   #4158
choi0706
Drives: t
I'm thinking I've got a leak at the flange between the overpipe and header.. Testing with smoke.. It does seem less than ideal using a 2.5" overpipe..
choi0706 is offline   Reply With Quote
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 03:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 11:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 05:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-19-2012 12:32 AM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 05:32 AM
