#2045 |
rolling over my sidewall
Drives: 15 FRS
#2046 | |
Grip>Slip
i'm sure i'm missing some key verbiage in there, but that's the gist of it, if i recall correctly. |
| The Following User Says Thank You to xjohnx For This Useful Post: | Scooby South (08-19-2013) |
#2047 |
Drives: '13 BRZ Ltd
That is true, but there is a cat in the front pipe as well - so you could run a catless header with a catted front pipe and remain legal. Or a catted header with a catless front pipe.
| The Following User Says Thank You to Wepeel For This Useful Post: | Scooby South (08-19-2013) |
#2048 | |
Drives: GR86
Wepeel beat me!!! Last edited by Stevo22; 08-19-2013 at 03:05 PM. Reason: Wepeel beat me |
| The Following User Says Thank You to Stevo22 For This Useful Post: | Scooby South (08-19-2013) |
#2049 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
edit: actual rule E. Catalytic converters: Any catalytic converters are allowed, but must attach within 6” of the original unit. Multiple catalytic converters may be replaced by a single unit. The inlet of the single replacement converter may be located no further downstream than 6” (152.4mm) along the piping flow path from the original exit of the final OE converter. The extents of an OE converter are defined by the expansion
chamber in which the catalyst is contained, regardless of placement within larger exhaust sections. Replacement converters must have a minimum catalyst density of 100 cells per inch and minimum substrate length of 3” (76.2mm). Last edited by Ranatsu; 08-19-2013 at 03:24 PM. |
#2050 |
Grip>Slip
Yep, you're right. At least I had the general idea right.
#2051 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
The Actual Rule:
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#2052 |
Conedancer
^^^ Which is why Nameless will make 2 versions of headers... one with the fan Replacement...one thats 'STX' Legal and no fan replacement..
#2053 |
Drives: Attitude
The difference in price and performance between the two is what'll do it for me. I don't want to cut up shrouds and stuff in the interest of returning to stock...but I'm not going to leave 20hp on the table.
| The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post: | chanomatik (08-19-2013), StormTrooper (08-19-2013) |
#2054 |
Grip>Slip
| The Following User Says Thank You to xjohnx For This Useful Post: | wparsons (08-19-2013) |
#2055 | |
Drives: Pavement MT GR86
I highly doubt it'll be over a 10hp difference. That being said, I don't have plans to leave the region for autoX. And therefore care very little about the class my car ends up in.
GR86 MT premium
#2056 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
I am a bit late to the thread... and I have not read all 94 pages.. tbh, I am a bit new to cars but my new FRS is turning me into a car enthusiast.
I have been shopping around for mods that will grant me more power without voiding my warranty so... a turbo/supercharger is out. therefore, I am stuck with intake/exhaust/weight loss and other trivial stuff.. I cannot, for the life of me, find much out there for aftermarket headers.. not even Perrin sells a header. This dude does. Can someone answer my questions? Why, if adding on an aftermarket header, do so few companies not make headers if they can add a great deal of power? Are aftermarket headers legal? Will I pass emissions in Mass with them? I dont believe it will void my warranty if I get one.. Last question.. where the blazes can I get one that meets the demands I listed above?! |
#2057 |
Drives: Scion FR-S | 6MT | Ultramarine
Can't freaking wait! This is going to be awesome.
#2058 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
| The Following User Says Thank You to Jive Turkey For This Useful Post: | roddy (08-20-2013) |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 03:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 11:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 05:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-19-2012 12:32 AM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 05:32 AM |
